Question about LG LRSC26920TT Side by Side Refrigerator
FREEZER NOT WORKING
FREEZER. NOT COOLING AT ALL, LOUD NOISE BY COMPRESOR . ANY SUGESTIONS?
  • m_mcneley May 11, 2010
    How old is it? Have you cleaned the dust from the compressor racks, below or behind refer? Does refrigerator side work at a steady temp?
    Sergeant:
    Champion:
  • 214 Answers
Please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that you have your gas chockage for which the compressor is making noise and the refrigerator is not cooling....... please visit your service authority...........have a nice day:-)
Posted on May 14, 2009
Top mount freezer won't cool, fridge works fine.
check for compresor operation. a relay on compresor could be out
Feb 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana ARB9059cs: compressor makes loud noise (come and go). Refrigerator not working but bottom freezer is working. All lights on. Please advise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
Jan 25, 2010 | Amana ARB9059CS Bottom Freezer...
Compresor is not running - a yelow and right
your power contactor relay on the compressor body is defective
Oct 25, 2009 | Frigidaire 17.8 cu. ft. / 504 liter...
My kenmore freezer is making a lous noise that
Is it still cooling ok - or is it going a bit weird ?
It could be the flow control solenoid - that affects where the gas goes - or the compresor motor (big black thing).
If it does not cool at all - it will need a new run capacitor on the compressor.
If it seems to cool ok - but sometimes too much - then suspect the solenoid coil / control for this.
Neither are that expensive.
Aug 07, 2009 | Freezers
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Compressor doesn't run
If the fan located next to the compresor works that means that the compresor relay is bad or the compresor burned out.
Jul 18, 2009 | Frigidaire FRS23R4A Side by Side...
Freezer or fridge stopped cooling. Can not hear compressor kick on
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
May 01, 2009 | Refrigerators
Fridge freezer not working/power ok,
If the compresor is very hot and won't start,the clicking you heard is the overload at the compresor that goes on & off beacause the relay ,that makes the compresor start is bad or the compresor is bad ,if you know how check the compresors coil if not try replacing the relay with a same replacement(no more than $20 or $30) if still won't start the compresor needs to be replaced.
Apr 24, 2009 | Refrigerators
Fridge making a loud noise like an electric engraver
it is compressor bad,plug cable from wall and after 2 h try again if want work compresor is bad,call service.
Feb 15, 2009 | Kenmore Refrigerators
LG LRSC26920TT Side by Side Refrigerator Logo
112 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
