Question about Logitech Z-5300e Surround Sound System Computer Speakers
NO SOUND I DON'T GET ANY SOUND IN CENTRAL AND SURROUND SPEKER'S BUT LEFT AND RIGHT THEY ARE WORLING FINE PLEASE LETME KNOW WHAT CAN I DO ABOUT IT THANKS 4 U TIME . CRISTHIAN URIEL
  • patrick carolan Sep 14, 2009
    no sound in all but 2 speakers
Sorround speakers not working though connected correctly
Without knowing exactly what your problem is, perhaps you are not playing sound that was recorded in at least 5.1 format. A DVD or BluRay will indicate the format on the cover. The data is decoded and split into (for example) six discreet audio channels. Left front, Centre front, Right front, Surround Left, Surround Right and LFE (Low frequency effects) If you are playing a standard stereo audio disc, then the sound will only be heard from the front L&R speakers, which are expected to be full range speakers. You can, however choose an audio configuration that also provides a signal for the SUB (LFE) and even a pseudo surround. If you want more info I'm happy to help. Just tell me exactly what sound source you are playing and we can work it out.
Cheers for now, Don.
Feb 19, 2015 | Denon AVR-1804 Receiver
PANASONIC SC-BT230 - The Center Speker and Back Sorround speakers not working
Press the surround button until it says manual, then use the left right arrows to select prologic.
Feb 25, 2011 | Panasonic SCBT230 Theater System
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Rear spekers no sound
Is the source signal of a surround sound type? Also, be sure that the rear speakers are on, (if your receiver has a speaker switch on it), and they are hooked up properly.
Mar 23, 2009 | Sony HOME THEATER SYSTEM System
Hp 5610 won't print
If you need Vista drivers for your printer, go to HP.com to get them and see if that works.
Jun 17, 2008 | HP Officejet 5610 All-In-One InkJet...
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
Only one surround back speaker works
It sounds to me like one of your speakers may be mis-wired. Try reversing the speaker wire (don't switch right-for left, but switch negative for positive) and see if that changes anything.
Dec 31, 2007 | Onkyo HT-SR800 System
Help
you cannot get your tv to play surround sound through the speakers, but if your tv has either a scart 21 pin socket or an audio out, you can fit a scart to phono adapter and connect the phono plugs to the audio left right input on your sound system, likewise if you have audio left and right output(phono) on the tv, connect to audio in on your unit. You should have a choice of output channels on the system menu, similiar to DVD/video1/video2 or output 1 and 2 or auxilliary 1 and 2
Jun 04, 2007 | Audiovox DV1532 System
Logitech Z-5300e Surround Sound System Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
