I have sound and no picture
I have a Toshiba projection Television, model number 50A61 - serical number 56643576. I have no picture but I have sound and everything else seems to be working properly. I was watching it and the screen just went blank as if it is not on yet the sound and power indicators are fine.
  • 110 Answers
These unit will mute the video for a number of reasons. F889, F890, F891, F850, F470 one of these fuses is open then fine out what caused the fuse to open. This an older unit so parts may be hard to find. The cost to repair it should not be to bad.
Posted on May 14, 2009
I have a toshiba 50a61 projection tv, it shows the menu and comes on but does not show a picture or sound.
I highly recommend you call a technician before you hurt yourself or cause more damage to the TV
Dec 08, 2014 | Toshiba 50A61 50" Rear Projection...
I have a toshiba 50a61 tv sound no picture
Hi ogmrwizzard,
This is an indication of faulty lamp.
First check the lamp connectors, pull-out, inspect the connectors and then re-insert and ensure its connection from the ballast board. If the symptoms still persist, you must replaced the lamp to back the picture again.
Hope I helped you.
Thanks for using Fixya.
Jdvillanueva
Jun 04, 2011 | Toshiba 50A61 50" Rear Projection...
Toshiba 50A61 have sound but no picture
Make sure correctly hooked up in back of TV. Then in menu go to audio and be shure that speakers are set to ON. Most TV's you can turn the speakers on and off in the audio menu. If they are still off you might have bad speakers and need to replace them.
Mar 12, 2011 | Toshiba 50A61 50" Rear Projection...
No picture or sound.
http://www.vancebaldwin.com/models/?TBA53AX61
Part Number Decription 23236623 #T461 FLYBACK TFB3086AD 24083013 #Z401 NOTE **SEE 50A61 FOR MAIN PARTS LIST ** 23549258 BEZEL 23427995 DOOR 23905094 IC STK392110 23311899 LENTICULAR SCREEN 23405040 MIRROR 23565302A OWNERS MANUAL 23311859 PROTECTIVE SCREEN 23306370 REMOTE 23311892 SCREEN FRESNEL CDSMPJTV03 SERVICE MANUAL (CD) 23527210 SPEAKER GRILLE
Feb 03, 2008 | Toshiba 53AX61 53" Rear Projection...
Toshiba 53AX61 w/ cracked screen
Lenticular = 23311899 $82.00 NLA
Fresnel = 23311892 $111.00
Protector = 23311859 $82.00
Andrews Electronics, Fox, Herman Electronics
........................................T.
Dec 14, 2007 | Toshiba 53AX61 53" Rear Projection...
Remote Control will not work.
You mean fix the remote - - not worth the cost...
Replace it with a miracle remote http://www.miracleremote.com/
Far less than replacing it with the original and it works everything including access to the service menus.. We have several here in the shop for the various brands and we do have the Toshiba.. It is everyhting it says it is...
Bill
Dec 01, 2007 | Toshiba 50A61 50" Rear Projection...
Toshiba 50A61..power comes on but no picture or sound
There are fuses in this unit, one could be blown there are also capacitors and a regulator that could be at fault I would suggest U find a repair man in your area if possible to go thru this unit find the fault and repair. It would cost less than to repair than buying a new one.
Jun 16, 2007 | Toshiba 50A61 50" Rear Projection...
Color problem with Toshiba
Sounds like a problem with convergence, poss just requires new STK 392-110 ICs , may need a couple of resistors that go due to faulty ICs
Nov 02, 2006 | Toshiba 50A61 50" Rear Projection...
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
Electro Med Services...
