Question about Garden
Mower stalls out after about an hour of run time
When I engage the blades on the mower it runs fine for about an hour or so but then begins to stall out. I have to let the mower sit for awhile then I can resume mowing, but it will stall out again after awhile. I have replaced the fuel filter, oil/filter, blades, air filter and greased all lube points on the mower.
    New Friend:
    Problem Solver:
  • 14 Answers
I would start with the fuel cap, but probably the coil if its a single cylinder,,,
Posted on Jul 12, 2013
My Husqy was doing the same thing and had it into two shops and they all thought I was on crack as they never got it to die. I happened to be talking to a customer of mine who used to do small engine repair and he said replace the gas cap. Apparently they are vented and sometimes those vents get clogged. As you mow it sucks gas into the mower and the tank compresses because it can't get air. Eventually the compression is stronger than the suction to the engine and voila, no gas and you die. As you let it sit, the tank slowly pulls air back into it going back to it's original size and you can start it again. Quick fix if you can't find a cap is when it dies take the cap off and let it expand, put the cap back on and start her up.
Posted on Aug 08, 2010
A few possibilities
1. If engine runs hotter than normal it can eventually heat up the carburetor to the point that there is a vapor lock. Blockage caused by gas bubble: a bubble of vaporized gasoline that blocks the normal flow of fuel. Problem goes away when things cool down. If that is the problem, you need to solve overheating problem. Since you have changed the oil, might be something blocking airflow to the flywheel which has the cooling blades on it. Or cooling blades are filled with debris. Make sure vent hole in gas cap is not blocked
2. Could be bad coil, or condenser causing the windings to act up when they are hot and have expanded they short out (kill engine) on their own casing. After they coil and shrink, they un-short themselves.
Posted on May 14, 2009
I have a toro zeroturn mower motor starts up fine I can drive it around fine, but as soon as I engage the mower deck the motor will start running rough then stall out. why?
Could be there is an obstruction in the deck that is not allowing the blades to turn freely and stalling out the motor.
Sep 13, 2017 | Toro Garden
Ariens lawn edger bogs down and stall when the blade is engaged
sounds like you need to return it and get replaced should be warrantied sounds like the bearings are seizing up on the blade shaft .
Jul 26, 2015 | Ariens Wheeled Edger - 986103
Why does my craftsman riding mower choke itself off when too hot
Clean the carberater the carberater is the number one problem for craftmen lawnmowers pay close attention to where the springs are hooked there are several holes the spring can go in take it apart slow and clean every littel hole and put it back together take your time dont get in a hurry its not to hard just time consuming then anythaing sholdent take a newbie more than 2 or 3 hours max me half an houre
Aug 18, 2014 | Craftsman Garden
Engine stalls when blade fully engages
its a bad safety switch adjustment you can remove the wire to test it only LoL
May 20, 2012 | Snapper Garden
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Riding mower stalls when PTO is engaged.
check the kill switch and the wire it could be that a small piece of the covering came off and is grounding to the deck or frame there by killing the engine the jerkink of the mower maybe whats causing the wire to come into contact with metal..good luck
Apr 03, 2010 | Garden
When I engage the mower blades, the tractor tries to stall
Hi..my name is Keith..and the newer mowers have all kinds of safety switches..and the mowers will shut off..if you put the mower in reverse with the blades on..so i would suspect you have a bad reverse safety switch..i hope this will help..if not please write me back
Jul 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Garden Logo
549 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
