Question about Gateway FPD2275W LCD Monitor
Power outage,monitor wont power up,hope its not fried
I have a gateway monitor hd 2100,we had a power outage today,when i tried to power the monitor up,it powers up but goes in i guess sleep mode,no picture nothing,is there a restet switch,gateway support wants money!!!!,can someone help me i paid alot of money for this thing its only 2 years old.i tried every thing,
  • Gateway Master
  • 5,660 Answers
I may or may not make your day. (But I wish you to know that I want to! lol!)
I believe it's not your monitor, I believe it's your computer. (Oh, that helped, huh!) However, don't freak out yet, it maybe a simple fix.
Let's test my theory. (I'm a computer tech with over 20 years of experience)
1.Do you have another monitor available for a test? Plug it into your computer, see if it comes on.
No can do? How about taking your monitor over to a friends, or relatives house, and see if they will let you plug it into their computer for a test. Even if your monitor should be bad, it absolutely won't hurt their computer.
2.Your monitor checks out okay on someone else's computer?
Or, another known, good, monitor, doesn't work on your computer?
Your power supply isn't any good on your computer.
The power outage is also referred to as a 'Brownout'. Too much electricity was needed, and the power utility service couldn't handle the load, or a transformer down the line, blew.
This causes a voltage spike. The first hardware component in a computer that is affected, is the power supply.
Your computer may seem like it's coming on. Lights light, fans spin, and it sounds like the harddrive is whirring away!
Not so! Inside your computer power supply are Electrolytic Capacitors. These are used as Filters. They filter the incoming AC electricity, and filter the outgoing DC electricity.
These capacitors are the weakest link of a power supply. (Next is the Rectifier bridge, then the transformer. IF this SMPS power supply uses a transformer)
When these capacitors start to fail, they are weak. For simplicities sake, let's just say they are small aluminum 'cans', and have Electrolytic paste inside. When the capacitor starts to fail, the Electrolytic paste develops a gas inside. (Hydrogen gas) This gas expands, and pushes on a seal inside the capacitor 'can'. When the seal is broken, Electrolytic paste starts to ooze out. So much paste loss, and the capacitor operates in a weakened state. Too much paste loss, and the capacitor fails.
The capacitors used in the output stage of the power supply, filter DC electricity. They convert 'raw' DC electricity, into 'true' DC electricity.
Inside your computer is a processor. This hardware component must have a steady, true, clean, supply of DC electricity, ot it won't turn on. (Sometimes it may turn on for a few seconds, but will turn right back off)
ALL the lights for your computer use less than 1 Watt of DC electricity.
EACH fan uses 2 to 3 Watts. The harddrive spinning uses less than 5 Watts.
A typical processor uses 55 to 125 Watts!
Your power supply has enough power for everything else, but when it comes time to turn on the processor, it 'falls on it's knees'.
No processor, No computer. No computer running, the monitor doesn't get a signal, and stays in the power saver mode.
(No processor running, also means the harddrive isn't activated to find the Boot Sector. It just sits there and spins the platters inside)
Solution? Buy a decent, affordable power supply, and replace the one you have.
Your Gateway tower probably has a 305 Watt power supply.
It's an ATX style of power supply. The type used in about 90 percent of computers. These are Cheap, and easily replaced.
Examples:
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1077&name=300-Watt-Plus-Power-Supply& (I suggest the Ultra brand. It also has a lifetime warranty)
To replace:
1.http://www.fonerbooks.com/r_power.htm
2.http://www.videojug.com/film/how-to-install-or-change-my-computers-power-supply
Before you do, however, there is one more thing I would like you to check, first. Check the Electrolytic Capacitors on the motherboard.
Specifically the ones that surround the processor. These 'Caps' are Voltage Regulators for the processor. IF even ONE is bad, the processor won't work.
This link takes you to a website, that shows you photos of visual signs of failure, with the capacitors on the motherboard,
http://www.capacitorlab.com/visible-failures/index.htm
FIRST, computer unplugged from power, computer case open. Touch the metal frame of the computer case, to relieve your body of static electricity.
Posted on May 14, 2009
I figure I need a replacement graphics card. The PC worked fine yesterday. Turned it on today and no signal to monitor. Tried both DVI and HDMI with the same result. Monitor is Gateway LP2417.
try pulling the power cord out of the monitor and then wait 30 seconds and pull it back in to monitor . Are you dealing with a graphics card or a motherboard video chip. May have DVI and HDMI plugged into motherboard rather than PCI video card. Check Bios to see if conflict exists between motherboard video chip and PCI video card.
Dec 31, 2015 | Gateway GM5632E 2.4ghz Core 2 Quad 3GB Ram...
Gateway dx 4320 wont turn on
It could be a few things:
a faulty power switch - you say that you've changed the PSU, but did that include the switch?
it could also be a Faulty Motherboard or CPU. If either of them are fried, you won't see anything come on either.
I'd suggest checking the switch first because that's the cheapest and easiest to replace
Sep 14, 2012 | Gateway DX432019 PC Desktop
Samsung hdtv how to know if lightning fried it
If the tv will not turn on it is safe to assume that the electrical storm did damage something in your television.
Jul 11, 2012 | Samsung 46 UN46D6000 LCD TV
I don't see a volume button on the gateway hd 2100 monitor. Is there a way to turn up the volume without having an attachment?
use your operating system volume controles or possably your keyboard has a volume control on it.
Jan 16, 2011 | Gateway FPD2275W LCD Monitor
We experienced a power outage today, our Gateway GT5408 was in Stand-by mode when it happened. After our power was restored, our computer will turn on with the cooling fans running and the leds light up,...
It could be the monitor died or the monitor cable is loose at one of the ends ( check both ends are connected and tight ).
try another monitor or if you have a newer TV with a vga monitor connector try your TV. (you will need to change the TV input to computer or to VGA )
Sep 09, 2010 | Gateway GT5408 PC Desktop
Gateway EzeTune
Exact same thing happened to me and gateway technical support are clueless. Try this fix:
Unplug the power at the back
wait 1 minute
hold down the power button and at the same time plug back in the power cord at the back
keep the power button pressed for 15 seconds.
Jan 12, 2010 | Gateway 19" Widescreen Flat Panel TFT LCD...
GATEWAY 2275 LCD MONITOR WENT OUT, WHEN PLUGGED
This could be due to a bad power supply inside the monitor witch is replaceable for like $25 bucks all you got to do is unscrew off the back undo a few cables and put in the new supply.
I hope this helps you in the repaire process if its under warrenty please seek warrenty guidlines.
Jul 17, 2009 | Gateway FPD2275W LCD Monitor
S-video input from Panasonic MD830 S-VHS to Gateway 2100 monitor causes monitor to intermittently project signal or turn off. Will a S-video to VGA converter solve this problem or is there a problem witth...
It seems the the monitor is not supporting the resolution you have selected in display settings of operating system. therefore please minimize the resolution of display then check your monitor. hopefully it will work
Apr 08, 2009 | Gateway E-2100-V2 (E2100V2-D) PC Desktop
Envision Monitor doesn't turn on.
monitor has sustained damage from the power fluctuation's from the outage I would report it to your power company they are obligated to replace any damaged equipment that may be damaged because of their failure to provide non outage service and then go take the monitor to a repair center they can determine if the boards internally were hit with a power spike and damaged, meanwhile while you send the report to the power company you can either buy a new one and then submit the price for refund from the power company
May 01, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
460 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
