Question about Philips Magnavox DVD/VCR Dual Player
We bought dvd/vcr model number DV2209. I hooked the cable to it so i could record shows. Wont let us watch any shows through it....?
    Genius:
  • 1,148 Answers
Turn it off to watch cable,,
Posted on May 17, 2009
I have an RCA VCR model VR651HF that still works great. I can record shows without a problem as long as I'm not trying to watch a dvd. I recently bought a Sony dvd player model DVP SR200. I have my cable...
The sequence should go from the wall to the VCR then the VCR to the RF modulator then from the RF modulator to the TV and this should allow you to record a TV program and watch a DVD at the same time.
Feb 25, 2011 | RCA VR651HF VHS VCR
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Bought a new VCR/DVD combo. Have TV with cable
Hard to believe you do not have any "F" connectors on the VCR/DVD. What brand is this? You should have inputs and outputs for separate composite and audio. Using phono cords with male ends you should be able to go to and from your television for recording and watching. It will mean alot of changing to go from one mode to the other but should be doable provided your tv has composite in/out. Your owners manual should show a diagram to hook the unit up this way. If you get stuck email me and I'll try to walk you through it. Give me as much info as you can on inputs and outputs. Let me know.
hardrocko
Feb 01, 2010 | Televison & Video
Cannot tape on vcr with new dvd-vcr player
You need to route the signal from the cable modulator to the DVR and then to the TV to be able to view and record. If this is done you will be able to watch what you are recording. When you are not recording, the signal will go through the DVR to the TV.
Please change the cabling and you should have what you want.
May 26, 2009 | RCA 32V550T 32" TV
VCR WON'T RECORD
you may have the outputs hooked up correctly however you may need to set the inputs to the selected type of cable you are using. S video 1 cable or video input witch is an rca adapter yellow in color. you will find these setting in the "setup section" on the remote set up button will get you there and then input or source.
Dec 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
Hook-up strategy
OK I will try to explain this...You need to go from your OUT TO TV output on your cable box and split that line so you have 2 lines coming out,then you can hook one to your vcr and one directly to your tv.Then you can watch tv while you are recording something on your VCR.I hope this helps
Sep 24, 2007 | Samsung DVD-V4600 DVD Player/VCR
Philips Magnavox DVD/VCR Dual Player Logo
75 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
