Canon FAX-JX200 Logo
Posted on May 14, 2009
Not working yes hi i have an older fax and it says waeting for redial and then does nothing. what can i do?
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on May 14, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
Helped
6385
Points
28
Recycle it! Cannons are junk, but thats just from my personal experiences.
How do I stop fax redial on Copystar 4035?
You have to be in the fax screen and find your User install or Initial settings screen. Redial can be set there. There's a default setting that I think you can set to "0" redials. I haven't had that manual for a long time.
1helpful
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
2answers
Fax is always busy when sending, have the line into the phone line port and into the telephone jack, fax scans and dials and even redials but it never go through, prints out receipt that says busy/no...
Has it always done this, or did Fax once work? Sadly, Windows XP Fax has many shortcomings, not the least of which is that it won't work with many modems still in common use. Modem incompatibility is not apparent during installation or the initial setup. It only becomes apparent when you try to send or receive a fax. The Fax Service will dial or will answer an incoming fax but then fail with any of a number of unhelpful error messages such as "Line is busy," "There is no answer," or "Reception error." There will be nothing in Event Viewer to give a clue as to where the problem might lie.
These errors have been nearly impossible to track down. To do so requires enabling both PSS and debug logging of fax transmissions, both of which require fairly extensive registry changes. For the time being, the best advice is to attempt to use XP Fax only if you have a modem that is listed on the Windows XP Hardware Compatibility List and using the latest drivers.
Hope helps.
How do I stop my Canon Faxphone from redialing when I mistakenly enter a wrong number and how do I stop my fax from giving me sent receipts
While the fax open the line and dail you can press the stop button,it will display cansel tx you select yes
I need to resend busy faxes with my MFC 9700
Yes, scroll through the set-up menus and set Number of Redials
We can't send faxes.
call the fax number from a regular to check for fax tones.
plug in a regular phone to check for a dial-tone.
GETTING COM AS 634 INSTEAD OF OK STATUS WHAT IS THE REASON
This is what the code means:
Redial was not successful due to no response from the called station or wrong number dialed.
Note
: If busy tone was not detected, the machine will only redial once.
So the your fax machine is getting no response from the fax you're calling.
Hope that helps...
Redial
Go into the admin mode or user mode to reset the default settings. Procedure should be in the op manual.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Fax doesnt send or recieve
pleas close the redial option and other number may be busy or finished
old marine
old marine
ZJ Limited
ZJ Limited
