Question about Fujitsu fi-5120C
Out of paper :CDT009 Load mroe paper to continue scanning
          I installed FI 5120 Image scanner and when I scan document , after completion of scanning ( 1 or more pages) system always gives error like Out of paper , CDT009 Load mroe paper to continue scanning ...How I do resolve this issue.
Thanks
Vasu
  • Anonymous Mar 16, 2014
    when i try to start the scanner it becomes the warming up but at the end it gives error and green light near the paper image is flashing
    after the warming up it gives an error and the green light near the paper image is flashing
  • 78 Answers
On the admin utility go to the errors tab and remove the out of paper action, return error
the disadvantage of that is you have to click on the scan icon to start scanning.
Posted on Oct 15, 2007
SOURCE:
5650c not scanned. making paper jam. rollers replaced. making big noise.document page stop halfway through
PDF]fi-5650C Image Scanner Operator's Guide P3PC ... - Fujitsu
www.fujitsu.com/downloads/.../scanners/.../fi-5650c_ops-guide.pd...
FujitsuThank you for purchasing the fi-5650C fi-5650C duplex color scanner product. ... 6.1 Removing jammed documents ..... store where you purchased the scanner or an authorized FUJITSU Image Scanner service provider to make repairs to this .... It is adjusted to the width of the paper in order not to scanned skewed pages. 5.
Okidata User's Guide OKIFAX 5650 Error Messagesmy.okidata.com/man-OF5650.../006B738F6240C3BF8525678500678C...Make sure a new drum is available, and replace the drum ... to be faxed or scanned hasjammed in the scanner. Refer to the "Problem Solving, Clearing aTroubleshooting - Oki Printing Solutions in New Zealandwww.oki.co.nz/support/printer/.../index.aspxOki Electric Industry... MB491 ES4191. FAQ: Paper Jam Clearing MB451 MB471 MB491 ES4191 ...MC361 MC362 MC561 MC562 How to setup scan to email. Open the attached ..... Can I disable Colour Copying and make only B+W Copying available? No, it not possible to disable Color Mode when copying via the Scanner Operator Panel.
Jan 29, 2016 | Office Equipment & Supplies
Fi-6130z continueously scans. It doesn recognize when there is no paper to be scanned
Your scanner went crazy. If you don't want to take it to repair, just disconnet it after you've finised scanning
Oct 09, 2014 | Fujitsu fi-6130z - Document scanner -...
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
I need to copy a word document however when I scan it, it makes it into a jpg document. What can do I fix this in order to be able to edit and save the scanned document as a word document?
Make sure you installed the full software suite for your scanner. Scanners do scan to image files but should come bundled with Optical Character Recognition (OCR) software. Select the OCR option in your scanner settings and it will convert your scans to an editable format. Take note, OCR software is only as good as the scan, and the content on the paper, so it might make some mistakes, in which you will have to manually fix in Word etc "proofing"...
Regards, Chris
Jun 29, 2011 | Fujitsu fi-6130 Flatbed Scanner
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
Hello, I work for a doctor's office and we scan a lot of documents. Lately we are getting a code ds42003 on a fijitsu scanner, what should i do this code is on the fi-4010cu, we also have a fi-5120c...
it is logical that in an office where document scanning is important and vital, you would call in the service technicians to fix it so that the interruption is minimal
Nov 28, 2017 | Fujitsu fi-5120C
How do I set up my scanner to scan multiple pages at once, without having to keep hitting the scan button. ( fi-6140 )
Hi, are you using Scannedallpro software? If so, press the batch scan setting button (2nd right after the white drop down menu). This will give you access to your settings. Select add, name your new profile appropriately, then select SCAN, Click SHOW CONFIRMATION WHEN NO PAPER IN ADF, then click on Detail Scanner Settings. This will take you to your options screen. Select either Duplex, for double sided or ADF Front side for single sided. You can choose to drop out blanks by clicking on the OPTION button at the bottoms of the screen, then JOB/CACHE, click the selection button for Blank Page Skip and choose the sensitivity. (I usually use a low setting). Click OK.
when happy with your settings click OK again, then apply.
Use your new profile to batch scan. The system will scan until the hopper is empty and should ask if you want to continue with the same batch scan, allowing you to add paper until the job is complete.
NB Always ensure you have selected Multi Page Tagged Image File Format as the system will not save your scan as one document without it.
Hope this helps!
Nov 10, 2010 | Fujitsu fi-5120C
I want to scan a doucument on the PIXMA MP500.
You must have got a CD with the printer. Just install it and load the paper in the scanner and press the scan button on the front panel. It automatically starts to scan and shows you the document. Later it will ask you whether to save it as a JPG file (as image) or a PDF file (document).
Dec 10, 2009 | Canon Pixma MP500 All-In-One InkJet...
No image after scanning
The paper sensor must be checked. Check if there is a speck of paper stuck inside the sensor. Blow with a vacuum cleaner.
S. Mohan
Sep 30, 2009 | Canon DR-2050C Path-Through Scanner
Scanning document
i had the same thing happen to me i went threw every thing and cleaned and still was there i came to realize that it wasnt the scanner but the software pdf that was being used the seriously took me by surprise so i went out and installed a fresh copy of pdf writer this resolved my problem with the pink markings
i hope this was of some use
Apr 24, 2008 | Fujitsu fi-5120C
Fujitsu fi-5120C Logo
4,872 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Vincent G
Vincent G
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
