Question about Samsung RB2155SH Bottom Freezer Refrigerator
Freezer keeps buzzing
Frigedaire side by side ultra ice freezer keeps buzzing
    Sergeant:
    Champion:
  • 214 Answers
Don't worry! its the sound of compressor vibration and it is normal........if the sound is more than turn round the refrigerator and tight the nuts of the compressor stand......................have a nice day:-)
Posted on May 14, 2009
Possible reasons why my freezer stops working then is again up and running - this is a Frigedaire professional series side by side stainles
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 26, 2011 | Frigidaire Refrigerators
Door seal on my Frigedaire sise by side gets hot, what is wrong?
I had this once with a Fridigare GLRS267ZAQ4 side by side but it was also heating up water and the freezer wasn't working very well.
My problem was that the coils and condenser in the back bottom of this unit needed a major cleaning and the fan wasn't working very well. Cheap to buy that part and replace yourself. This problem was causing this unit to heat up everywhere because the coils and compressor were not being cooled properly.
I have often found this unit to get ice build up in the back inside wall and had to take a hair dryer to it in order to melt the ice. This mostly caused problems with the ice dispenser and freezer getting warm.
Right now I am having a problem with my refrigerator not cooling well but the freezer is fine. Guess I'll try to defrost the ice and check the coils again.
Hope this helps!
Kyle
Dec 15, 2010 | Frigidaire FRS3R5EMB Side by Side...
Hi, we just purchased an 5 year old GE profile refrigerator with full door/bottom freezer from a private party. It was working fine at his house. The refrigerator has a loud buzzing every 1/2 for a few...
The buzz is most likely coming from the water valve that feeds the ice maker. If the ice maker is not being used the buzz will continue unless the power is disconnected to the valve. It does not hurt anything but can be annoying.
If the ice maker does not have the shut off handle (arm) to lift then a solution would be to unplug the ice maker itself. If you look at the ice maker in the freezer it is usually held on by 3 screws to the side wall. If you remove these screws there will be a wire plug that you can unplug and remove the entire ice maker and free up room. With it disconnected the buzz will stop.
Apr 18, 2010 | GE Profile Stainless Bottom-Freezer...
Traulsen Ultra freezer quit and right wall is leaking water--why?
The fridge is twenty eight years old and not worth putting another dime into it. A fridge that old will just keep dimeing you to *****.
Mar 06, 2017 | Traulsen Refrigeration 48'' Wide x 24''...
My kenmore elite side by side is making a buzzing
The buzzing noise is likely coming from the main power board and will need to be replaced.
Nov 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
Icemaker has to be manually turned off
frigidaire has 2 diff i/m units if you have the one that has the i/m along the left hand wall of the freezer then probably you have a broken shutoff cam in the ice maker. solution is replace the i/m
if you have teh model with the icemaker along the back wall. over production of ice is nature of the beast and not really anything you can do about it.
i know neither is solution is great but i hope it helps peyton
Jan 18, 2009 | Kenmore 73503 Stainless Steel Bottom...
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
Frigedair refrigator
My GE Side by Side refrigerator is about ten years old. the refrigerator side stopped working and is warm. The ice box side is cool but is not as cold as it usually operates.
Nov 07, 2007 | Whirlpool GD5SHAX Side by Side...
Samsung RB2155SH Bottom Freezer Refrigerator Logo
290 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
