First make sure the gas is fresh and mixed properly with a high grade oil ( I use gold spectra). If the spark plug is not new replace it and check to ensure there is good spark. if this does not resolve the issue the problem may be a pinhole in the fuel line (very common) or within the carburetor itself. If you are mechanically savvy remove the cover, remove the carb and disassemble by removing the fuel pump (4 tiny screws and the bowl (one large screw). Clush the carb with a spray can of solvent after removing the fuel pump and gasket and the float bowl gasket, if you have a compressor blow some air through the passages. Re-assemble the carb and see if that works.
