Question about Ovens
I have a belling triplette 333 combination microwave/oven which i need to replace the bulb for. i do not have the manual and it seems that you cannot get to it without taking the whole machine appart. do you have any ideas how to do this?
TO CHANGE BULB ON BELLING TRIPLETTE 333
You must remove outer cover and bulb is located from the front on left hand side 15w bulb hope ttis helps
Bill
Posted on Nov 15, 2009
Testimonial: "thank you. i since found the manual but thanks anyway"
  • David Adcock
    David Adcock Apr 03, 2013
    Thanks for that info, do you know what type of base the bulb is (BC or screw - & what size of base)
HOw to replace light bulb microwave KEMS308
Unit has to be removed from wall top panels removed to replace if can live with out it great bulb is cheap labor 100-150
Jan 24, 2014 | KitchenAid Architect II KEMS308S 30"...
Hardwiring in cooker
6mm is the norm for wiring in the majority of electric ovens, you could fit 10mm, but it is is not really needed, unless you want to do it that way.
Please rate my fixya solution.
Thankyou.
Jan 30, 2009 | Belling Ovens
Need to replace light bulb in kitchen aid microwave
KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
Jan 19, 2009 | KitchenAid KEMC308 Electric Double Oven
Jenn-air microwave light bulb
This is an older (Mfgr. May, 1987) microwave oven. Functions perfectly, works an looks good to this day, just no light inside. I searched a couple of websites looking for parts for this unit and appliancepartspros.com provided schematics of the product that I own. From those drawings, it was determined that the microwave oven will have to be slid out of the cabinet above the built-in oven in order to change a $2.37, 40W light bulb. Just a handfull of scrws retaining the oven and exhaust baffles and I'll get it out (onmce the New Year's Eve hangover disappears). The engineer who designed a system like this must have been on an Acid Trip. I haven't looked closely at newer microwave ovens, but I'd have to believe changing a crummy light bulb would have to be made easier than this during the preliminary engineering phase of design.
Dec 31, 2008 | Ovens
Oven light bulb
Check your email
Jun 15, 2008 | Ovens
Instruction Manual Needed?
Hold cook time button and stop time button together and while both buttons pressed in, use + and - buttons to set time.
regards Paul.
May 10, 2008 | Belling XOU252 Electric Single Oven
Microwave oven light - KEMC 307
you ll need to pull unit out to replace bulb, 2 scrws remove side trim of oven, 3 or 4 screws remove trim under micro; above oven, 2 more screws behind that grill will release micro from supportthat should free it up enoug to slide foward 6 or 8 inches( the bulb is ontop of the cavity) good luck!
Feb 25, 2008 | KitchenAid KEMC307 Electric Double Oven
big job belive it or not the oven will need to be pulled to change it please post your email and i will send you the manual
Jan 24, 2008 | Ovens
Ovens Logo
399 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
