Question about Amana AFD2535DES French Door Refrigerator
Freezer Door handle came off after 1 yr.
Our French door freezer door handle has slowly been loosening. There were no screws visible to tighten, so I couldn't do much about it. Today the handle popped off. Nothing is broken in the handle but the clips in the handle are loose.  I can tighten them, but am not sure how the handle is reattached.
Can you help?
Thanks,
Joe
  • jps-jr Oct 18, 2007
    Thanks. The clips had actually come loose but were still attached to the handle. I tightened them, then slid the handle on as you suggested.
I had this problem with the bottom freezer door of my Amana.
What I did was slide off the entire door handle by applying pressure pushing toward the right to get the handle off. Once the handle was off, I slid the clip (which was still clipped on to the door) off and screwed it back on to the handle. Once the clip was tightly secured to the back side of the handle, I carefully slid the handle bar back on to the door by sliding it to the left back on to the door clips until it clicked securely back into place.
Posted on Mar 28, 2008
  • 473 Answers
There should be screws in the clips to tighten and then put the handle back on to the bolts on the door thru the big holes in the handle clips and slide the handle the opposite way very hard to lock it in.
Posted on Oct 18, 2007
How to remove the bottom freezer door handle on Samsung French door refrigerator model # RF26XAERS
The screw heads may be inside the door cavity, screwed into the back of the handles.
If this is the case, as with our Fridge-Master fridge/freezer, it is very difficult, needing strip down of door.
Good luck... :)
Jun 06, 2018 | Samsung Refrigerators
How do I reattach handle on freezer door pull that has come unscrewed on French Samsung refrig
Many times the handle is slid on from one side or the other onto the screws. Try sliding the handle off by gently putting a screwdriver or putty knofe under the handle on the side that is still attached and pushing the handle sideways. This should remove the handle so you can remove the mounting screw and get it back on the door. then you can slide the door handle back on after getting the screw attached on the door again.
Oct 04, 2014 | Samsung RF265AA Bottom Freezer French Door...
How can I get my freezer door handle to stay on?
If the screws are still good, put some "lock tight" on them and tighten. This should fix the problem
Jun 17, 2014 | Amana AFD2535DEW - 25 cu. ft. French Door...
I have a 2006 kenmore elite trio refridgerator wirh french doors and bottom freezer. on of the door handles is loose. what tool do i use to tighten handle. each handle has a screw at top and bottom. The...
There is two allen set screws for each hand at both end and they are facing each other on the handles.. Remove the allen screw and put a very minute speck of jelly on each screw---small-small amount. This will kept the set screws from loosen up. GB...stewbison
Aug 31, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
Bottom freezer pull out door handle is loose. How do I tighten it?
if there are no visible hanlde screws( sometimes tiny allen wrenches under handle VERY SMALL).. if not the the handly merely pulls off to the left, and then the mounting hardware can be tightendd ad refit by sliding back to the right
Oct 13, 2010 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
How to remove the door handles
Looh up under the top and bottom of the handles and there are small allen set screws. Loosen these and slide the handle to the side and it will come off.
Dec 15, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Loose freezer door handle
There is a "set screw" on the underside of the posts that connect the handle to the mounting posts on the face of the door of my Jenn-Air bottom freezer. Use an Allen wrench to loosen the set crew, which is very small (my Jenn-Air requires a 3/32" Allen wrench), and then tighten the bolt on the mounting post on the face of the freezer door. Position the handle over the post, then tighten the set screws with the Allen wrench. Cynthia
Jul 21, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
The door handle on the freezer of my GE Profile Bottom Freezer Refrigerator came off.
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Jul 11, 2009 | General Electric Profile PFSS2MIXSS...
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Amana AFD2535DES French Door Refrigerator Logo
2,110 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
