Question about Whirlpool DU1055XTSQ Built-in Dishwasher
Water leak at heater element connection seal, rusted connection
I have major corrosion on the red wire connector to the post that connects the heating element. The sleeve of the molded plastic tub where the connection is made has melted slightly.
The is where the heating element passes through the unit and connects to the electrical lead (the one with the red wire). You can see where the water is dripping from inside the clear plastic sleeve that goes over the connection post.
These seems like a manufacturing defect, likely a faulty seal?
What can I use to seal from the inside of the tub so it does not leak any more? Silicon?
  • Official Brand Answer
  • 362 Answers
Mlecha, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Mlecha), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Posted on Apr 25, 2017
catriver
  • 878 Answers
SOURCE: small plastic top and mid spray arm do not turn, bottom does
decrete, you want to get down to the chopper and screen. If the screen is plugged up with gunk there won't be enough pressure to reach the top spray arms. Check out the posted pics. Remove the lower spray arm. Rotate the rear feed arm to the right until it unsnaps from the tube going up the back. See the 4 torq screws holding the filter on. Remove them. Lift the filter up. Now you will see the chopper inlet cover. 1 torq screw holding it in. Lift it up and there's the chopper and screen. Catriver..post back
Posted on Apr 09, 2007
SOURCE: Water Leak
is the pump gray or white? if it is gray then replace it.look where the pump mounts to the ,otor and see if there is a black line coming from the middle.this is probably where your leak is.
just change the pump.
Posted on Nov 05, 2008
aborcass
  • 2651 Answers
SOURCE: water leaking from water output at top of washer
soundsas if you have a faulty, inlet water valve. your model is notshowing up on my part look ups, but definatly replace the valve( your water hoses are connected to it. in mean time make sure to turn off water inbetween loads
Posted on Dec 11, 2008
jumptrout51
  • 3361 Answers
SOURCE: Cold water hose or seal leak inside machine leaks into basin
Replace the water inlet valve. That is where the hoses connect.
Here is a link to show you how to access the inside of the washer..
Posted on Mar 24, 2009
SOURCE: Stays in wash cycle Whirlpool Dishwasher Du1050SS
my repairman contacted whirlpool about my washing machine staying on
wash.. to his surprise.. and mine.. and his co=workers.. this is the answer,
it worked.. and we have never heard this before.
In your original istallation booklet it tells you to let the dishwasher run til its complete
the first time you use it as it may rinse twice... my original installation man told me this also.
however.. if you suffer a "blip" in your electricity.. it could put the little dishwasher "brain"
out of whack.. it can run as long as 3 to 4 hours on wash to reset itself.. if you stop it
(like others have mentioned.. and which I did also).. it doesn't complete the reset and it
will attempt to do it the next time..
answer?.. just let it go once as unnerving as this is.. it works.. They did mention that
if it went to 5 hours.. call your repairman because you need a new mechanism.
karen in Dothan
Posted on Apr 03, 2009
Red wire connect
Water heater elements have two screws and wires can connect to either screw.
Copy following link if you are rewiring thermostats:
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Jun 09, 2012 | Hardware & Accessories
My water heater is leaking and only 4 years old. Will the use of a water softener void the warranty?
The warranty should not be void by using water softener, BUT read product manual.
http://waterheatertimer.org/Water-heater-manufacturers.html
1) First thing: Why is water heater leaking? Where is the leak?
http://waterheatertimer.org/Leaking-water-heater.html
For example, if you have electric water heater leaking from element, then replace element.
Replace leaking TP valve.
If water is leaking down vent pipe, and combustion chamber rusted out, then vent problem must be corrected.
These are not covered by warranty.
If tank is rusted out, then read below.
2) If water heater is rusted out after 4 years, you might have stray current corrosion.
This happens when hot and cold pipes are not connected together with a ground wire, and/or if cold water pipe is not grounded to earth.
This might not be covered by warranty.
3) Read water heater instruction manual for advisories.
Tanks rust out when anode rod is depleted. Softened water depletes anode rod faster.
Instruction manual says to check anode rod each year.
Checking anode rod is like checking oil on an engine. If oil was never checked and engine burned up, the manufacturer will not honor the warranty.
If anode rod is depleted, and tank is rusted out, the warranty might not cover the rusted tank since owner was supposed to check for anode depletion.
4) Anode rods can also be covered with calcium deposits and stop working.
This night not have anything to do with water softener, but anode stops working and tanks rusts out.
In any case the owner's manual probably says to check anode rod to prevent leaking from rusted tank
http://waterheatertimer.org/Replace-anode-rod.html
Sep 07, 2011 | Water Heaters
I have a hot water heater model # EES 52917. It is 8 years old. The tank has rusted around the top heating element. Why has this happened and what can be done about this issue. From what I understand...
AO Smith is biggest manufacturer and ships about 140,000 units per month sold under different brands. Look at rating on tank. Is it a 9 year tank? Or 6 year? Or lifetime?
Number of factors can cause rust around element:
1) Element is seeping moisture: check and replace element.
Elements can start leaking any time
http://waterheatertimer.org/Water-heater-is-leaking.html
2) Anode rod can be depleted from variety of factors including water softener or calcification over anode so it will not work: Check and replace anode rod every 1-2 years with water softener, every 3-5 without water softener. New anode rod will STOP the rust, but will not repair tank that is rusted.
Tanks with longer warranties have 2 anode rods, one on hot water nipple, the other on top of tank.
3) Stray current corrosion: add a jumper wire between hot and cold pipes, and make sure tank is grounded. If there is stray current, it will deplete steel in tank if tank is not grounded.
For example one fellow had a tank that rusted out every few years until he discovered his big radio antenna was grounded back to hot water pipe and the tank was not grounded, so the interference depleted his tank.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#Ground-tank
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 23, 2011 | Water Heaters
My water heater is leaking a lot. water comes from the down bellow. It started like three months ago but it is getting worst Do I need to replace it? how much it will cost a similar one?
It sounds like you need to replace it, Actual cost can very widrly depending on your location but I would say $350-400 is probably close. Plus installation unless you can do it yourself. Hope this helps. Thanks
Nov 23, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
Sep 18, 2010 | Whirlpool Water Heaters
I took the wires of the thermostat and heating coil and cannot remember how they go back on. I need a wiring diagram to put them back on properly
if you look at the connectors the wires that connect to the heater are larger and the wire is thicker,it doesn't matter what wire goes where on them,also the heater wires should be red and the other is red with a white stripe and like i said it doesn't matter what post on the heating element the wire with the stripe or the solid red wire connects to.the same with the thermostat
May 31, 2010 | Dryers
How hard is it to change the flaper that lets the heat come in the vents. the shop said the flapper is stuck. the blower blows but it will not heat. heater coil is good. how hard is it to take dash out.
Check the flapper actuating mechanism is working ok. The flapper vane may be seized up due to water/corrosion etc.
If it is lever / cable actuated, the mechanism may be seized up due dirt/rust/corrosion.
Application of WD40 (or similar) may free up the jambed lever/cable mechanism or flapper vane.
If vacuum activated, check vacuum servo and connections for air leaks etc.
Hopefully the above checks/lubrication can be performed without removing major dash components.
Jan 16, 2010 | 1999 Jeep Grand Cherokee
Water heater keeps popin the breaker replaces breaker still no good. new heater just installed all wires are good
I assume this is a 240 volt water heater that runs on a 30 amp circuit. Read the instructions that came with the new water heater to be sure. If the wires are connected correctly then you have a defective water heater. Let's first make sure it is wired correctly. Turn the breaker off and take a look at it. It must be a 30 Amp breaker and the wires going to the water heater must be 10/2 with ground. This is an orange wire. If you cannot see the water heater from the service panel it must be wired to a disconnect box. Look at the breaker and make sure the red & black wires are tightly connected to the double pole breaker and the copper wire is connected to the ground bar. At the disconnect box (if applicable) the red/black wires from the service panel must be connect to LINE and ground to ground bar. The wire going to the water heater from the disconnect box is connected to LOAD. It is easy to get these mixed up because they are not always in the same location and are hard to read on some disconnect boxes. Look carefully and make sure they are correct. At the water heater you connect Black to Black and Red to Red. Make sure the ground is connected tightly and none of the wires are touching each other. Use wire nuts and then tape the connections with electrical tape. You should not have applied power to the water heater until it was full of water. If you did then your burnt out the electrodes. I would suspect you have a short somewhere or the water heater is defective.
Dec 10, 2009 | Cars & Trucks
My Magnifica is also leaking.
In mine i have exaclty the same problem. To fix you have to chnage the special red orings (hight temperature silicone orings) in the heater block. But if you try to search this seals will be impossible. So you have like me change all the heating block. Becaiuse the rust in my magnifica destroyed the metal support. Costs approx 49 $.
Jul 07, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
COFFEE MAKER LEAKS CLEAR WATER FROM THE BOTTOM EVERY TIME I USE T
Have the same issue, looking for my receipt for warranty. All of us having this problem can't be wrong and it must be defective
Dec 30, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Whirlpool DU1055XTSQ Built-in Dishwasher Logo
212 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
