Question about Pentair IntelliBrite Pool Light :: 120V - 100-FT Cord -
How to fit the gasket on a pentair pool light
  • 366 Answers
Once you have the light fixture on the deck, take it apart. There should be a screw/bolt with a 3/8" head with a phillips insert. Once you remove the bold the band should come off. Be sure to take note how the light comes apart. You'll have to line up the top screw with the top of the fixture, this also lets the tabs fit properly as well. Once it's apart, just pull the old gasket off and clean the lens thoroughly. stretch the new gasket around the lens and make sure it seats completely. Place the lens against the fixture with the lens lined up with the led's if you have the intellibrite. Sometimes the lens will have an "up" marking. Where the cord comes out of the fixture is normally the the top, line the fixture ring up with screw to the top, check to see that the tabs are lined up and then fit the wire band around the tabs and insert the bolt and tighten thoroughly.
Posted on Sep 24, 2009
What coould have caused all the pentair aqualumin lights to have burnt out or filled with water?
This seems to be caused by the gasket having failed. There is no other answer except that if you have water inside the lens of the light.
Rod
www.uspartscenter.com
Jan 29, 2013 | Pentair American Products AquaLuminator...
Pentair pool cleaner won't stay locked in
bad in-wall fitting see if tabs ore off if broken replace if cannot get out of wall turn off pump put fitting in wall and then try with channel locks to remove
Apr 02, 2012 | Pentair White/Gray Legend Platinum...
TYPE OF POOL WALL CONNECTOR FROM HOSE TO THE POOL WALL FOR PENTAIR GRAY LEGEND PLATINUM POOL CLEANER?
There are a couple fittings used between the wall and pipe,
Start with these:
Wall Fitting, Gray - Part Number LLW22PM
Wall Fitting, Complete - EW22
Quick Disconnect Adapter, Gray - LL23PM
If these aren't what you need let me know.
Feb 27, 2012 | Pentair White/Gray Legend Inground...
Pentair pool heater error e05 begins to heat then shuts off heat
This issueis related to the stack flue sensor and it might have a wiring problem or a bad sensor. I recommend you call the Pentair technical support at 800-693-0971and they should be able to help you figure this issue out further. Ihope this helps.
Oct 08, 2011 | Pentair Mastertemp Pool & Spa Heater Dual...
Have a pentair 1 HP whisperflow pool pump. It makes a loud high pitch sound when turned on. Sometimes when first turned on it won't but quickly will begin making the loud high pitch sound. Almost...
Are you sure that you have it wired the right way. it has a setting for 220 or 110 the pump will run if it is not wired correctly however it will be varey ******* the brushes inside the motor resulting in a loss of efficiency
May 22, 2011 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
I installed a complete hayward filter with a new multiport valve. i can see DE in my pool. what would cause this? Thanks for your help.
If these Hayward pool filters are leaking DE back into the pool, there are a couple things that you will want to check. Check for loose bolts on tube nest plates and tighten them if necessary. Make sure that you don't have a worn or loose fitting diaphragm gasket and that there are no rips and holes in it. Replace the gasket if any of these is the problem. Check for openings or tears in one or more Flex-
Tubes and replace them if necessary.
Dec 19, 2010 | Pentair Clean & Clear Filter and Dynamo...
Water flows out the flange where the motor
dont no were you are,but did it freeze,loose,gasket trouble,is the centre housing cracked?
Dec 08, 2009 | Pentair Pinnacle 1 1/2 - Hp In Ground Pool...
Pentair IntelliBrite Pool Light :: 120V - 100-FT Cord -  Logo
303 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
