Question about Dryers
Squeaks and sqeals during dry cycle
Hello, I have a Maytag Stackable unit model number MUE2000AYW, The dryer squeaks during the whole cycle. Is there a solution to my problem?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Lubricate the contact points, pulleys , change the felt seal .
Get a new dryer, abot time?
Vitally
Posted on May 15, 2009
Maytag dryer model number LDE840ACE squeaks during the drying cycle
That is probably a Wheel. More likely the wheel over the heater. I recently worked on one of these and posted a pictorial:
My Maytag dryer repairs
Jun 20, 2012 | Maytag Dryers
Maytag Neptune Stackable washer/dryer will only wash one cycle at a time unless I manually move dial to next setting...also will not spin as of this morning. Model # MUE2000AYW thx
The timer motor is bad, you can order a new one at reliableparts.com , using your model number. For information on how to perform your repair please reply and i will be happy to help.
Thanks, Repairman45
Dec 19, 2010 | Maytag Washing Machines
I have a maytag dryer model MDE3757AYW that is making a loud squeaking/sqealing noise. the drum still turns and dries the clothes though.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 02, 2010 | Maytag Dryers
Squeak
check what is called an idler or tension pully. lubricating these can somestimes help but only a temporary fix. actualy its not a fix. only makes it quiet. replace them or call service these parts are easily accessable
Apr 25, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag dryer squeaks during cycle
How do you replace the glides/slides? I have a Maytag dryer that's squeaking, took off front and it's clear it's the glides. Found where to buy them just need directions for replacing. Anyone know how?
To change the glides you have someone lift the drum--after taking off the front panel--and pull out the glides. We bought the glides locally and just ordered on line the felt pads that go under the glides, as one was missing. So I haven't actually completed the project but should easily be able to once the felt pads arrive.
Mar 23, 2009 | Maytag PYE2300AY Electric Dryer
Dryer is warm but not hot
Is the model number listed here or can you find the complete model number? May need cycling thermostat or gas valve solenoids. Let me know if I can help, Sea Breeze
Mar 22, 2009 | Maytag MDG16PD Gas Commercial Dryer
Squeaking Kenmore Stackable Dryer
Your rear drum bearing has worn through the plastic and is now hitting the metal support underneath it,
soon it will act like a guillotine and slice of the ball, the drum will fall backwards into the heating element and short to ground causing the fuse to blow the heater element to burn intwo and the whole thang will be dead in the water.
Mar 07, 2009 | Kenmore Dryers
Irregular squeaking from stackable dryer
Post your make and model please. Sounds like the rear drum bearing is dried up
Feb 20, 2009 | Frigidaire FEQ332E Electric Dryer
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
216 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
