Question about Cyberhome CH-DVD 300 DVD Player
Dvd 300, have sound but no picture
I have problems powering the unit at times, but more frustrating is the fact that when i do get it to power up, i get sound but no picture. i have checked the input setting for the tv and also all the cable connections, to no avail. it has been a very good dvd player up until this point and i would hate to toss it if it can be fixed. pls help
    President:
  • 814 Answers
This unit is probably just aging out and finally given up working. The first sign of problems is when you should have looked for solutions to the problem. When a unit start to malfunction it is usually a sign that it is overheating or aging out. Sometimes this occurs in new unit , but that is usually faulty components.This problem shows up early and can be fixed or replaced.In older units the whole mechanism is aging out and there can be numerous problems leading to a major failure.In these cases only a replacement is really cost effective. Hope this helps you with your problem.
Posted on May 15, 2009
No power going to unit
This is very technical problem. It is the power supply. A very sensitive circuit board, in fact i just fixed one today. The way these power supply works is they convert the ac directly to DC. Then switch on and off at high frequency of typically over a hundred thousand times per second to drive a special transformer to deliver power to the unit. On larger unit the screen is driven by several high voltage transformers and probably that wnet out first thats why it lost picture. Finally the main power supply went out as well. When I fixed the one I did today I had to find a technical data on the chips that like a freakin engineer analyzing a circuit. In dept understanding of electronic theory is a must. Now you may find a power supply on e bay or something thats about the best advice i can give you.
Jun 26, 2010 | Grundig Lenaro 26 in. LCD TV
No sound, no picture
Try with external monitor and let me know did u see ur desktop with external monitor?
OK?
Nov 24, 2007 | Toshiba MW26G71 26 in. TV/VCR/DVD Combo
Won't power on
Toss this junk to the garbage can, this is how I solved my frustrations with my two units
Dec 29, 2009 | Cyberhome CH-DVD 300 DVD Player
I have a Cyberhome CH-DVD 300 DVD Player &
Toss this junk to the garbage can, this is how I solved my frustrations with my two units.
No picture
hi..make sure the cable or dvd RCA inputs red,yellow
and white inputs are proper.There may be some loose
connections.
check it out..
thank u..
rate me..
May 05, 2009 | LG 42LC2D 42 in. LCD HDTV
Have picture, no sound
I've had this trouble too. Not sure how to fix it, but I've found a work-around:
Remove DVD.
Insert Audio CD.
Wait for audio to play.
Remove audio CD.
Reinsert DVD.
Sound should work again.
If you power off the unit, you may have to try this procedure again.
Sep 27, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD doesn't work, Help! please.
It sounds like a common problem with these units, which is easily fixed...
Open the unit and look at the capacitors on the power supply circuit board, there are probably some bulging or leaking caps on it, just replace them and you should be good to go. You should replace them with a little higher voltage but keep the same micro-farad value. ie: use a 16volt in place of a 12volt.
Jun 08, 2008 | Cyberhome CH-DVD 300 DVD Player
JVC AV56WP74
Replace the lamp, also the shut down time is correct the unit must allow plenty of time proper lamp cooling. otherwise the lamp life will be greatly shortend. normal lamp life is 3000 hrs.
lamp replacement may require an internal limp timer reset have a qualified tech replace the lamp.
Oct 06, 2007 | JVC HD-52G886 52" Rear Projection HDTV
No light fuse is good unit (1) want power up and unit (2) red light but want do nothing both are connected to AC power source
The CH DVD300 is notorious for power supply problem. If this the case, you can send the power supply to be repaired for around $15.00 to:
Wired Communications
31211 N. 77th Way
Scottsdale, AZ, 85262
Tel. 480-209-1700
Contact them before sending anything.
Francis
Oct 04, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
42 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Henry  Thomas
Henry Thomas
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
