Question about Dell Wireless Keyboard Optical Mouse w0147
Voltage on Acer Aspire One -110 - 220?
I want to buy the Acer Aspire One from the States but I will be using it in Zambia which has the same voltage as the UK. I need to know if the Acer Aspire One from the States is 110-220 ie I won't need to use a converter.
  • Dell Master
  • 4,338 Answers
It is 100 - 240 V.
All you needs is the Votage adapter, no converter needed.
Acer Aspire one rating 11.1V laptop battery. Charger Specs: Input Voltage: 100 ~ 240V AC 0.24~0.60A 50/60Hz Output Voltage: +12.6V DC Output...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 15, 2009
Can I use a 19V, 4.74A ac adapter for my acer aspire 5602WLMi, for which its battery is 10.8 V 4000mAhr.?
Before you plug the adapter pls check the voltage of the laptop that it accepts the one that u mentioned is not the voltage that the laptop takes,their is a sticker behind the laptop back which tells you the charger adepter power that the laptop takes i am 100% sure Enjoy!!!!!!!!!!!
Dec 23, 2013 | Acer Aspire 5602WLMi AC Adapter
I neeed a USER Manual for ACER MB.SE109.002 Aspire Desktop Board Motherboard
I believe what you are asking for, is a Motherboard Manual, for the motherboard used in an Acer Aspire M5400 desktop computer,
Not available.
The motherboard is made FOR Acer, by a motherboard manufacturer.
In this case the manufacturer does not supply information.
Acer does.
Motherboard,
http://www.shopping.com/acer-acer-mb-se109-002-aspire-desktop-board-motherboard/info
Specifications,
http://support.acer.com/acerpanam/desktop/2010/acer/Aspire/AspireM5400/AspireM5400sp2.shtml
With the above information you can see;
1) Processor Support.
2) Uses a Socket AM3 processor socket,
http://en.wikipedia.org/wiki/Socket_AM3
[ Look at the list of AMD Phenom II, and Athlon II, processors.
Now look at this chart, {Scroll down},
http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors#Phenom_II_series
Now look at the processor socket used for these processors. Scroll the page down, compare using the charts ]
3) The motherboard chipset is an AMD 880G,
http://en.wikipedia.org/wiki/List_of_AMD_chipsets#A-Link_Express_III
Here you see more information on what the motherboard supports.
4) The Ram Memory used is DDR3 Sdram, at either 1066MegaHertz, or 1333MHz.
(That is PC3-8500, and PC3-10600, respectively)
The Maximum TOTAL Amount for the motherboard is 8GB.
There are 4 Ram Memory slots.
The Maximum Amount for EACH one is 2GB.
NOTE*
O/S = Operating System.
Windows XP, and Windows 7, are two examples of an O/S.
With a 32-bit O/S, the maximum amount of Ram Memory that will be recognized, is 3-1/2 GigaByte. (3.5GB)
You have to have a 64-bit O/S for above 3.5 GB.
(8GB? You need a 64-bit O/S)
ALSO, don't just use any Ol' DDR3 ram memory.
I doubt you can go into BIOS Setup, and change the Voltage, and ram timings, for a high-performance ram memory.
In otherwords 'gamer' ram memory.
JEDEC sets a standard for Ram Memory.
One of the standards is the Voltage. Standard default voltage set for your motherboard by JEDEC, for the Ram Memory, is 1.5 Volts. (DC)
MAXIMUM voltage is 1.575
That Acer board is not capable of handling DDR3 high-performance ram memory, that will exceed 1.5 volts.
(Probably isn't a BIOS upgrade either)
What is it that you seek? Post back in a Comment.
Regards,
joecoolvette
JEDEC,
http://en.wikipedia.org/wiki/JEDEC
May 19, 2012 | Computers & Internet
I have lost my lead to my acer laptop aspire5100 series model number BL51 19v .474Acan you help.I am a mature age person thanking you Pat
There are two solutions to this problem, Pat.
One is to buy the correct AC adapter (Charger) for the laptop.
Two is to buy an aftermarket AC adapter that will work for your laptop, but will also work for many other laptops.
1) http://www.usbphoneworld.com/acer-adapter-19342-65w-lc-adt01-aspire-5520-ac-acer-aspire-5100-ac-adapter.html?CAWELAID=950033775
The above is from a quick search. Your search may be better. Just put Acer Aspire 5100 charger, in your search box.
2) From another quick search,
http://www.atbatt.com/laptop-chargers/b/acer/m/aspire-5100.asp?utm_source=google&utm_medium=ppc&utm_keyword=Acer+Aspire+5100+Charger&utm_content=NAC-X90-22&utm_campaign=google0&gclid=CLeDr7qIlqsCFQ9S7Aodvn_TXA
Would also like to commend you for your intelligence.
Stating the Voltage, 19V, and the Amperage, 4.74A ,is a really intelligent thing to do.
(The charger MUST have 19 Volts for the Voltage. The Amperage (Amp's, or A), can be more)
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 11, 2011 | Acer Aspire 5100 Notebook
WILL NOT CHARGE OR POWER ON
Normal 0 When you connect the power adapter into the laptop, does the power LED light up? If not then -
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Oct 22, 2010 | Acer Aspire 5100 Notebook
I need to replace the AC Adpter. Is the ACER 19 3.42A 5.5X1.5mmB Power Adapter good for the ACER 5520-5334 ?
i use my acer 3680 power on my 5315 check bottom of laptop match up the voltage on laptop to voltage on the charger itself if its the same plug it in.. 1 volt wont matter?
Jan 04, 2010 | Acer Aspire 5520-5908 Notebook
Acer aspire m3201 wont boot up
There are numerous issues that could cause this but if absolutely nothing happens, no lights, no fans, nothing then check the power supply. Use a simple voltage tester to see if you have any voltage on the connectors going to the hard drive and cd/dvd drives. If not this is a pretty easy and relatively inexpensive fix. You can e-mail me at globalmac@yahoo.com for more help.
Jan 02, 2010 | Acer Aspire M3201 Phenom X3 8650 PC...
Can I put a 6 hour battery in my Acer Aspire One Netbook?
Dear Budwatches,
I don't recommend it, but it nice to try as far as the voltage and the current voltage is perfectly match with the acer aspire one. I suggest you to try or buy the asus A1000HE the latest model of netbook from eeePC series, because it garanty you to run the daily computing without AC plug in, that's because this latest model (A1000HE) can spent you awesome 10HOURS battery life>>>
GoodLuck!
Aug 23, 2009 | Acer Computers & Internet
What power connection is needed? I can't find my plug-in, and don't know what wattage/voltage my Acer 3000 lap top takes. Anyone know?
The Acer 3000 uses a 19 Volt 3.42 Amp power supply with a 1.5 mm end on it. You can either check your local Acer supplier, or check the following Amazon webpage=> http://www.amazon.com/Adapter-Power-Supply-Acer-Aspire/dp/B001BP1YVC
Jul 10, 2009 | Acer Aspire 3000 Notebook
Using battery charger with 3.42A vs 4.74A for lap top
YOu can always use higher amps when required but not lower than required. Voltage should stay the same as original charger - keep it in mind.
Mar 02, 2009 | Acer Aspire 5100-3357 Notebook
Dell Wireless Keyboard Optical Mouse w0147 Logo
2,452 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
