Question about Zoom X6 (5590) DSL Modem (55900003)
Problems with xbox 360 wireless adaptor, finding zoom x6 router
I have bought a zoom x6 because my old linksys router kept over heating and turning off. when i got the new router i also got the xbox wireless adaptor. the problem is xbox adaptor does not find the zoom x6. i have tried using connectivity set up with flash drive, which is no good. i have done manual search for the network but it still can't find it. however it find both my neighbours networks. so on trying my faulty router the xbox picked it straight up. the security settings are the same as my faulty router but still no joy please can anyone help???
  • 1 more comment
  • Anonymous Jun 17, 2008
    have the same problem has cool7300s saying it is connected but it is not
  • aussiegrl Jul 19, 2008
    I have a similar problem, except xbox see's my network and connects, and when I do the media test I get wireless network not connected. I change from my Linksys router to a TP-Link router. When I plug my Linksys back in I get the same non connection message. Any Idea's.
  • Nobox Jan 02, 2009
    My xbox 360 (Wireless adapter) also refuses to connect to my zoom 5590 x6 ADSL Modem/router. It can find it but it just will not connect . Anyone have any ideas?
For this problem use http://zoom.custhelp.com/cgi-bin/zoom.cfg/php/enduser/std_adp.php?p_faqid=929&p_created=1193678463&p_sid=NcYTzXmj&p_accessibility=0&p_redirect=&p_lva=929&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjEsMjEmcF9wcm9kcz0yNSwxMjcsMTY5JnBfY2F0cz0wJnBfcHY9My4xNjkmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PVdpcmVsZXNz&p_li=&p_topview=1
Posted on Jan 02, 2009
I cant use xbox live without plugging into router which im unable to do. Is there another solution
You can do it wirelessly. You need a wireless router and if you have an older model Xbox(The newer models have the wireless adaptor built in) you need to by the wireless adaptor. Found a Liknsys Cisco wireless N-300 router refurbished on Tiger Direct for under $30. I bought one there excellent same one at Walmart between $60 and $90. The Adaptor for the 360 is $79.99 to $99.99 and you can get those online or at Walmart and Gamestop.
Dec 24, 2010 | Microsoft Xbox 360 Console
How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
The easiest way to connect to Xbox Live without using your pc is to buy a
wireless network adapter for your Xbox.
You would then go into the system settings on the Xbox and configure the settings for your wireless network.
http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
Xbox 360 - direct to internet - No PC.
Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
Wireless WPA connection problem to Zoom ADSL X6
ya there is filter oing inbound also check port forwarding in router and check firewall to.
Default ip for access belkin router is http://192.168.15.1
May 05, 2009 | Zoom X6 (5590) DSL Modem (55900003)
I have a Zoom X6 ADSL modem that keeps dropping my internet signal. How can I correct this?
is it wireless connection or ethernet? Zoom routers have a firewall and when you have something connected that the firewall doesnt like (Xbox 360 or Gaming) it will drop the connection. goto zoom.com/x6 and it will give you instruction on how to by-pass the firewall using an different IP address.
Mar 22, 2009 | Zoom X6 Adsl Modem/router Rohs...
Wireless adaptor xbox 360
make sure that your modem acctually has wireless capability, enter a manuel ip address and gateway that should do it you can find out ur ip address and router settings at routerlogin.net and you should be connected to youre router if a username and password are required then there are websites conntaining all default passwords, most will be admin and password
Jan 18, 2009 | Microsoft Wireless Network Adapter Xbox...
Cannot connect xbox 360 to wireless router
If you use DSL I would also check to make sure you are not being port blocked by your ISP. Some will block you if you exceed bandwidth on a particular port rather than throttling you or shutting you down entirely.
Dec 29, 2008 | Linksys Wireless-G WRT54G Router
My xbox 360 Nat is MOderate i have a Zoom x6 Adsl Wireless or Wired
You will need to forward some ports on your wireless router or modem. Call xbox live customer support, and they will guide you through the process.
Jun 04, 2008 | Zoom X6 Adsl Modem/router Rohs...
Zoom X6 Adsl Router
You must assign a static IP address on the Xbox 360 that it is outside of the Zoom X6 router's DHCP pool. Also, the Xbox 360 must be in a DMZ. This will prevent the firewall of the router from blocking connections to the Xbox 360.
  1. Assign a Static IP address on the Xbox 360 console:
    • Power on your Xbox 360 and go to the System area.
    • Select Network Settings and then Edit Settings.
    • Select IP Settings. The Edit IP Settings screen opens.
    • Select Manual and then enter the following settings:
      • IP Address: 10.0.0.150 (or any 10.0.0.x IP address, where x is between 100 and 250)
      • Subnet Mask: 255.255.255.0
      • Gateway: 10.0.0.2
    • Select Done, to go back to the Edit Settings screen.
    • Select DNS Settings. The Edit DNS Settings screen opens.
    • Select Manual and then enter the following setting:
      • Primary DNS Server: 10.0.0.2
      • It is not necessary to enter a Secondary DNS Server.
    • Select Done.
    • Power down your Xbox 360.
  2. Access the Zoom Configuration Manager:
    • From a computer that is connected to the Zoom X6, open a web browser and type http://10.0.0.2 in the address line and then press Enter (or Return).
    • Enter the User Name and Password (in lowercvase letters):
      • User Name: admin
      • Pasword: zoomadsl (where "l" is a lowercase letter L)
  3. Create a Virtual Server rule to put the Xbox 360 on a DMZ:
    • In the Zoom Configuration Manager, click on the Advanced Setup icon at the top page.
    • Click on the Virtual Server/DMZ button.
    • On the Virtual Server/DMZ page, enter the following settings:
      • Internal IP Address: 10.0.0.150 (or whichever Static IP address you selected per Step 1)
      • Protcol: DMZ
      • Start Port: 0
      • End Port: 0
    • Click Save Changes
    • Click the Enable box, if you have this option.
    • Click Write Settings to Flash
  4. Plug the Xbox 360 Wireless Networking Adapter in to the Xbox 360 console. If you are not sure how to do this, please refer to the manual that came with the Adapter.
  5. Select the Zoom wireless network on the Xbox 360. (Note: The following steps assume you have a working wireless network with WEP or WPA security enabled and you know the Key and SSID of the network. If you have not done this, please refer to theFAQ on setting up a wireless network with the Zoom X6.)
    • Power on your Xbox 360 and go the System area.
    • Select Network Settings and then Wireless Network.
    • Enter the SSID of your network
    • Enter the Security Key for your wireless encryption. This must be either WPA or WEP. If you use WEP, you must enter the HEX digits for the Key you are using.
    • Power the Xbox 360 off, wait a few seconds, and then power the Xbox 360 back on.
    • Go to the System area.
    • Select Network Settings.
    • Select Test Xbox Live Connection. If everything is configured correctly, all the tests will show Pass.
  6. Congratulations! You can now enjoy your Xbox 360 with Xbox Live.
May 23, 2008 | Zoom X6 Adsl Modem/router Rohs...
Cant get nat to open to play xbox live
Question about Port Forwarding?? <A href="http://portforward.com/english/routers/port_forwarding/routerindex.htm">Click Here</A>
May 17, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
LIVE SETUP
Does the Xbox 360 wireless network adapter look like this?
What steps have you tried already?
Nov 15, 2007 | NetGear WGR614 Wireless Router
Zoom X6 (5590) DSL Modem (55900003) Logo
627 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Mike
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
