Question about Maytag MZD2766GES Side by Side Refrigerator
Older maytag fridge side by side.
Water leaks from under neath, what appears to be a breather line or a drain line. It's a plastic line that is attached to the bottom of fridge. There are no other leaks just at this spot. and is wrecking our wood floor. Iam thinking of plugging the line off. It fill a butter container about every week.
  • 331 Answers
Re: older maytag fridge side by side.
Buk, there's supposed to be a drain pan under your fridge to catch the water that comes from the drain tube. The water that's coming out is supposed to be there (only, it's supposed to be caught by the drain pan)... it's the water that's made when your fridge defrosts itself. If you plug the tube, the water will back up inside the fridge , puddle up in the bottom and eventually leak out through the door.
You should order a drain pan for it. Here's a link to one online. After you have it in place, you won't have to worry about it anymore. The water that collects there will simply evaporate back into the air.
Posted on Oct 15, 2007
0 characters
3 Points
Water keeps leakingon floor from under neath
check drain pan..... also make sure water not comingfrom inside fridge
Aug 31, 2014 | Maytag MSD2456G Side by Side Refrigerator
Leaking under neath front of refrigerator
Usually any defrost water sits in a plastic pan and evaporates away in normal operation. If the pan becomes brittle it cracks and leaks water. Pull the fridge out and look on top of the black pot (compressor) Is there a plastic drain pan sat on top of it?
Sometimes if the fridge is working hard a lump of ice can form on the pipework going back to the compressor which melts causing some water at the front of the fridge.
Lastly, the insulation under the fridge may have broken down, allowing condensation to form and drip. If the drain was blocked, the water would be inside the fridge, not underneath.
Apr 20, 2012 | Kenmore Refrigerators
Maytag mbf2258xeq leaks but it's not connected to a water line. Where's the water coming from?
water is coming from condensation from the compressor coil. usually this will evaporate fast enough to not puddle on the floor. check the plastic line running down the back of the fridge to see that it's not broken or pulled out. while you have the fridge out, clean the coil by blowing it out with compressed air and clean the pan under the compressor as best you can. Hope this helps
Nov 30, 2011 | Maytag MBF2258XEW
Have side by side 10 years leaking water on floor in front of refrigerator there is no water connected to refrigerator, cant find an overflow pan under neath...
clogged drain causing the water that cant reach the drain pan underneath to leak on the floor. Unplug fridge and open doors for 24 to melt ice likely clogging up drain. If that doesnt fix, you'll need to call refrigerator repair service
Jul 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool gold refrigerator leaking under neath on the side
If its leaking all the time you could have a problem with the water supply line (if it has an icemaker)Or the solenoid valve (water valve) that opens to refill the icemaker after it drops (harvests) the ice.Or the plastic water lines that run from the valve up to the icemaker.You should pull the frig out from the wall and check the back for leaks.You could also Just shut off the water supply to the unit and see if it stops.These leeks cause a lot of damage when they go unnoticed for a long time.I would check it out asap.
Jun 03, 2010 | Whirlpool ET1MHKXM Top Freezer...
It is leaking water out of the bottom. It does not appear to be coming from inside the fridge or freezer. It does start on the bottom on the freezer side.
Without seeing your refrigerator I can only imagine that you have a drain pan leak below refrigerator, defrost condensate drain line loose or missing the drain pan, frozen over drain opening inside rear wall of freezer or the defrost condensate line is blocked somewhere along its route to the condensate collection tray below refrigerator.
Apr 09, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water pooling under right front of refrigerator
is there any ice on freezer floor or is the bottom rack iced in?if so you have a blocked drain in the freezer,or if that's ok you could have a crack in one of the plastic water lines,also check the catch pan where the water drains into when the fridge defrosts,you can pour water down the drain in the freezer to check that,roll the fridge forward and take the bottom panel off the back,should be easier to check for leaks and take off the front kick panel,while you're in there vac out all the dust in there,front and back,you should do this every 6 months
Jan 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
no water will be coming from that line it is going to be a blocked drain line or a rust hole under where you can't see
Apr 17, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Water leaking from under fridge
Check to see if you have a crack in the water line running to the ice maker. The plastic line is prone to crack. Easy way to see if water is from ice maker is to shut off water to it (usually under sink).
Dec 15, 2008 | Refrigerators
Maytag MZD2766GES Side by Side Refrigerator Logo
264 people viewed this question
Top Maytag Refrigerators Experts
Richard Roth
Richard Roth
Michael Thomas
Michael Thomas
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
