Question about Dryers
Blown thermal fuse on Kenmore dryer
I've replaced the thermal fuse twice on my Kenmore dryers, 70 series. There are no clogs, leant screen is clean, brand new duct and no kinks on it and fan motor has no build up. What is causing the fuse to blow?
  • 2 more comments
  • jose_herrera May 16, 2009
    Hello, thanks for replying. Here is the info you requested.
    Kenmore 70 Series
    Model #110.66712690
    Serial# MF3409108
    Thanks again.
  • jose_herrera May 17, 2009
    Hello vickygomar,
    I just purchased a thermostat kit, which includes two t-stats and a couple of connectors, for this particular dryer. I spoke with a buddy at work and he informed me he had similar issues with his dryer a while back that that is what the problem was. Please let me know if this is what you think it is or some other issue? Regards Jose Herrera
  • jose_herrera May 20, 2009
    I received the fuse and stat a couple of hrs ago and replaced them. I ran a couple of loads already and so far so good. I did notice that even in the low/delicate heat setting, the dryer/clothes still fell pretty hot?
    Is this something I need to be concerned about? I'll let you know if the fuse blows again. And thanks again for the reply. Jose
  • jose_herrera May 22, 2009
    Guess what vickygomar, the darn thing did it again. I was drying my 3rd load and it blew the thermal fuse. What next since I've replaced the thermal fuse 3x and both thermostats?
  • 460 Answers
I need the serial# to assist you better.
Thank you for trust fixya.com
Posted on May 14, 2009
  • 2 more comments
  • VIRGINIA MARTINEZ
    VIRGINIA MARTINEZ May 18, 2009
    this is important as your friend recomend it.
    Whirlpool suggests replacing the cycling thermostat also when the fuse goes bad since it is probably not shutting the elemet off when it should if the fuse opened...also be sure to re-check your vent system from the dryer to the outside, make sure you have good air flow.
    Your Rating is very important for me
    "Was this helpful?"
  • VIRGINIA MARTINEZ
    "Was this helpful?"
  • VIRGINIA MARTINEZ
    VIRGINIA MARTINEZ May 20, 2009
    am so glad to hear that your dryer is working proparly.
    let me know if these anything also I can help u with am here to help U.
    If you satisfy with my help please
    "Was this helpful?"
  • VIRGINIA MARTINEZ
    VIRGINIA MARTINEZ May 22, 2009
    let see if this helps you a bit.
    Firt at all have you check the lint(lana) in your dryer not only in your front your driyer but in the behind tub, and in the bent to see if is running freely let test it ok,
    1.- go to the out side vent
    2.- put in the vent 3 squers of toilet paper together means with out cuting them in one piece,
    3.- turn your dryer on
    (*_*) If all the paper toilet fly freely is fine
    ((*_*))If the paper toilet goes slow, Give thanks to God because this Fuse save your live, your and your family,LOOK at this video
    DryerVentCleaner.com
    If you need to clean your lint and vent see this video
    http://www.youtube.com/watch?v=5Dj4im31l...
    This is a web side that I found so you can learn more about this problem.
    http://answers.yahoo.com/question/index?...
    KENMORE DRYER REPAIR VIDEO 5
    http://www.youtube.com/watch?v=Wd1OOYegk...
    You need a meter to check all this is just 10.00 in wal-mart.
    Let me know if this works for U and what was the problem.
    Was this information helpful?
Kenmore dryer 70 series
Check the vent for clogs and kinks. Could be something in the blower wheel causing the noise and blocking the vent.
Remove the vent from the back of the dryer, unplug the dryer, and reach inside the dryer vent to check for items lodged in the blower housing.
Feb 04, 2014 | Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
I have a roper dyer red444qv1 but will not start
This is very likely due to the thermal fuse being blow open as a result of a failed thermistor and/or clogged lint screen or restricted vent system. The thermal fuse is wired in series with the motor and cuts power to the latter when the former has blown. No dryer function works when the motor cannot run.
Disconnect power then clean the lint screen and the vent system if necessary. Remove the rear panel to access and replace the thermal fuse and the thermistor on the blower housing. Click on the link below for the troubleshooting and repair details.
Kenmore and Whirlpool Dryers Not Starting
Jun 19, 2011 | Roper REX4634KQ Electric Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Dryer will not turn on
Check for a blown thermal fuse. It's about an inch long and is usually located just inside the rear of the dryer attached or close to the exhaust duct. It can be tested for continuity using a multimeter or ohmmeter. A lack of continuity indicates a blown thermal fuse. Hope this helps and best wishes.
Aug 26, 2009 | Kenmore Dryers
80 series kenmore dryer not heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Aug 04, 2009 | Kenmore 84052 Dryer
29'' Kenmore electric dryer series 110 not heating up
Check the following to address this issue.(Most common issue will be a burned out thermal fuse.)
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Aug 03, 2009 | Dryers
Kenmore Dryer won't heat up
thermal fuse is bad. replace fuse. clean out vent duct. thermal fuse usually blows when there is restricted air flow over heating element.
Jun 24, 2009 | Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Kenmore dryer 70 series flame ignites, but goes out after 5 mins
If it's gas, the coil valves get weak and are unable to hold themselves open when hot. First, check the exhaust vent. If it's clogged, it can't remove heat and it will shut off prematurely. Most likely the coil valves though.
Mar 03, 2009 | Kenmore 63942 Dryer
Dryers Logo
1,289 people viewed this question
Top Dryers Experts
