Question about Black & Decker & Leaf Hog Blower / Vacuum
Toro Ultra 225 Leaf Blower - Speed not controllable & stops
Can I bypass the speed control and solder the AC directly to the motor to use the blower as a fixed speed device?
5 Suggested Answers
rwvanlue
  • 486 Answers
SOURCE: the electric motor on my B&D LeafHog leaf
My experience with B&D products is that the unit can be repaired, but by the time you buy the part and pay shipping, even doing the work yourself, you may have close to the replacement value. You can get parts from blackanddeck.com
Posted on Nov 12, 2009
  • 72 Answers
SOURCE: My electric B&D leaf blower started to slow
Hi, sounds to me like you got worn brushes on your electric motor. On units that you can change brushes easily there is a screw plug that is located where each brush is positioned. This way the brushes can be easily replaced without removing the plastic cover. If your unit does not have this access, then the brushes are probably soldered in. In this case your better off checking the warranty and/or buying a new one because the motor is burnt. You can avoid this problem by using a thicker extension cord that is plugged to a dedicated receptacle. This way the motor will not heat up as much and burn out prematurely. Hope this helps.
Posted on Nov 30, 2010
SOURCE: My motor brushes at end
Try Platt Electrical supply - 800-257-5288 (Platt.com) BLACK & DECKER #89754-01 REPLACEMENT BRUSH. It seems the entire motor head was manufactured by DeWalt and is now obsolete. I don't know if these brushes will fit, but someone there may help.
Good Luck!
Posted on Aug 31, 2011
  • 6468 Answers
SOURCE: electric b&d leaf blower will not turn on
open the covers while unplugged and see if a wire came unplugged
Posted on Mar 24, 2012
Toro mower over heats
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jul 10, 2014 | Toro Lawn Mower With Toro Power Tools
Why will my toro 5198 leaf blower not start?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Jun 28, 2014 | Toro 51599 Electric Blower 12 Amp
Motor won't turn on
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Apr 14, 2014 | Toro 51599 Electric Blower 12 Amp
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
Apr 06, 2014 | Toro Blowers Rake and Vac - Electric...
Blower does not turn on
Apr 03, 2014 | Toro Garden
Snow blower shorted out
Feb 17, 2014 | Toro 51599 Electric Blower 12 Amp
Motor was losing power and burning
Jan 13, 2014 | Toro "Toro" Super Blower/Vac
Brushes on the motor are bad. where can I buy them
Sounds like the brushes are worn out and in need of replacement, if available.
Nov 04, 2011 | RTO Weed Eater Electric Barracuda 2595...
Plugged it in and it won't run but it was running fine when I put it away two weeks ago.
Check the plug for loose wire or at blower where wire it enters to make sure the wire was not pulled and disconnected inside. If after looking and it is not a wire, check the brushes on the motor. They could be worn out or not making a good contact. Blow out brush housing and re-install brush sometimes this works. That's about all I can think of unless there is a safety switch then check that. Good luck.
Nov 22, 2010 | Toro Craftsman 225 mph Electric BlowerVac
After a couple of hours of use last week, the motor started slowing down. Turned it off and it would not restart. tried again after an hour and it started but sounded really rough. stopped it and took it...
sounds like the motor is worn out. Toro does not sell the motor separate. It is considered a throw away unit.
You will have to purchase a new one.
Sorry.
Good Day.
Nov 05, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
Black & Decker & Leaf Hog Blower / Vacuum  Logo
408 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
