Question about Brother HL-2040 Laser Printer
I recently plugged my printer into a USB Hub Adapter, and since then it won't print a total document. At best, half the document, but usually just an inch or so. I've checked all the settings. Things LOOK normal. What should I do?
The printer is an HP Officejet v40. It appeared to be fixed last night and printed out one entire sheet, but then went back to only printing out partial pictures and text. How much would it cost me to find out how to fix this? Do I need a new driver? What could it be?
Barb Thompson
Posted on May 15, 2009
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
All of a sudden when I went to print a document I get a message that says printer is offline??
Usually when you see this it just means the printer is in sleep or low power mode and won't wakeup. Try turning it off and back on or pull the data cable and put into a different usb port. You can adjust some settings in the usb port and the printer that sometimes will make this a bit better but usually you have to wake it up from time to time. Some usb hardware is better than others at waking up what is called Legacy hardware which is just the term for things left plugged in. I have two identical pcs and one does this all the time and the other doesn't. It is better on a a newer laser printer we installed than it was on a inkjet but still does it from time to time no matter what settings.
I usually swear at mine and threaten it as well but pulling its cord seems to make it work the best ;-]
Sep 02, 2011 | Canon Pixma MG5220 InkJet Printer
My Dell V305 printer will not print the whole page of an email. This is a document that I need the whole page.
You can get the half document when yhr printer runs out of memory ie too big a or too detailed a print job or if the document itself contains what the printer is seeing as control or commad characters and errors out. It can also be a port error.
Usually its just too detailed a print job. When you print click on the printing preferences and then look for either a DPI setting or a Quality setting. Turn any of those down and try printing. You may have to turn it down more than once to get it to behave. Most new printers can print at 2400 dpi. Unless you know what too look for you won;t be able to see much if any difference even down to about 300 dpi.
Sometimes you cn get port errors and those can be hardware or operating system caused. You can try another usb port. Also try rebooting and printing with nothing else running.
Aug 26, 2010 | Dell Office Equipment & Supplies
When connecting the usb to printer and camera when i go to print it says usb error
The two devices are probably overloading the USB power. The total power output on one hub in the computer is limited to 500mA. If they work separately, this is most likely the problem. The way to fix this is to purchase an inexpensive powered USB hub (it will have a power supply to plug into the hub as well as the USB cable to the computer).
May 13, 2010 | Polaroid PoGo Digital Photo Printer
Lexmark to HP problem
I've never successfully connected a Lexmark USB printer to a Parallel port with an adapter as the adapter doesn't provide bi-directional commP, use a USB powered hub, if the system doesn't have USB, try an USB expansion PCI card
Mar 19, 2010 | Lexmark JetPrinter Z11 InkJet Color...
Only one half of page prints.
My suggestion would be to totally un-install the printer and erase all traces of the driver(s). Search for them after the un-intall and erase them manually.
Re-install the printer and driver...reboot if nessasary...align the print heads...do a test pattern...then try and print your document. It might just be a corrupted driver...some would suggest just installing over the existing driver...but I've found doing it that way gives you the best chance of it working the first time.
Apr 24, 2009 | Epson Office Equipment & Supplies
Printing not proper
Adjust the printing properties from normal to best.
Mar 28, 2009 | HP DeskJet 3940 InkJet Photo Printer
HP 7210 all-in-one is having trouble printing. At best, will print just the first inch or so of the document---at worst, prints only a few symbols at the top, or prints a meaningless barcode-like pattern,...
It was a connectivity problem between the computer and printer. I had recently switched from a direct USB connection to a non-powered USB hub. Apparently, routing through the hub resulted in an inadequate, inconsistent connection between the computer and printer, so print jobs were garbled or only parts of the page were getting printed. Switching the USB cable back to a direct connection between the printer and computer completely resolved the problem.
Dec 02, 2008 | HP Officejet 7210 All-In-One InkJet...
Printer doesn't seem to like my 7 port USB hub
Hi Bob,
A lot of the time devices plugged into a USB hub don't receive enough power to run correctly. One possible solution is to get a dual-input usb cable and try using that. These cables connect to a usb device and then have two jacks for plugging into ports, which may supply enough power. You should be able to find them online fairly cheaply, so if you can spare 2 spots in the usb hub that may be your best bet.
Feb 14, 2008 | HP LaserJet 2200 Printer
Brother HL-2040 Laser Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
