TV picture and sound goes off--leaving a blinking green light showing as on (power). Several times in the last week I have shut the power strip off and then on again and the TV went back on with the solid green light for power. TV is plugged into power strip due to build in unit cabinet, but that is not the issue since it has worked for several years that way and this issue has only come about in the last 2 weeks. TV unit is about 4 years old. Ideas?
  • 19,396 Answers
If TV goes off and the led stays blinking, that is because the TV is going on protection.
Protection is a special diagnostic mode that starts when an internal fault has been detected.
If this happens erratically while you are watching TV, then parts that can commonly cause the problem are PSU board, main board or digital board, ballast board and converge board on DLP, inverter on LCD, low buffer and sustain boards on plasma.
Posted on May 15, 2009
  • 10,594 Answers
Thats OK, as you said you are able to see Lamp compartment and lamp number that shows its DLP TV that requires Lamp.
There are 4 type of TVs that can be recognize by model number that is it Rear Projection, DLP, Plasma or LCD.
Thanks.
I could not find the model # as the unit is built into a cabinet--can't reach the back. So I got online--and it appears they all have a lamp light that only lasts 3 years--so I ordered the replacement light and hope that is the fix. Was able to see the lamp replacement # as that was in the front base of the unit. Seems like a generic problem to many large LCD TV's.
Hope it works..
Tv does not turn on
If green light flashes more than 8 times, it could be as simple as repairing or replacing the power supply. Unplug the TV ,remove the back. Look for bulged or leaking capacitors on the power supply. Do it yourselfer? only if you have soldering skills, or purchase replacement board. remember, used boards are just as old as your failed board, buy new or rebuilt, Good Luck
Feb 17, 2014 | LG Televison & Video
Tv wont come on
first of all you may unplug about 2 hours and try again as symptom shows some internal overheating or power failure going on
Mar 01, 2008 | RCA HD52W59 HDTV Projection Television
My Projection Tv - when I turn on it turns right back off no picture no sound ? help
To know where the problem is:
when set shuts off and green power light goes off:
On front of set press and hold both the menu and input buttons at same time for at least 5 seconds and release both buttons.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
May 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
LG 47LC7DF Green Light Blinks 16 Times - No Picture or Sound
Well dont keep it on!
By running it after it shutdown and it finally did its last pop that added another $XX to the parts bill.
The control boards (2) have now failed There are burned Capacitors ( pop!) and possibly even a few transistors burned out. This is not a DIY it is a Tech job as once changed these boards require additional tuning of the convergence factor.
Aug 31, 2009 | LG 47LC7DF 47 in. LCD HDTV
Sony kdf60655 green light blinking 37 times and pic goes off/on
I am having the same problem and we purchased the tv new in April of 2005 had the four yr warranty also. That's obviously passed and now we don't know what to do? What did you find out?
May 04, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
