Question about HP mx705 17" CRT Monitor
Menu(user mode )display is coming again and again?
User mode display is coming again But after setting my graphics properties it not coming . Again restart my computer this message is come. Please solve my problem.
  • 91 Answers
While your PC is turned on, disconnect the monitor, and unplug, then plug it back in, and reconnect it back to PC..
Posted on May 14, 2009
My monitor says out of range
You have set the resolution or refresh rate of your display adapter to a value which is too high than what is supported by your monitor.
In order to fix this, you have to do the following:
1. Reboot your computer & press F8 to boot into Safe Mode.
2. Once in Safe Mode, open Device Manager.
3. Remove the display adapter device driver form Device Manager.
4. Reboot your computer again. Windows will boot up normally & will detect the display adapter. It will prompt you for the device driver for the display adapter.
5. Use the CD that came with your display adapter to install the device driver. Once done, your problem is fixed.
Sep 01, 2011 | Insignia D300a PC Desktop
Hi, My monitor has dull display. After starting my computer, I could see the desktop but after few seconds it disappears. I am sure whats happening. Please suggest me what to do.
My answer will help Windows XP and Windows 7 users.
When the computer starts, start pressing F8 button. After several seconds you will see the following menu.
Safe Mode Safe Mode with Networking Safe Mode with Command Prompt ---------------------------- ---------------------------- ----------------------------
If you have Win XP, there will be a menu item as 'Enable VGA Mode'. In Win 7 you will see 'Enable low-resolution video (640 x 480)'
Select this option and press enter. (XP users will have to enter again).
After the computer is ready, goto display properties and save the resolution.
- In XP right-click on desktop, select 'Properties', Click the 'Settings' tab (last tab on top), and click 'OK' button.
- In Win 7, Right-click on screen and select 'Screen Resolution'. Click 'OK' button.
(Ignore any warnings)
Restart the computer.
Set the screen resolution again to a reasonable setting.
- Be careful! If you set it too high (if the monitor does not support the resolution you select), again the screen might disappear! (Sometimes this happen automatically after installing a game)
Jul 19, 2011 | Dell E176FPC Monitor
No screen display after resolution change
Restart your computer press F8 key from the displayed option select safe mode. After entering in to the safe mode go to device manager in my computer property, Hardware option. In that remove the display driver and restart your PC.
Sep 30, 2010 | Computers & Internet
I need to have the resolution set at 1440 X 900 for best viewing. I don't have a clue how to do this. Thanks.
Hi
Please do the following
1) Switch on your PC
2) Right Clickin the middle of the dekstop and click on properties
3) This will open a display properties window, at the top there will be a tab called settings
4) In this windows half way down there will be a option entitled screen resolution, this slider can be pushed to the left or right push to the left until the figures at the bottom read 1440 X 900 pixels
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 17, 2010 | eMachines E17T4W 17" Monitor
Screen goes black. the power light is on, but the picture goes out. if i turn the power off, then on again it comes back for about 5 seconds, then goes black again.
Check to see if this problem follows in safe mode. Reboot and when the Dell splash screen comes up tap F8 until you see the multiboot options. Scroll to "safe Mode with Networking" let the machine boot up and see if you have a screen. If you do, right click on the desktop and set the resolution to 800 X600 and reboot normally. Usually when a screen goes blank in normal mode but shows up in safe mode means you have an incompatible resolution for the monitor or graphics adapter. This may be a driver issue or hardware. If the screen boots up in normal mode at the lower resolution, then try and go to properties again and bump the resolution up a bit, if it blanks again, try to go online and update the driver for the graphics chip.
Sep 08, 2009 | Dell Dimension E510 PC Desktop
Need to change vidio mode to display input to 1024-768 @60hz to use my new monitor dell 2400 diminsion and acer monitor please help me''
go to control panel. look for personalize or display menu. select display settings and change your resolution and apply. then go to advance settings and see if set to 60 hz
Apr 24, 2009 | Dell Dimension 2400 PC Desktop
About my loptop
Try right-clicking anywhere on the blackened area of your desktop, a menu might appear. Scroll down to Properties and click. In the Display Properties window click on the Settings Tab and see if you can re-adjust your screen resolution here, if not then read on...
Power off the laptop. Power on the laptop while holding the F8 key or both the SHIFT and F8 key together, if it boots to the Windows start up screen, power off and try again. This will bring up a menu, you will want the BOOT INTO SAFEMODE menu option.
After the safemode boot process, see if your laptop will display graphics (it should default to 640x480 mode and you should be able to view most of your desktop icons). Right click any where in a black area on your desktop, a menu will appear. Scroll to Properties and click. In the Display Properties window, click on the Settings tab and adjust your screen resolution from here.
Let me know if this works or not.
Jul 10, 2008 | IBM Computers & Internet
Monitor not working
try going to safe mode,restart pc then press f8 for advance boot menu,go to safe mode,choose administrator,reenable display adapter again..eiether thru device manager or display properties
Jun 25, 2008 | Acer Aspire 3680 Laptop
OUT OF RANGE on monitor screen
you have to change frequency of monitor to work smoothly form display property.
Out of Range is frequency is not matching
To solve this, wwhile booting Press F8 to get advanced boot menu from that select "Enable VGA mode"
change the display properties
right click on desktop - Select properties - Settings - Advanced (from bottom) - goto monitor tab - change the frequecny to default. and restart the system normal mode
May 25, 2008 | XFX GeForce FX 5200 Graphic Card
SCREEN MESSAGE - MODE NOT SUPPORTED
You have set a resolution that is too high or incompatible with your monitor. I assume you are using Windows. Turn the computer on and immediately keep pressing F8 on the keyboard until the 'Windows Advanced Options Menu' appears. Use the Up and Down keys to select 'Enable VGA Mode' Press enter and your screen will work again when windows starts. Now go to the display properties and click 'Advanced' then click the 'Monitor' tab and tick 'Hide modes that this monitor cannot display' OK everthing and now you should be able to adjust the resolution without getting a blank screen again! Good luck and come back to comment soon. Regards
Sep 26, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
HP mx705 17" CRT Monitor Logo
255 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
