Question about Mtd Garden
Stalls when engage blades in forward, but cuts fine in reverse
Mower stalls when I engage the blades in forward, but cuts and runs fine in reverse! The mower runs fine in forward and reverse without the blade deck engaged.
  • Anonymous Mar 15, 2014
    cuts ok when cutting short grass, but stalls when cutting taller, what is wrong
  • Anonymous Mar 27, 2014
    Blinking light on dash panel. Blade won't engage. Battery is fully charged.
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
Starts fine, drives fine. When I engage cutting blades, it immediately stalls.
If in all other respects the mower is running like expected then it is most likely the switch under the operators seat that will not allow the blades to engage when no one is sitting in the seat. If the operator is under weight or the switch defective the unit will shut off!!
Apr 11, 2016 | Garden
Craftsman GT6000 54" stalls while mowing
Sounds like you have dulled the blades with your aggressive hill cutting
Aug 12, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
Mower dies when directional pedal ( F/R) or engageing blades
check the safety switches start with the one on the pedal
May 16, 2012 | Garden
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Engine runs but stalls when engaged
This sounds like a micro switch, or relay issue, it is not stalling it is being switched off, if there are some relays on the back of the bulk head replace them, they are just a push fit.
Feb 26, 2012 | Garden
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Riding mower stalls when PTO is engaged.
check the kill switch and the wire it could be that a small piece of the covering came off and is grounding to the deck or frame there by killing the engine the jerkink of the mower maybe whats causing the wire to come into contact with metal..good luck
Apr 03, 2010 | Garden
Troy Built Ride-on, stalls when blade is engaged.
You may have a short in one of your safety switches. There is usually one on the seat that shuts it off if you try to get up and one on reverse if you try to back it up. I would look there to see if somehow they are grounding out
If you can get it where you can grab the blades, check and see if they float easy. You could have a seized bearing on one of your blades that is stalling out the motor as well.
Hope this helps
Aug 20, 2009 | Garden
Poulan Pro riding mower jerks in forward and the blades engaged
This is a lawn mower catagorized as a chainsaw. We don't answer lawn mower questions ands you don't cut down trees.
Mar 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
1,191 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
