Question about Frigidaire Freezers
Freezer Compressor Motor turns on and right back off
My upright freezer motor/compressor turns on and right back off, Is it the compressor or could it be a switch? It is not a frost free and is old but has never ever given me a problem. I did notice a switch in the very front underneath that has a temp dial and a couple of adjustment screws on it. I beleive it is a frigidare, probably at least 35 years old. Thanks for your help
    Sergeant:
    Champion:
  • 214 Answers
Please check the following list,
1) check wheather the service wire is in good condition or not.
2) thermostart might have been off.
3) turn the refrigerator backword and see if is there any wire is disconnected/cut.
4) try changing the plug of the refrigerator.
if your problem is not fixed than please contact the service engineer. i'm sure that your stater had been blown.................. have a nice day:-)
Posted on May 14, 2009
Upright whirlpool freezer make loud noise when it comes on
This noise is the fan motor going bad because a bearing is worn out. You need to replace the fan motor before the compressor goes out.
Aug 28, 2014 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer motor will not turn on
Try cleaning the unit out and any coils you can reach (typically located near the bottom of the unit behind the toe grille). Do you hear the compressor running? The compressor is constantly meant to go on and off frequently to keep unit at a constant temperature. If you do not, the unit could possibly have a coolant leak or an issue with the internal sealed system including a faulty compressor, evaporate fan or main control board. Contact a professional move forward accurately.
For manualsonline.com
Jan 29, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My Kenmore up right freezer is not working properly. The fan in running however the condensor will come on for a few seconds and then turn off. The food is thawing out in the freezer and water is dripping...
When you say condensor you probably mean compressor. If the big metal motor at the back is making that noise that is your compressor. The compressor is either bad or the relay for the compressor is bad. I recommand replacing the relay first since it is your cheapest solution and then if that doesn't solve it then you can decide if you want to replace the compressor or not as this is not something you can do yourself and can be quite costly to do if you have a technician do it. Hope this helps.
James Memije
Head Technician
Accufix Appliance Service Centre
Oct 21, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Yesterday, my dad brought me a working GE upright freezer from his house, transport time about 45 minutes. The freezer was working fine before he left his house, he did tip it little bit to load, unload...
You should try to un-plug the freezer and let it stand up-right over night to re-settle the freon back down inside of the compressor.
The compressor should normally get hot if it is doing it's job right, and there is a starter for the compressor motor (usually it looks like a large capacitor) that could have failed, or the defrost timer (if it has one) could be stuck, and you should be able to see the small dial on the defrost timer slowly turning, and if it does not turn, then replace the defrost timer.
Jun 07, 2010 | GE 13.7 cu. ft. General Electric Upright...
Freeezer with no compressor activity
If all fans are running, but not compressor You could try to install 3 N 1 start kit, thats might help 50/50. If it will start compressor - be ready for compressor to go out soon. might work for a year.
Dec 13, 2009 | Kenmore Freezers
The compressor works for a few seconds but then stops. The freezer is over temperature.
Check the condenser fan motor (next to compressor) make sure it is running. Next change relay (inside black box) on compressor.
Apr 27, 2009 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Mar 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
234 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
