Question about Brother IntelliFAX 4100 Laser Fax
KEY PAD ON FAX MACHINE WON'T WORK
WE ARE TRYING TO USE OUR SPEED DIAL NUMBERS AND WHEN YOU HIT A NUMBER OR ANYTHING ON THE KEY PAD ALL IT DOES IT BEEP.
  • Brother Master
  • 1,113 Answers
Have you programmed the  'rapid' (one touch) buttons or the speed dial numbers? (print a report of stored numbers to be sure)
Is machine set to fax mode?
Posted on Oct 16, 2007
SOURCE:
Need to know how to fax from mcf 210c
How to enter Fax mode
Before sending faxes, make sure (Fax) is illuminated in
green. If not, press (Fax) to enter Fax mode. The default
setting is Fax.
How to dial
You can dial in any of the following different ways.
Manual dialing
Press all of the digits of the phone or fax number.
Setup Send
3 - 2 SETUP SEND
Speed-Dialing
Press Search/Speed Dial, #, and then the two digit Speed-Dial
number. (See Storing Speed-Dial numbers on page 5-1.)
Search
You can search for names you have stored in the Speed-Dial
memories. Press Search/Speed Dial and the navigation keys to
search. (See Storing Speed-Dial numbers on page 5-1.)
* To search alphabetically, you can use the dial pad to enter the first
letter of the name you are looking for.
Fax Redial
If you are sending a fax manually and the line is busy, press
Redial/Pause, and then press Black Start or Color Start to try
again. If you want to make a second call to the last number dialed,
you can save time by pressing Redial/Pause and Black Start or
Color Start.
Redial/Pause only works if you dialed from the control panel.
If you are sending a fax automatically and the line is busy, the MFC
will automatically redial one time after five minutes.
If the LCD shows Not Registered when you enter the
Speed-Dial number, a number has not been stored for it.
Color fax transmission
Your MFC can send a color fax to machines that support this feature.
However, color faxes cannot be stored in the memory. When you
send a color fax, the MFC will send it in real time (even if Real Time
TX is set to Off).
Nov 02, 2011 | Brother MFC 210C All-In-One InkJet Printer
I have registered my Brother MFC 9840CDW on the brother website but it still says "not registered" when I try to email a scanned document. I registered it online. Do I have to do anything on the...
If the LCD shows Not Registered when you enter a One-Touch or a Speed-Dial number, it means that an email or number is not stored there.
If you selected E-Mail and save the E-mail address, you can only use the E-mail address when you are in Scan mode. If you selected IFAX and save the E-mail address, you can only use the E-mail address when you are in Fax mode.
Your machine has 20 One-Touch keys where you can store 40 fax or telephone numbers or E-mail addresses for automatic dialing. To access numbers 21 to 40, hold down Shift as you press the One-Touch key
You can dial in any of the following ways.
Manual dialing
Use the dial pad to enter all the digits of the telephone or fax number.
One-touch dialing
Press the One-Touch key that stores the number you want to call. (See Storing one-touch dial numbers on page 60.)
To dial One-Touch numbers 21 to 40, hold down Shift as you press the One-Touch key.
Speed-dialing
Hold down Shift as you press Search/Speed Dial, and then enter the three-digit Speed-Dial number. (See Storing speed-dial numbers on page 61.) Three-digit number
May 17, 2011 | Brother MFC-9840CDW Laser Printer
IntelliFax-4100e
go into menu, arrow over until you see 2. Fax hit set, then arrow until you see 1. one-touch speed dial, then hit set. touch the one-touch button you want to change, then the number 1 to change it, it will display the number, hit clear to delete it then dial the new number hit set and you're done.
Feb 11, 2010 | Brother IntelliFax-4100e Fax
How to specify fax machine to dial '9' before fax number?
Hello ilay,
This procedure is from the Brother FAX-4100e FAQ link:
Storing Speed Dial numbers:
You can store Speed Dial locations on your machine(*). Once you have programmed the Speed Dial number on your machine, you can dial the number by pressing Search/Speed Dial, #(Pound Sign), the Speed Dial number, and then Fax Start.
*The number of locations you can store varies by machines. Please refer to the User's Guide for your machine. The latest User's Guide is available in the Manuals section.
To store Speed Dial numbers follow the steps listed below:
1. Press Menu.
2. Press the left or right arrow key to select Fax and press Set.
3. Press the left or right arrow key to select Set Auto Dial or Set Quick Dial, and press Set.
4. Press the left or right arrow key to select Speed-Dial and press Set.
5. Use the dial pad to enter the location (Speed Dial number) where you wish to store the number and press Set.
6. Enter the number you want to store (up to 20 digits) and press Set.
Note:
If you want to enter a pause in the dialing sequence (to wait for an outside line, for example), press Redial/Pause as you're entering digits. Pressing Redial/Pause enters a 3.5-second pause when the number is dialed, and a dash appears on the screen. If you need a pause longer than 3.5 seconds you can press Redial/Pause as many times as needed.
7. Use the dial pad to enter the name or company name (up to 15 characters) and press Set.
If you want to store the number without a name, just press Set.
8. Return to STEP 5 to store another Speed Dial number or press Stop/Exit to exit the menu.
[Here's the web address for the Brother FAX-4100e FAQ]
http://welcome.solutions.brother.com/BSC/Public/Templates/FaqEndPage.aspx?NRMODE=Published&NRNODEGUID={30FA9470-D303-4B5B-8BDC-89B1CBA491AE}&NRORIGINALURL=%2fBSC%2fpublic%2fus%2fus%2fen%2ffaq%2ffaq%2f000000%2f002000%2f000004%2ffaq002004_010.html%3freg%3dus%26c%3dus%26lang%3den%26prod%3dfax4100_us&NRCACHEHINT=NoModifyGuest&prod=fax4100_us%C2%AE=us&c=us&lang=en#one_7
[Here's a link to the FAX-4100e users guide]
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002079/FAX4100e_UsaEngUsr.pdf
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 10, 2010 | Brother IntelliFax-4100e Fax
I have a Brother IntelliFax-4100e fax that speed dial button 04 needed to be changed when we changed our phone system to include a 9 at the beginning of the number. Did that, it was 'accepted', but still...
go into menu, then to fax (hit set) then one touch speed dials (hit set) then hit the 04 one touch button and it should show you what is programmed. You can hit number 1 to change, type the number with a 9 in front of it(ie. 9+1+area code+7 digit number) then hit set and program a name for the number, hit set until the fax beeps to accept the change. You can test it with a blank cover sheet. That's how I have mine at work set up and it works fine. Hope this helps.
Jan 29, 2010 | Brother IntelliFax-4100e Fax
I need to set up one touch dial fax numbers
This should be what you're looking for:
1 Press Menu/Set, 2, 3, 2.
2 Using the dial pad, enter a three-digit
Speed-Dial location number.
Press Menu/Set.
3 Enter the number (up to 20 digits).
Press Menu/Set.
4 Enter the name up to 15 characters (or
leave it blank).
Press Menu/Set.
5 Press Stop/Exit
Apr 23, 2009 | Brother IntelliFAX 2800 Laser Fax
Fax2900L machine not working according to set user parameters
You have programmed the broadcast with 1 too many numbers using the 10 key method. You wioll have to remove just 1 of the numbers in the broadcast. Not one of the quick dial numbers or one of the speed dial numbers, but one of the numbers you entered using the 10 key pad. I believe the maximum is 10, but you must leave 1 free for the memory to work.
I see that you have programmed 53 numbers for this broadcast. Why not assign speed dial numbers for those that you have used the 10 key pad for?
May 09, 2008 | Ricoh FAX2900L Plain Paper Laser
Need help changing the speed dial ID numbers
In order to change #01 to #21 its best just to program the number into #21 slot and then clear the memory for #1.
Start by trying to store a number at a location already used Press Menu/Set, 2 (Fax), 3 (Set Quick-Dial), 2 (Speed-Dial).
Use the dial pad to select the three-digit location (001 – 200) in which you want to erase the number and press Menu/Set.
The screen displays the name or number currently stored there, then prompts you to either 1. CHANGE or 2. EXIT.
Press the Stop/Exit key when the cursor is to the left of the digits. Everything above and to the right of the cursor is deleted.
Hit he menu/set key.
This should save the speed dial number as a blank.
Apr 29, 2008 | Brother IntelliFax-2820 Laser Fax
Edit number stored in speed dial
all you need to do is push and hold the speed number button that you what to chang till it starts blinking in the display. i think the name comes up 1st. press enter if that's o.k. ore use the courser to delete. if you have pressed enter then the number show-es up press the arrow key back to erase @ enter the correct numbers. hit enter key. if you git in to something you don't know press the stop key 2 times will git you back to main screen
Apr 11, 2008 | Samsung SF-560 Plain Paper Laser Fax
How do I set up speed dial
Lift up the cover over the key pad and the is a key marked data registration. push it then push the set key. using the arrow keys scroll down to set up machine then push set, and find the speed dial feature again push set enter your number push set and go on to the next one. Good luck it is kind of confusing
Jun 14, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
158 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
