Question about Kenmore Kitchen Ranges
Replace orifice spuds on gas gooktop, from Natural to LP
Kenmore 36" gas cooktop Model #911.33213101 I have purchased the required replacement LP gas orifice spuds. It appears that the burner bases can not be removed from the top, they are held in by the ignitors. I do not see any access to change the orifice spuds from the top. Before I remove the cooktop and disassemble it from the bottom, am I missing something ? What is the correct procedure. Thanks, Jerry
4 Suggested Answers
SOURCE: Converting Kenmore gas range to LP???
I had success with the conversion. The directions are very cryptic, but it can be done, without the professional emptying your wallet, for 5 minutes worth of work. No adjustments needed on the air shutters, once they are wide open. The orifices are the pain-in-the-a$$es. You need some small tools to get to them, or chance dropping them under the top....which wasn't fun. Oh...and watch which orifice goes where...there are 3 sizes. So, short version, change orifices, open shutters, and flip regulator setting from NG to LG. Orifices take the longest time. ~ sjDIY
Posted on Oct 31, 2008
MNTECH
  • 1543 Answers
SOURCE: Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Posted on Jan 06, 2009
  • 4 Answers
I just converted mine and the regulator plug was not the same as the one in the manual. It had a black plastic piece snapped into the cap that had to be turned over for LP. I unsnapped it and turned it over. I changed the nipples for the burners and they worked great. The oven orifice had to be turned all the way down (clockwise) ans the air damper opened.
When I did all this the oven still had a large yellow and blue flame. I raised the oven orifice up 2 turns and then turned it down all the way and the oven flame was perfect! The oven orifice is hard to turn so make sure that you turn it all the way down using a 1/2 inch wrench.
Posted on Dec 07, 2010
Conversion of Kenmore Elite Gas Range 790.7523 from Natural gas to propane.
each burner has a natural gas jet or (orifice) as you pull them out, one atb a time. You should be able to color coordinate them at that point. the jets will be at the end of each gas line right before the burner. and each burner gets one. I haven't seen the model you are referring to. but the ones i have changed out in the past, usually the hole is the same size for all the burners no matter the size of the burners. I hope this helps. good luck with it!
Jun 17, 2015 | Kenmore Kitchen Ranges
The regulator seems to be closing off completely, and not flowing gas (LPG). We have converted cooktop from natural gas to propane per instructions manual -- changed orifice spuds, converted regulator and...
I HATE TO TRY AND EXPLANE THIS FOR FEAR SOME THING MAY GO WRONG DID YOU FOLLOW THE INSTRUCTIONS TO THE LETTER. FROM NATURAL GAS TO LP YOU SHOULD OF HAD TO CHANGE THE POSISTION OF THE ORVICE IN THE REGULATER THAT IS WHY YOU ARN'T GETTING THRU THE REGULATOR CHECK YOUR DIRECTIONS AGAIN SOME TIME YOU HAVE TO THIGHTEN THE NUT ON THE REGULATOR SO IT DISTORTS THE ORFICE TO LP, AND SOME MODELS YOU HAVE TO TURN THE ORFICE OVER. BECAREFUL AND TRY AGAIN
Feb 06, 2011 | Maytag MGC5430 Gas Cooktop
How do i convert to lp
Contact the manufacturer to get an orifice kit...you will need to replace the orifice's to convert to lp
Jan 15, 2011 | Whirlpool 36 in.GLT3657 Gas Cooktop
HOW TO CONVERT FROM NATURAL GAS T PROPANE
Their are 2 types of ranges. Ones with sealed burners and ones that do not have sealed burners. The sealed burner ranges must have a kit to replace the orifices. The none seal burner models are simply called crank down and flip models. That means you flip the screw on top of the regulator to where it reads LP. and then you tighten down the spuds on the top burners and the oven valve and then you adjust the air shutters.
Note: Some stoves with sealed burners cannot be converted to LP. The model number you posted is not a correct model number.
Nov 19, 2010 | Kenmore 72002 / 72004 Kitchen Range
Natural gas to lp conversion kit for a Thermador GGNCV30 cooktop
Your LP gas provider will get the orifices for you just call them with the model number of your thermador. They have gotten them for me many times.
May 07, 2009 | Thermador SGS36GS Gas Cooktop
Natural gas orifice burners
Before you get too involved, check to see if the natural gas orifices are still with the range. Usually, when the conversion is done, the person who converts the range puts the original natural gas orifices into the holder which contained the LP ones, then replaces it. Look for an inch and a half long metal strip holding the four brass orifices held on by one screw very near the range gas regulator. (the regulator is the part the gas line connects to on the range) Also, look for the conversion instructions in the original installation and set up instructions, or attached to a sheet of paper on the back of the range. You will need to change the plunger in the regulator (Unscrew the cap, flip the plunger around, and replace) and turn the orifice spud on the bake and broiler burners three full turns counter-clockwise also. (using a 1/2 inch open end wrench, counting twelve 1/4 turns) Orifices will require a 7mm or 9/32 inch nut driver or socket to change. The orifices are different for the simmer, regular, and high output burners. (have a "I", "II" and "III" marked on them to help identify them, respectively.) The left two burners are both "regular output" burners, and use the same orifices.
Apr 20, 2009 | GE Kitchen Ranges
Converting stovetop from natural gas to lp
there is a square nut on top of the regulator un screw it and underneath you will find a Cly flip that over should take care of it one side will say ( nat) the other will say( lp) you want lp up
Feb 25, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Convert to LP (propane)
Contact Miele directly via their website. This would require an orifice change if it is possible for this appliance. Since natural gas, butane, and propane are all forms of LP (Liquified Petroleum), it is usually, but not always, possible.
Oct 15, 2007 | Miele 35 in. KM326G Gas Cooktop
Sep 30, 2007 | Kitchen Ranges
Can't boil water on new Maytag Gas Cooktop
No adjustments.  You will need the correct orifices.  Contact maytag to get the correct ones.  They should send them to you for free.
Nov 18, 2006 | Maytag MGC6536 Gas Cooktop
Kitchen Ranges Logo
517 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
