Question about Sony Car Audio & Video
Brake light stays on 2003 beetle and brake not on
The brake light comes on and beeps all the time on 2003 volkswagon convertible new beetle and the brake is not pulled on.
  • 34 Answers
Sounds that u are low on brake fluid. but if u are low on brake fluid u might want to check your brake pads as well cause the might be abit wore aswell or the second poilbilty is a prob with your hand brake light switch with is a botton jst under the hand brake
Posted on May 24, 2009
    Problem Solver:
  • 11 Answers
It sounds like a bad relay, underneath your dash on the drivers side there is a set of relay switchs. One is relay 173 (running light/brake light relay). My car never came with one which is werid because its required, idk it was missing and my break light would come on and flash and beep. Once i replace the relay it stopped and worked fine after that. idk if you experience the same problem.
Posted on May 16, 2009
Red blinking oil signal on a 2003 volkswagon beetle gls 2d means
OIL PRESSURE SWITCH FAULTY.U MIGHT NEED TO REPLACE THIS FIRST..
Feb 23, 2015 | 2003 Volkswagen New Beetle Convertible
My 99 vw beetle keeps making beeping sounds at random and constantly for no apperent reason and the abs light also appears or stays on for extended amounts of time (not related to the random beeping) any...
check make sure alternator charging battery if alternator fails volts out put 11.0 volts that will set off abs light, if alternator okay have vechicle abs brake system scanned at the volkswagon dealership.if abs light flashing while in motion could have faulty wheel speed sensor.
Sep 18, 2012 | Cars & Trucks
How do you replace the brake light on a 2003 volkswagon
Open the trunk, push back the carpet in the area of the tail light. You will find 2 or 3 black plastic wing nuts. Take these nuts loose and remove the whole light assy. from its bay. Once out remove the wiring harness by twisting the plug 1/4 turn to access the bulbs.
Apr 29, 2011 | 2003 Volkswagen New Beetle Convertible
How do I reset the computer on a 2003 VW beetle after I change the oil
you cant reset the computer unless you go to a volkswagon dealer they plug in the computer and that turns out the light, i had the same ploblem
Dec 19, 2009 | 2003 Volkswagen New Beetle Convertible
ABS Light Stays on new brakes put on
Could be dirty abs sensors attached to your brakes. I would clean them with brake parts or elecronical cleaner.
Other possibility is a faulty ABS system.
May 22, 2009 | 2003 Volkswagen New Beetle Convertible
Pulsing brake pedal
Sounds too me as if your rotors need to be replaced or turned if possible
Apr 29, 2009 | 2003 Volkswagen New Beetle Convertible
How do I change the brake light bulb on a 2005 volkswagon beetle turbo? Thank you.
generally talking you open up the boot and pull the boot lining from the area of the brake light and you should find a connector that just unscrews in the brake light sector then just replace the bulb hope this helps
Mar 12, 2009 | 2005 Volkswagen New Beetle Convertible
Headlight adjustment 2003 volkswagon Beetle Convertable
i have come across this problem before;but at this minute i just cant recall?but the light fitting slides out of the wing towards the front;like a long tube.open your bonnet pull back the carpet against the wing in the in-side see if you can detect a screwloosen and pull light fitting forward.hope this helps.adrian
Feb 25, 2009 | 2003 Volkswagen New Beetle Convertible
Air bag light will not go off
There is an alert concerning the air bags. Contact the dealer.
Nov 28, 2008 | 2004 Volkswagen New Beetle Convertible
2003 volkswagen beetle
Faulty Brake Light Switch, see dealer for recall information, common problem on VW's
May 15, 2008 | 2003 Volkswagen New Beetle Convertible
Car Audio & Video Logo
134 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
