Question about Mitsubishi WS-55909 55" Rear Projection Television
46 Inch Mitsubishi PRoj. TV. 7 years old. Starting to randomly lose Cable signal, than come back up after a few seconds. No predictable time of the day or duration. Any pointers will be appreciated.
  • rasdes00 May 14, 2009
    Thanks for you pointers. I will try the VCR solution and see if it works. Chaning the input to Channel A or Chanel B makes no difference.
    President:
  • 788 Answers
Most likely the set is loosing the ability to tune channels. The tuner will need to be replaced. If you have a cable box set up or even a VCR you can use that for your tuning and use the television as a monitor and use the video inputs on the back of the set. They are the Yellow, White and Red connections. You may also be able to use Ant-B, as it has a separate tuner.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for your support
Posted on May 14, 2009
My mitsubishi WD73640 keeps randomly losing it's source signal, the tv will go black,then hdmi window will appear then all will restore
Check the HDMI cable make sure it is fully seated or better yet get another one. You can get them on eBay for a few $'s
Nov 25, 2016 | Mitsubishi WD-73640 73-Inch 1080p...
Samsung tv repair
I was a Samsung Tech for over 3 years, I would take it apart and look for loose connections to the panel. If that does not work, you will have to start out with smaller parts. In my opinion its the main board. Whats the model number?
May 04, 2016 | Samsung Un46eh5300 46 Inch 60hz Led Hdtv
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
New 46 inch flat panel TV. After the TV has been on for a couple of hours the picture goes out but the sound continues. Anyone have this issue before?
Yes,the causes is the tv Tuner signal board have a short in it some kinds.That the board,where the incomming tv broadcasting signal cable plug.New tv under a year old,call for warrenty or newer than that take back where u buy it and exchange for another tv.
Dec 28, 2010 | Televison & Video
Have a 2 yr old 46" Sony LCD. No picture at start up.
It may just need time to warm up. Try starting it up and waiting around for the picture to show.
Jun 04, 2010 | Sony BRAVIA KDL-46WL140 46 in. LCD TV
Vizio 32 inch hdtv, Motorola DVR box...Whenever I turn the tv off, the cable connection is lost and I have to unplug/replug the DVR box when I want to watch the cable again. It's not the box, because I...
Here a way,u could test,if it the cable signal,tv Main tuner board have problem or the DVR box again.U have analog antena?Or go and a buy a digital antena.Reset ur tv to free air signal and use it for few hours,turn it off/on and see if u losing signal,require unplug,replug to get signal back.Two problems solved ur tv board or cable signal good or not?Than U know it the DVR box and have connecting problems.
Mar 19, 2010 | Vizio VW32L 32 in. LCD HDTV
Mitsubishi WT-46807 Bottom of picture cut off
YOU HAVE A VERTICAL DEFLECTION PROBLEM, THE RETURN CAP IS DRYING OUT AND MUST BE REPLACED
Dec 27, 2009 | Mitsubishi WT-46807 46" Rear Projection...
65" Mitsubishi Projection Television keeps flashing black screen
check your closed caption, long time ago there were 4 cc options. Turn it completely off, that might get rid of it.
Jul 18, 2009 | Televison & Video
My tv is 6 mos. old. 46" mitsubishi. vertical lines on flat panel. mitsubishi impossible to deal with. won't honor warranty without sales receipt.
THIS IS A KNOWN ISSUE UNFORTUNATELY WITH SOME 46 INCH MODELS OF MITSUBISHI. YOUR LCD PANEL (MOST MAJOR PART IN TV) IS DEFECTIVE AND SHOULD BE WARRANTIED FOR ABOUT 2 YEARS.
IT MAY BE ONE OF THE REASONS THEY ARE RESISTING...OOPS I MEAN REQUIRING PROOF OF PURCHASE. IT IS A KNOWN ISSUE I HAVE SEEN A NUMBER OF TIMES NOW.
HOPE THIS HELPS
Jul 07, 2009 | Televison & Video
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
Open Questions:
Mitsubishi 55" big screen TV powers down after 70 secs We had a power outage in the neighborhood, after which our Mitsubishi 1080 HDTV WS-55909 only had a blinking green light on the front (no variation or pattern), even after the set was powered down. Upon reading online, it appeared the DM module capacitors were the likely culprit, so I sourced (7)1000 microfarad capacitors and replaced them, then reassembled the TV. This was the first time I'd soldered on a circuit board, so of course a lot of things might have gone wrong. However, after that the TV now powers up, but I only have a blue screen and cannot get the remote to work except to power the TV on and off (tried changing batteries in remote, reprogramming remote per setup manual, etc). Further, the TV powers off after 1 min and 15-20 seconds. I then tried to see if I could get any of the attached devices to work on their own with no other devices on except the TV. Each of them yielded a blue screen (X-Box, VCR/DVD recorder, Wii, cable) except the DVD player -- which displayed a great picture! The problem is the DVD will play 1 min 15 seconds then the TV will shut down and the green light will blink steadily (no pattern) for 60 seconds, then power down. And this only works if the DVD is on before the TV is turned on, and since the remote doesn't work I have to press "play" on the DVD player. The DVD is hooked to Component Input 2 so that input appears to be working fine. The VCR/DVD recorder is attached to Component Input 1. When I had it powered up and turned on the TV, I got a blue screen. However, when I left the VCR/DVD on and then turned on the DVD, there were jagged lines on the TV for 3-5 seconds, then the TV made a popping sound and shut off. When I then turned on the TV (i.e., with both the VCR/DVD and the DVD on first), the DVD worked but could not switch to the VCR/DVD without the TV turning off. I also tried switching the cabling for the DVD to Component Input 1, but the DVD no longer worked. When I tried the VCR/DVD on Component Input 2, it still only yielded a blue screen. So is Component Input 1 bad? And why would the TV work with the DVD in Component Input 2 but not the VCR/DVD? Obviously I have multiple problems here. The first one to deal with is the TV shutting off after 1.25 minutes. I am unable to see where I can get an error code when the blinking light just blinks quickly without any pattern, and neither the front panel controls nor the remote control work. Perhaps most of my inputs on the rear of the TV don't work now except Component Input 2 but I don't know how to test this. So I made a little headway with the capacitor replacements, but not sure what I can do at this point. Any suggestions? I've seen references for other Mitsubishi big screens that shut down like this, and the fix was related to the output power module, but not sure if it applies the the WS-55909. Thanks in advance for any help you can provide. estout7
Jun 28, 2012 | Mitsubishi WS-55909 55" Rear Projection...
See all Mitsubishi WS-55909 55" Rear Projection Television Questions
Mitsubishi WS-55909 55" Rear Projection Television Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
