Question about Pentax Optio S5n Digital Camera
Powers up but does not stay on
On switch on the lens comes out then after about 1 second the green light around the ON button lights up then 4 bleeps and switch off.
  • 2 more comments
  • Bassa Oct 16, 2007
    tried a new battery and also with mains cable .
  • Bassa Oct 19, 2007
    I think the 4 bleeps indicate a switch off signal as there is a different bleeping at switch on.
    Sorry if this confused the issue
  • Bassa Oct 21, 2007
    what can i do to check/fix this suggestion?
  • Bassa Oct 22, 2007
    anyone any answers
    Novelist:
  • 198 Answers
Hello Bassa,
This error code you receive indicates a lens assembly failure when syncronising the inner lens in order to achieve autofocus. The camera detected that the lens are improperly alligned and everytime it starts it will check again to see if the problem has been resolved. If not it will prevent you to take pictures because if the lens are unaligned they can damage themselves or other components when trying to achieve autofocus when taking pictures. This is a protection feature. A "do it yourself" solution is veeery out of the question here (i'm sorry for that) because the lens assembly is a very delicated mechanism. Sometimes service centers use microscopes or very small tools when handling parts of the lens assembly and the calibration of the lens focal distances is made using special devices. If someone or some other peoples from other forums instruct you to try pulling the lens out, or applying pressure on them, please do not to it. Altrough it may present a small chance of realigning a loose component in the lens mechanism, in most cases it will damage the small servomotors inside or the inner mechanism. The best course of action would be to try sending it to a service center to have it diagnosticated there. Ask them to give you a price estimation before they repair something, there may be a chance the lens assembly is damaged beyound repair (and furthermore very few service centers will even fully dissasemble a lens mechanism, even just to look at it not to mention repairs).
I'm not in here for ratings, but i should do my job and tell you what i think is the right course of action.
Posted on Oct 23, 2007
    President:
  • 317 Answers
It's because you've been photographing too much porn.
Posted on Oct 19, 2007
  • 363 Answers
I should imagine the 4 bleeps indicate an error message. Does your manual describe the error bleeps?
Posted on Oct 16, 2007
  • Martin B
    Martin B Oct 19, 2007
    This could be a problem with the lens position switch or the lens is not able to fully come out due to debris/bodily fluids etc.
    If the lens comes out and the switch is not activated within the second or two, it will assume it is jammed or think something is obstructing it.
  • Martin B
    Martin B Oct 21, 2007
    Keen to help you here.
    Did this fault just start happening and can you remember what you did just before it started.
    Heres a few things I'd like you to try if you haven't already.
    Remove the battery for a few minutes then replace and try powering up.
    Try starting it in playback mode (play and power together I think) to see if it stays on.
    Plug it into a PC and check if you can copy files.
    Let me know as much info as you can
  • 790 Answers
Check the battery maybe you have defective battery!
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
When i turn my ps3 on the green light comes on turns yellow then turns off which it then has a flashing red light how do i fix this problem?
hello try a reset press and hold the standby button on the front of the ps3, you hear 1 bleep the 2 short bleeps after the short bleeps release the button it should reset good luck
regards
shaun
Oct 01, 2010 | Sony Playstation 3 (PS3) Console
My playstation turns on but nothing happens after that. There is no display or sound output. It will not turn off, gibving two beeps if you try to shut it down. The hard drive light comes on for about...
hello try resetting it turn the ps3 on then press and hold the standby button you should hear 1 bleep then 2 short bleeps after the short bleeps release the button it should reset it self
regards
shaun
Aug 30, 2010 | Sony Playstation 3 (PS3) Console
Monitor turns on and screen comes up for about 1 second and then turns black. Green power light stays on and green
This will be a fault with the inverter section that powers the ccfl lights usually a transistor or an i.c replaced will cure the problem
Dec 22, 2009 | Compaq FP 7317 17" LCD Monitor
The lens on my L730 digital camera does not open.
Hi, I had exact the same problem with mine Samsung L730. I opened it and took the 2 flatcables from the circuit board (to the lens-unit) out of there connectors. After I put them back in again, the camera worked. I geuss it was a bad electric connection of the lens-unit. Maybe this will solve your problem. If the camera is older than 1 year and has no warrenty, just try this. Good luck.
May 23, 2009 | Samsung Digimax L730 Digital Camera
Switches on & bleeps
try to check the cable connection between the monitor and the tower. what is the color of the LED light on the monitor?
Oct 27, 2008 | Dell Dimension 3100 PC Desktop
Camera powers off after seconds
Make sure that batteries are fresh and battery compartment is clean.
Mar 16, 2008 | Samsung Digimax S500 Digital Camera
Pentax Optio S5n Digital Camera Logo
109 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
