Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Husqvarna riding lawn mower will only click once but not turn over when key is turned on. Replaced battery but no help. What are some possible solutions
  • 1,000 Answers
If you have a pair of jumper cables, connect one of the red clamps to the battery positive, then using the remaining clamp, touch the post on the starter and see if the starter turns over the engine.
Make sure the key is turned off and the transmission is in neutral.
Let me know if it turns over and we can go from there.
Regards,
Posted on May 14, 2009
What should I try next? My mower will not start.
When you turn the key, do you have 12V art the Starter?
If you do, then tap the starter with a small hammer. If it cranks, then your Starter is failing
Jun 25, 2014 | Snapper Husqvarna RZ4623 46" 23HP Kohler...
What can I try next? My husqvarna RZ4623 wont start. Nothing when the key is turned.
Is the small wire, coming from the Ignition Key, Getting 12V to the Relay when you turn the Key? Were Mice chewing on your wires?
I have a husqvarna 42'' cut lawn mower. I can't
Test the small lead on solenoid for volts when you turn the key. The small lead is what jumps the two switch leads together internally with key in start position.You should be getting 12 volts or so on this small lead, if you have nothing there, check the key switch. Sounds like the key switch isn't sending power to solenoid. Also, check all grounds. Good luck
Sep 05, 2013 | Garden
Husqvarna CTH180XP rideon lawn mower 42" rear
Hi Sue and welcome to FixYa, I am Kelly. You have been quite lucky to get 7 years out of your battery. Given the age of the battery that is currently installed this is most likely your problem. You have voltage but very little amperage due to thinned out battery plates.... (
Let me know how it goes.
Thanks for choosing FixYa,
Kelly
Aug 09, 2011 | Husqvarna Garden
My Husqvarna riding mower won't start. I was
Check to see if you left the blades engaged. There is a safety switch that prevents starting with blades engaged. Easy to miss, happened to a friend of mine last month.
If this really helpful, please rate.
Jul 11, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Turn key on riding lawnmover but hear click but want turn over
If your connections are good then A) you have a bad battery or B) you have a bad solenoid.
May 10, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
CTH151 lawn tractor stopped dead. Nothing happens when I turn the key. Is there a series of micro switches to check?
There are four micro switches on this mower. Go to www.gardenresources.co.uk/ Look at the bottom of the page for husqvarna tractors, then to further reading, click on husqvarna manuals, click on husqvarna ride on mowers, then click on cth151 xp. It will bring up the operator's manual in PDF format. About page 23 it should have a diagram showing the electrical part of the mower.
Hope that helps mate
Dec 27, 2009 | Garden
Husqvarna YTH Lawn Mower will not start
try wiggling the plug while turning the key.
you may have loose terminals inside the plug
May 05, 2009 | Husqvarna Garden
Husqvarna Ride Lawn Mower does not want to start, which theres about 1/2-tank of gas. My Husqvarna Ride Lawn Mower is only a few years old which I have done some routine maintenace. The lawnmower has set...
I've discovered that if you leave key on battery will be drained to dead. Checking battery with meter shows +12v. When key is turned to start position nothing happens. When you connect meter to battery terminals and put key to start position the meter reads about .250 VDC. Even after taking battery to Advance Auto and have it checked it still does same thing. Eventually I jumped my mower with another battery that was being used in my scooter. Bingo! all worked well with jump. You would probably be able to jump with car battery with no problem.
Mar 25, 2009 | Husqvarna Garden
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
350 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
