SOURCE: How do I check washer specs?
They made this model apparently between 2002 to 2004, it is specified as 10kg capacity. If you end up getting it then here are some parts diagrams for the model that may come in handy; http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LAT9704AGE&mfgModelNum=LAT9704AGE&fkMfgID=1 I'm afraid i have had no luck with a manual, but this link shows an auction of one near you from a couple of weeks ago - you may get an idea of what people think and what it's worth http://www.trademe.co.nz/Home-living/Laundry/Washing-machines-dryers/auction-90916298.htm Maytag appliances are normally above average in quality, found nothing specific about particular faults with the model which probably means it is pretty reliable. You could also ask maytag - they may be helpful - please let us know the results if you try them; http://www.maytag.com/support/contact_us.jsp Hope this helps :)
SOURCE: Torn bellow on Maytag front load washer
there is a spring style clamp holding it to the front panel simply peel back slightly and "pop" it off, then holding it to the inner tub is a screw style clamp, depending on yr of production, either a 5/32 scrwe or a phillips, holding it in the 2 oclock position, release clamp andreinstall boot, it might take some time to get to fit backaround hte tub but itll bo, you gotta walk it on in spots ( like changing a tireon the bikes as a kid) itlll strectch over the rim and fit, just have to work it
SOURCE: maytag lat8840baw washing machine.
my maytag lat8840 will not fill with water on any cycle...wants to spin and rinse when I turn it to those points
SOURCE: Maytag Neptune FAV6800AW Top Loading Washer Noise
Hello gwatson01,
Wondering if you could rate my clarification request as a solution? I joined this forum as a owner DIY’er to help other owners. The machine is just too expensive to junk and as you found fairly easy to work on. As a forum member as you I receive no compensation for my support to other owners. Thank you in advance for your support. Rich
My solution;
I’m an owner/DIY’er of the machine. Please take a look at this post and see if your mechanical noise may be coming from underneath the tumblers, maybe some coins grinding around under the tumblers. If you think it is take a look at the service manual link in that post. It will take you thru the tumbler removal process, see if you feel comfortable with the process, the manual does not call out a #20 Torx driver is required to remove the tumbler.
If you think the grinding noise is very metallic and not muffled by a tub of water the grinding noise may be coming from the transmission/clutch area and removing the machine front vertical cover will be necessary to better sound isolate the suspect area of the machine. Do you feel OK to remove the front panel? If so see this post.
The 1st link I sent you to shows that this owner had issues after the coin removal. I would also like you try a Spin Only cycle with no clothes in the wash basket. Can you let me know if that cycle runs with no noise? We can’t totally rule out an issue with the clutch/transmission components with the info supplied so far. To help you remotely diagnose this issue detail information is needed. Let’s try to sound isolate the grinding noise source location. Follow all safety rules in the Service Manual. If you don’t feel comfortable to proceed I would recommend you call in a qualified FAV6800AWW repair service for support.
SOURCE: Top loading maytag washer leaking water during wash cycle
Hi, There are two spring clips located in the gap between the top and front panel. They are the edges.
If the pump and hoses aare ok, fill the washer with water and look up toward the center of the tub abd transmission area. It migth have a seal going bad.
I hope this helps.
Vic
