Question about Sony KV-27V42 27" TV
Unavailable Part I have a Sony Trinitron model KV-27V42. It's about 7 years old, and it shut off while I was watching it. When I try to turn it on, I can hear it click like it always does, and then the screen remains blank. There is a red standby/timer button that flashes a couple times every 30 seconds or so. A repairman diagnosed that I need a Power Supply Board - Complete Part # A1298901A is no longer available. Is there a compatible part out there that can be used instead of the one identifed by the repairman/technician?
  • 12heather Dec 18, 2007
    TV is 7 years old and shut off while watching today. It smelled a little like something burning when standing near the set. When turned back on, screen stayed blank. There was a clicking sound inside the set and the standby button flashed 4 times. After 30 seconds it flashed 4 more times, then the set turned off. We unplugged the set and let it sit for more than 5 minutes and plugged it back in to the wall outlet. This did not help. Wondering what the problem is and how much it will cost to repair?
    We also noticed that it has always made a sound when immediately after turning it on that sounds either like a "thud" and a "buzz".
    Problem Solver:
  • 14 Answers
I 've been an electronic tech for more than 20 yrs, and a tv tech for many yrs as well, the problem you describe; the power supply board needs to be repaired as well as the main board, on the main board usually the Horizontal output, however, parts should readily be available for both, I've worked on and repaired many of these model tv's. hope this helps.
Posted on Nov 22, 2007
  • 1,694 Answers
More properly called the "A" or main board.Can be repaired by
a qualified tech in a shop setting.Possible horiz or power circuit
Posted on Oct 15, 2007
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
32 inch sony trinitron wega
It will most probably need an overhual of the power supply
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega Kv-36XBR250 screen blinking
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Sep 02, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Tv shut itself off while I was watching.
The power supply will need to be replaced. You can get them for $30 plus dollars and solder them in.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The 'pop' may have been an arc of electricity from the flyback coil. The flyback is the device that produces very HIGH VOLTAGES --that can kill so be careful--. It may have just goten old and the material around the flyback broke down and allowed the electricity to arc to a near by source to ground. it happens when CRT sets get old. Typically I expect 7-10 years of a consumer grade CRT. Other then that any fix for it would have to be performed by a trained technician because voltages can linger in the 'caps' and even the 'tube' itself for years, I once got 'bit' by a set that was left un-plugged for 5 years.
Aug 15, 2008 | Sony KV-36FS100 36" TV
Sony trinitron TV KV-27TS27 screen remains dark
how do i adjust the brightness if i dont have the controler?
Jul 24, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Won't ruen on
nombre de ligne
Jun 17, 2008 | Sony KV-35V35 TV
Sony Trinitron Model KV-27S10
If hte set is a Sony, the standby light should be blinking a code. Report that code here and we should be able to guide you. That code will indicate the problem circuit within the set that has the fault.
Jun 02, 2008 | Televison & Video
My TV won't come on!!!
you have powersupply problem .you wil have to have it checked by tech sorry
Mar 22, 2007 | Sony KV-27V42 27" TV
Sony KV-27V42 27" TV Logo
75 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
