Question about Amana NED7200TW Electric Dryer
Dryer will not dry - drum will not turn
I have a amana dryer model no.: NED 7200TW will not dry. All the sensor and setting lights are on but nothing happens including the time which is running down but the drum is not turning - you hear a click but nothing is happening Dryer less than a year old.
  • Anonymous Mar 30, 2014
    Dryer comes on but drum not turning, etc. Lights display etc. But nothing else
Just happened to mine also. The problem was that the Idler Pulley came loose from the drive belt. There is a switch on the idler pulley so that if there is no tension on it, the motor will not start and you will have the symptoms you describe. To reattach the Idler Pulley, remove the back plate surrounding the dryer exhaust. This will give you access to the Pulley. If the belt broke (unlikely with a new dryer such as yours), the fix is more involved. This dryer is the same as the Maytag MDE6700 - you can do a search for a service manual for that model and you can see the details. Hope this helps.
Posted on Jun 04, 2009
  • david rodriguaz
    david rodriguaz Nov 20, 2013
    the thermostat keeps failing
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Is it under waranty? call seller and change it
Vitally
Posted on May 15, 2009
HOW DO i GET THE FRONT PANEL LOOSE AT THE BOTTOM
You have to tip the unit backwards. Put a a piece of wood under it and remove the screws on the bottom of the unit. There should be one on each side.
Nov 02, 2014 | Amana Dryers
My Amana gas dryer Model NDG7800AWW heats initially and then stops.
Hi Mohit , you need a new set of valve coils . It's part # 5303931775 GOOD LUCK APPLIANCES R'EN
Jun 17, 2014 | Amana NDG7800AW Gas Dryer
Is the amana ned 7200tw stackable
Yes stackingkit 5303937141 to stack them
Mar 16, 2014 | Amana NED7200TW Electric Dryer
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
Aug 08, 2013 | Whirlpool Cabrio WED5550XW 27" Front-Load...
3 year old Amana NED 7200 dryer has film of black grease in drum back portion and grease is on clothes after coming out of dryer.
Check the thermostats for continuity. Sounds like the dryer is getting to hot and may have melted something. There is nothing with grease in that area of the dryer,
Nov 06, 2012 | Amana NED7200TW Electric Dryer
AMANA DRYER MOD # P NGD 7200TW FRONT LOAD ABOUT 1 1/2 - 2YRS OLD NOT GETTING HOT WHEN TURNED ON HOW DO I OPEN FRONT PANEL TO CHECK IGNITOR AND SENSORS
To open that dryer ya need to first remove the top by removing the screws in the rear of it,then remove the control panel...behind the control panel are screws that hold the front panel to the cabinet.
this tip i wrote will help ya to determine why its not heating...after disconnecting the front panel it can be letf connected to run the dryer to see whats happening as far as the igniter not coming on or whatnot
Here is that tip http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 10, 2011 | Amana ALG230RAW Gas Dryer
T5 error code comes in my amana dryer ned 7200tw
That is actually a Ts error.
Thermistor Short Sensed
The Thermistor resistance is very low.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Thermistor is Item #27 HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 06, 2010 | Amana NED7200TW Electric Dryer
Amana NED7200TW Electric Dryer Logo
507 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
