Question about Homelite Mighty Lite Lawn Trimmer
Where does the gas line connect on a homelite trimmer
I know the line with the filter in the tank but which connection does this line go to
  • Anonymous May 18, 2009
    Which is the intake line???? the one going to the bulb????
Does it have a resec hose
Posted on May 16, 2009
  • smith848 May 16, 2009
    does it have a reserc hose?
What is the filter like piece in the gas container of Homelite trimmer? Is it supposed to be in there?
There are two lines that come out of the gas reservoir. One of these is the gas intake line. The filter is on the end inside the tank to keep trash out of the carburation system. If the filter is just loose inside the tank you might repair it with a gas line kit that has the filter on the end of the new replacement. However, you might see if the filter just slipped off the end of the intake line. Possibly it could be put back on. If this is the case, pull the line out through the gas cap opening after you have released it from the metal connection just above the tank.
Sep 24, 2014 | Garden
My Homelite XH2XS-0254RA Trimmer gas lines have broken off inside the gas tank, can replacement parts be obtained
Hi carlfreeland...
Yes, your fuel lines can be replaced, be sure to get the right size to fit your machine.
Go to your parts supplier with the model/serial number and manufacturer of your weedeater.
Most of the time there will be two size fuel lines, the bigger one is the one the fuel filter inside your tank is connected to.
Please take time to rate me
Jul 03, 2011 | Homelite Expand - It Brushcutter...
Model ut21004 homelite gas weedeater want stay
fuel issue, look for cracks or holes in the two lines from tank to prime bulb, check prime bulb, adjust/clean carburetor, may also need to check filter inside tank it is connected to the bigger of the two hoses. Tim
May 30, 2011 | Homelite Mighty Lite Lawn Trimmer
Hello i have a question on changing th fuel
how to change fuel filter in gas tank remove line from carb pull line through the fill hole in gas tank remove filter replace & pull hose back up reconnect to carb & your done
Jun 27, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite UT2680 trimmer fuel line (25cc engine)
You can go to a small engine repair shop, parts shop or look on eBay and they should have the fuel lines you need. Not very expensive, about $1.00/foot for new Tygon lines. You are way overdue for replacing yours. The ethanol in the gas does a job on them.
Jun 09, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
Primer button on homelite gas trimmer
It's possibly the filter, can't help there. I would check for a split line or loose connection between the tank and bulb and even splits in the bulb itself.
Apr 24, 2010 | Homelite Mighty Lite Lawn Trimmer
Fuel line on Homelight
the filter in the gas tank that line goes to carb
and the one that line goes to bulb
Jul 18, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
My homelite weed eater sx-135 the fuel filter broke of the tube
The longest, and sometimes smaller in diameter, fuel line goes from the carb. to the bottom of the tank. It should rest comfortably on the bottom of the tank. The other line should go from the primer bulb to just inside the gas tank, (about an inch).
HINT: Cut the fuel lines at an angle before inserting them into the gas tank. This will allow you to get them in much easier.
If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
The longer, and sometimes smaller in diameter fuel line, goes from the carburetor to the bottom of the tank. This line, which has the filter attached to the end, should rest comfortably on the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch, with that very small piece of plastic attached to it. This piece of plastic keeps this line from pulling out of the gas tank. this line serves as an overflow from carb.
Jim
I am clealning ;up a homelite string trimmer, one adjusting screw. how can i know if i have the gas lines in correct places i know which line has the filter in the tank but where does it connect to the...
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor often connecting at the bottom to a short barbed stub.
May 14, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
229 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
