Question about HP PSC 950 All-In-One InkJet Printer
HP2110 all-in-one. Cannot escape out of the align cartridges.
After installing the new blk. cartridge and hitting enter, the printer prints out the instruction sheet and then prints the pattern page.as usual. I then put pattern sheet in scanner as directed and press enter when prompted. It just continually tells me it is aligning over and over and over. If I hit cancel it keeps telling me over and over than the Pen Alignment is being cancelled but it never cancels. I uninstalled the program and re-installed it but to no avail.
I have never had a problem with this printer before. Can you help?
Thank You
  • 4 Answers
SOURCE: align cartridges
Cerfer39-YOU ROCK!
I was ready to go buy another printer and found your solution. Worked BEAUTIFULLY!
THANKS A MILLION for saving me the cost of a new printer!
*Tip-I always mark the date on the side of the ink cartridge(s) when installing them so I know how long it takes to use them up.
My black ink cartridge installed it in March 07'. It said it was 50% full, but I could hardly read the font. I guess they dry up if you don't use them within a year.
Posted on Jan 04, 2008
Inkworks
  • 87 Answers
SOURCE: alignment cartridge
Here's the deal with the cartridge alignment page....the machine will spit out a series of black lines mixed with yellow ink and at the beginning of each of these lines is a "Green" check mark. The carriage moves back and forth over these lines and green check marks and reads them by use of what is called a "spot sensor" that resides on the right side of the carriage assembly. This is usually noticed by the blue ray of light that shines out of it. So if you are getting an alignment failure one of two things is happening....1)You've have got a bad cartridge (usually the color) and it is not laying down the right colors, specifically the green check mark or 2)You've got a bad spot sensor...even though it may still be shining the blue light, the sensor board can't process the information. Its an easy fix either way.
Inkworks
Posted on May 22, 2008
SOURCE: alignment failure
try to hit set up button then hit opions button to by pass error message
Posted on Oct 18, 2008
  • 990 Answers
SOURCE: Keep getting message Press Enter to Align Cartridges
after each alignment you press enter key or start key not cancel key,
Posted on Dec 13, 2008
  • 2692 Answers
SOURCE: Changed the cartridge, Printer says "alignment cancelled"
Try doing the whole process over. Reinstall the old empty cartriage, Get the empty messsage then change it again with the new one.
Posted on Dec 22, 2008
The alignment both vertical and horizontal are off!
Title: How to Install/Change the Print Cartridge Document ID:HO46 Back To Answers Properties 1000 Color Jetprinter 1100 Color Jetprinter 2030 Color Jetprinter 2050 Color Jetprinter 2070 Color Jetprinter 3000 Color Jetprinter 3200 Color Jetprinter 5000 Color Jetprinter 5700 Color Jetprinter 5770 Photo Jetprinter 7000 Color Jetprinter 7200 Color Jetprinter Lexmark X63 Lexmark X73 Lexmark X83 Lexmark X84 Lexmark X85 Mac OS 8.6 Mac OS 9.x.x WinWriter 100 WinWriter 150c Z11 Color Jetprinter Z12 Color Jetprinter Z22 Color Jetprinter Z25 Color Jetprinter Z31 Color Jetprinter Z32 Color Jetprinter Z34 Color Jetprinter Z35 Color Jetprinter Z42 Color Jetprinter Z45 Color Jetprinter Z45se Color Jetprinter Z51 Color Jetprinter Z52 Color Jetprinter Z65 Color JetprinterHow to install or change the print cartridge; Microsoft Windows 95; Microsoft Windows Me; Microsoft Windows 3.1x
Solution Microsoft Windows 95/98/Me:
(Applies to all printers)
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Dec 16, 2009 | Lexmark JetPrinter Z11 InkJet Color...
I just installed a new color cartridge in my 8650 Lexmark printer. The ink cartridge acts as if it is empty. Printer keeps telling me to align cargridge. Worked perfectly before the new ink installed. Not...
  1. On your computer, go to "Start," "Programs," "Lexmark Series." Click "Lexmark Control Program."
  2. Step 2 Select the "Cartridges" tab. Click "Change Cartridges." The Change Cartridges screen appears, displaying the animated instructions for installing or changing cartridges. When you have finished viewing the animation, click the "Finished" button.
  3. Step 3 Remove the tape covering the print head of the new print cartridge. Insert the new print cartridge as shown in the animation.
  4. Step 4 When the "Choose Cartridges" screen appears, select the cartridge(s) you installed in your printer from the list boxes. Click the appropriate box to reset the ink levels to full. Click "OK."
  5. Step 5 The Automatic Alignment screen appears. Click "Align" to align the print cartridges for best print quality. The printer prints a page with a bi-directional alignment pattern. On the printed test page, locate the number that comes closest to forming a straight line under the bi-directional alignment pattern. Enter that number as the bi-directional alignment setting in the Alignment Cartridge dialog box. Click "OK."
Nov 25, 2009 | Lexmark All-in-One Printer with PictBridge
How do I align ink jets?
      3. Click OK.
Nov 13, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Hp officejet 6110 not printing. Can't get out of "align cartridge"mode.
printer problem call up hp at 1-800-474-6836 and ask them for an upgraded printer which you will get at 50-60% cheaper than the original and its a factory new printer.But it is definitly not free.
What you have right now is a hardware problem and the printer is dying so change it fast while this offer is available
May 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Printer keeps showing : Press enter to align cartridges. After doing this it then prints out an alignment page and shows: Alignment failed please: Press enter Alignment failed. This goes on and on. I have...
I have found that if I put in an old aligned page the printer reads it as and the alignment is accepted. As for the cancelled message being in the window, I have had this problem too. I've ignored it and selected the copy button and it took the command. The only problem with hitting cancel is that you cannot turn off your printer. Every time you do you have to repeat the aligning and cancellation process.
May 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Cartridge alignment
Put a teeny tiny bit of oil (3 in one on fingertip) all over the slide (chrome bar that you see looking into the printer from the front) and retry. Just a thin film, NOT enough to drip.
The self test and align 'scan and print' procedure is timing out.
Mar 27, 2009 | HP PSC 2175 All-In-One InkJet Printer
How to change lexmark Cartridge
      3. Click OK.
Dec 09, 2008 | Lexmark X1150 All-In-One InkJet Printer
I have replaced both my color and black cartrigages for my x2500 printer, restarted the computer, and it is still giving me an empty cartrigage message
is this a pc or mac?
for windows general make sure you folowed these steps:
      3. Click OK.
Dec 01, 2008 | Lexmark Office Equipment & Supplies
Align page message
I have an OfficeJet 5780 and I have to do the alignment also. The allignment page it prints should have instructions on it. Just put it in the scanner and press "Enter". It needs to scan it to align the print heads.
This is from the manual on their website:
The HP Officejet prompts you to align cartridges every time you install or
replace a print cartridge. Aligning the cartridges ensures high-quality output.
To align the print cartridges when prompted:
1 Press Enter on the front panel.
An align cartridges (test pattern) page prints.
2 Load the align cartridges page face down in the ADF between the paperwidth
guides and press the Enter button again.
3 Recycle or discard the page.
Geno
Feb 21, 2008 | HP Officejet 4110 All-In-One InkJet...
Alignment after new cartridge
Hi I think that you will need to clean the gold dots on the printer carriage or if not done so remove the blue tape from the cartridge or if you are trying to use refills install some originals as this may help.
Hope this helps'
Please rate me
Cheers J
Dec 30, 2007 | Apple HP Officejet G85xi InkJet Printer
HP PSC 950 All-In-One InkJet Printer Logo
109 people viewed this question
Seeker5211
Seeker5211
