Question about Goldstar Dehumidifiers
Settings what % is proper? Is the larger the number the higher the humidity level?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 75 Answers
As an example, if you want the Humidity % factor to be 50%, 70% or whatever % you want in the space in question to be, set it at whatever % you want the space to be and the humidifier will work until it reaches that setting. It will then shut down until it determines that the humidity has reached a level that requires dehumidifying again. You can set it to run for 2 hours and it then it will shut down for 2 hours, or you can set it to run for 4 hours and then it will shut down for 4 hours. You just have to decide just how humid the area is that you are dealing with.
Go to; www.shopping.com and search for Goldstar Dehumidifiers and you can read comments by others who have purchased this brand. I, myself have one in my celler that has been running for over two years and it has made a world of differance down there.
Good luck. :)
Posted on May 15, 2009
What is a good number setting to set dehumidifier on this spring? Higher number or lower?
You can start at a lower number, and then increase it as the season progresses and gets more humid. One way to adjust is use an inexpensive humidity meter to see how well the unit is working and maintaining your desired level. Many thermometers have a humidity meter included with them. When the meter shows humidity is increasing, you can raise the setting as needed.
May 14, 2015 | Dehumidifiers
Tip
Taking the Confusion Out of Using a Dehumidier
Many consumers are confused about setting the proper levels of humidity on dehumidifier units. And then think something is mechanically wrong with the unit. When in fact, over 70% of the time it operator error. That and a lack of proper routine maintenance are the problem.
The numbers on the LED screen represent the amount of humidity you want to maintain. Not the amount you want to remove. For example: If you set the level at 70%, which is rather high, more than likely the unit may start up momentarily and then shut OFF. That's because the setting is to high. Now, if you set it at 45%, the unit will turn ON and run until either the bucket is full and/or the humidity level has reached 45%.
Here's a good rule of thumb if you use your humidifier year round.
In the Winter you want to maintain a humidity level of 50 to 60%. The moister the air, the more comfortable it will feel. Plus, the humidity helps eliminate static electricity in the air.
Conversely, in the hot, humid Summer months, you want to keep the humidity level as low as possible (35% or less). Also, if you have ceiling fans, using them 24 hours a day, helps to move the air and generate a windchill, which fools your body into thinking it's cooler than what it really is. At the same time, it's saving on energy costs by not having to run your AC as much, because the dehumidifier is removing the humidity.
Just remember, the higher the setting, the higher the humidity level will stay. The lower the setting, the more humidity will be removed and the more comfortable you'll feel in the Summer.
And don't forget Routine Maintenance. Clean the air intake filter regularly. Clean and wipe down the refrigerant coils every 60 days. And don't allow water to remain in the collection bucket to long. As mold can build up in it.
Speaking of which, the water in the bucket, when fresh, is great for watering house plants. Because, when it's fresh, it's distilled water. No chlorine or minerals.
on May 04, 2011 | Maytag M7DH45B2A Dehumidifier
I don't understand how to set my humidifier to run economically and still do it's job.
check manufacturer web site for a manual, most have them available for download
Jul 30, 2014 | Midea MDF1-30AEN3-BA4 Westpointe 30-Pint...
My Haier DE45EAL is difficult to adjust the Humidity How do I do it?
The arrow down button lowers the humidity level to what you want to extract and maintain. The higher settings remove little to know humidity and maintains a higher humidity level.
If you're trying to extract a lot of humidity/condensation, lower it to 35%.
Hope this helped you & thanks for choosing FixYa
Sep 20, 2011 | Haier Dehumidifiers
My humidifier dont collect water
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 16, 2011 | Maytag Dehumidifiers
I have purchaced two maytag dehumidifiers M7DH45B2A either one works. I cleaned inside and out blew out the coils with air. Motor runs but will not take out the humidity.
You may have the humidity level set to high. Keep in mind, the higher the number on your LED screen, (if your units have LED display) the more humidity remains in the house. Lowering the numbers on the screen (to 45%), should have a better affect.
Hope this helps you. Please let me know.
May 11, 2011 | Maytag M7DH45B2A Dehumidifier
My dehumidifier compressor runs and then shuts off, then runs and shuts off, continuously. The fan continues to run. It seems to be pulling water, though it's hard to tell how much because I have a...
Part of the problem may be that you have the humidity level set to high. The fan runs constantly to move the air around. When the unit senses a humidity level higher than what you have it set for, the compressor turns ON. Once it's ON, if the humidity level is short lived, it turns OFF.
Try setting the humidity level to the lowest possible setting. Usually, that 45%. If the humidity level in you home is higher than that, the compressor should turn ON and run until either the bucket is full or the humidity level reaches 45%. If this doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet for 12-15 minutes. Plug the unit bakc in, turn the Master ON/OFF Switch to ON and set the humidity level at it's lowest setting. Allow the unit to run until it cuts OFF and check the bucket for water. Hopefully that 12-15 minute time out allowed the unit to reset itself.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 11, 2011 | Maytag M3DH30B2A Dehumidifier
Our dehumidifier turns on for only a few seconds, then shuts off.
Wendy, it's probably because the humidity level on the unit is set higher than the humidity level in the house. Keep in mind, the humidity level you set the control to, is not the amount extracted from the air. It's the level you want it to maintain. The higher the percentage level, the more humidity stays in the house. The lower the percentage level, the more humidity it removes, until the lower humidity level is reached. Then the humidifier will automatically shut OFF and/or the unit shuts OFF, because the bucket is full. Once it's emptied and replaced, if the unit needs to continue to extract humidity, it will start running again.
Hope this helped you solve the problem. Please let me know. Thanks.
New unit, try using in basement. nothing happen, should humidity settings be high or low? Dose humidity level be high? In the bucket whats the plastic cup about? do something alow water to enter bucket?
If you trying to remove humidity, the setting or percentage of humidity to you want to remove should be set low. it's actually the humidity that will be left in the air. In the Hot Summer months, you want lower humidity, as opposed to the Winter months, when you want higher humidity.
"Plastic cup inside the bucket" - that's got me stumped. But, I suspect, it may be a float valve to turn the unit off, once the bucket reaches the full level. The water enters the bucket through a drain tube or hole from inside the dehumidifier, above the bucket.
By best advice, since this is a new unit, that you recently purchased, is read the Owners Manual/User Guide and become thoroughly familiar with the proper operation of your Dehumidifier, as well as how to properly maintain it. As, they aren't maintenance free.
Apr 15, 2011 | Haier DE65EJ Dehumidifier
How to use
sorry its kind of late. if you still have this problem let me know
Sep 03, 2006 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
171 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
