Question about GE GTS22KBP Top Freezer Refrigerator
Evap fan does not run
Evap fan would not run, got new one, works on it's own, when put it place, it still won't run. how do you test electronic board?
    Sergeant:
    Champion:
  • 214 Answers
Please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
Posted on May 14, 2009
Kenmore 106.54584400 fridge warm, air baffle No open in normal ops. in test mode opens and closes but evap fan does not run. fan motor runs during normal ops. thermistors good in test mode.
I would meter test the evap fan it may have gone out cuz if it was ur defrost timer or cold control you would have no motor condenser fan working either? and no cold control damper working in test mode?
is the fan impeeded or just not moving?
May 21, 2015 | Kenmore Refrigerators
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
GE GSH25JSTASS doesn't freeze or cool
Ok, first off, replace all thermistors, freezer (2) & refrig (2). Then check that evap fan is working properly. This is a DC volt fan, not ac volt. There have been some issues with these, I would replace if problem continues.
How this box works, main control board monitors everything from how many times doors are open, how long they are open, how and when I/M drops ice, etc.... Every so many hours, depending on how many times the doors are open, you got ice thru the door, etc... it will shut down and go into defrost mode. When it is time for defrost mode it will run refrig into a "sub zero" state, shut down evap fan, run deeper into sub zero effect, shut down compressor when the thermistors say it's cold enough, turn on defrost heater that melts any frost in evap, then turn compressor back on for a few minutes, then turn evap fan back on. Most techs think that the mother board is defective when in fact the thermistors are not measuring temps correctly within the whole unit. If the thermistor say, hey mother board I'm only 60 degrees in the freezer, then it will keep running the compressor trying to get to zero or -1 or till the darn thing freezes up and stops moving air.
Find another tech to work on your unit, one that has some electronics background and/or computer knowledge. It takes a electronics & computer degree to work on these units and understand how they function.
Doors, some of the new frigs have magnetic door gaskets, if it is not staying shut, replace door gaskets. If door stay open or is leaking air (especially around ice shoot) it can cause some really weird stuff to occur, like thermistors saying I'm cold at the inlet to evap but not at the top of evap and mother board will try to correct it's self by running longer. One other thing about door gaskets, if the drain plug in the evap area is frozen or plugged up, doors won't shut properly and stay shut.
For one thousand dollars, I'll come to Florida and fix for you, 200 to fix refrig and the rest for a good time at Disney World (LOL). Good luck. Contact GE for repair on this unit if you can't get good results from your repairman. Their people, like me, go thru extensive training on these boxes. You can thank our goverment for the energy codes that have gone into effect over the years requiring mfgs to have to keep the cost of running these refrigs down as low as possible, the only way to do this was to computerize these boxes. Good luck
Sep 30, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Fan in freezer not working
It runs when the compressor runs except when it's in the defrost cycle. If you have an electronic control instead of a defrost timer the control could be the problem since it runs the fans. You can test the evaporator fan. See how here> How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
Refrigerator has a clicking sound and does not run
Replace the motherboard (part # WR55X10942) but be careful to check that the evaporator fan (inside the freezer) turns on when you power up the refrig again. A bad evaporator fan motor can take out the motherboard. If compressor starts with new board but not evap fan, unplug immeadiatelly and replace the evap fan motor to save new board.
Sep 11, 2009 | Refrigerators
New evaporator fan not running smoothly
Great ! ! Usually the main control board is the problem , when the evap fan doesn't run .
Sep 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Refrigerators
Fridge and Freezer won't cool.
The evap fan is running - but is your compressor motor running -t his is what i'm concerned about - 82F ? That is very high - this suggests to me there is no cooling AT ALL - only the fans are working - and my gut tells me your compressor is not running AT ALL - I would rule out thermostat since when it kicks in and your evap fans turn on, your compressor should turn on too. If this fridge has electronic controls, have your motherboard / control boards checked, have your compressor checked. If your compressor is running and you can hear its distinctive humming sound, then you have a sealed system problem, a major one :) Have those two things checked.
Aug 19, 2009 | GE Refrigerators
Evap fan wont run can it be tested for bad board
Using a little 9 volt square battery , unplug the fan motor and connect the battery to the motor . ( fan runs on low voltage dc ) . If the fan runs , board is bad , if not , then motor is bad .
Jul 17, 2009 | GE GSS25SGMBS Side by Side Refrigerator
GE GSS201EMDCC Fridge and freezer not cooling.
there is probaly a "clixon" in the unit that senses the temp of the evap. if the evap does not get down to a certin temp the fan will not run. this makes it so you do not have ice crystals all over the freezer. matters on model. also sounds like the fridge might be short on gas.
Apr 08, 2009 | GE GSS20IEM Side by Side Refrigerator
GE GTS22KBP Top Freezer Refrigerator Logo
158 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
