Question about Fujitsu fi-5110C ScanMaker Scanner
Reinstall the scanner
Last month i tried installing a different printer for my work computer & it erased the download for the fujitsu fi-5110C scanner i have hooked up to it. I still have the disk & tried to reinstall it but it wouldnt work so i had to use the trial version, it has now expired. since i still have the disk, i just need help getting it reinstalled so i can start using it again.
  • 4 Answers
Explore the driver CD....you will find a tool to clean the installation . it will clean up in 2 secs.
Posted on Jul 03, 2009
The printer my have corrupt the setup of your scanner. So try and uninstall the setup properly and install it again.
How to unistall go to your control panel-Double click on Add or remove programs-then click on the scanner's setup then click on remove or change.
LATEEF FOR FIXYA
Posted on May 14, 2009
Scanner is not connected or another application is using it
The driver might be corrupted. Suggest that you remove the driver and re-install it (Start, Printers & Devices, right-click your scanner and select Remove Device).
Jun 18, 2014 | Fujitsu fi-5110C ScanMaker Scanner
Fujitu FI 6670 service manual
Fujitsu has documentation for all of their products on their website.
Here is a list of all the scanner docs:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/docs.html
For the FI-6670 they link to 3 different documents:
Datasheet [587KB]
Getting Started Guide [1.39MB]
Operator's Guide [12.7MB]
Jan 31, 2014 | Fujitsu fi Office Equipment & Supplies
Can't connect fujitsu 5120c scanner to windows 7 machine
To connect your Fujitsu fi-5120c scanner to Windows 7 PC, you need to install the TWAIN driver for Windows 7. Please download the driver update from the link provided below:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/twain/v9211013.html
Hope the above information is helpful.
Please feel free to to contact us for further assistance.
Thanks & regards,
ScanCare
Sep 04, 2011 | Fujitsu fi-5120C
Does fi 5120 driver works on Window 7?
Fujitsu fi-5120C is compatible with Windows 7. However, you have to download and install the scanner drivers for Windows 7. Click HERE to download the required drivers and toolkit (Installation & User Guides are also available).
Run the downloaded file and follow the on-screen instructions to install the scanner drivers/ toolkit.
Hope it helps! Good Luck!
CreativeTECH
Mar 16, 2011 | Fujitsu fi-5120C
I was just upgraded to Windows 7 and after using it for about 3 days, now my scanner is not being recognized by the system. How do I reload it to recognize on my computer without any disks?
kindly update the fujitsu scanner driver for your 5110 scanner to windows 7..
Mar 14, 2011 | Fujitsu fi-5110C ScanMaker Scanner
How do I make color scanning the default for my Fujitsu 5110C?
on the comp under printer setting find your printer then right click then go to make default priter go to start first controll panel printer and fax,s
Nov 08, 2010 | Fujitsu fi-5110C ScanMaker Scanner
The fujitsu fi-5110C won't scan all pages just takes the whole thing and just scans the first page. Is there a setting where you can make the scanner to scan each page one at a time? thank you :)
Please follow the information provided below:
If all the pages are being fed through ADF and if image format is TIFF, then you may require another application to view the multi page TIFF image. If you're using ScandAll 21 or ScandAll Pro application for scanning, you have to choose multi page scan option in Batch Scan Setting. Please follow the help contents provided in the scanning application.
Hope the above information is helpful. Please revert if you have any doubt.
Regards,
TechSatya
Jun 29, 2010 | Fujitsu fi-5110C ScanMaker Scanner
Can't install scanner
First chek if the USB ports are working by inserting a known working device, like a pendrive. If it is working then change the USB cable. Buy a good quality cable designed for USB 2.0. This is shielded cable and this should solve your problem. Pls ensure that scanner is powered.
S. Mohan, Chennai, India
Nov 22, 2008 | Fujitsu fi-5110C ScanMaker Scanner
Fujitsu fi-5110C ScanMaker Scanner Logo
213 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
