Question about Homelite Mighty Lite Lawn Trimmer
I am clealning ;up a homelite string trimmer, one adjusting screw. how can i know if i have the gas lines in correct places i know which line has the filter in the tank but where does it connect to the carburetor
  • 420 Answers
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor often connecting at the bottom to a short barbed stub.
Posted on May 14, 2009
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
While trimmed is in use, how do I release more trimmer line?
Bumping the string head lightly on the ground will release more trimmer line if the line was loaded properly and spooled in the correct direction. If the line was loaded wrong, doing this procedure won't help. Make sure your line was loaded correctly. Do this bump as the engine is slowing down or running slow. Most all gas trimmers work this way, but some of the electric ones have automatic line feed and no bumping is necessary.
Oct 10, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
32 cc string trimmer will not run
It sounds like you need to adjust the fuel mixture screw in the carb. To do this, while it is running adjust the screw in either direction until it runs properly without the choke.
Sep 10, 2009 | Craftsman 25cc Gas Line Trimmer
My line has snapped but I am unable to go into the mechanism to retrieve, please can you help.
look for a notch above the guard and rotate the string spool until you see a coresponding notch in the shaft assembly place a screwdriver in both notches then try to losen the string spool screw
Jul 30, 2009 | Homelite Mighty Lite Lawn Trimmer
Installing new line on my string grass trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jul 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
Jun 18, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite curved shaft timmer line problem
So, is this trimmer suppose to feed the string automatically? If not, then it sounds like the string is wound up on the spool the wrong direction.
Jim
May 28, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Homelite string trimmer - gas
put it in the trash and buy yourself a new one nto the same brand.
Aug 09, 2008 | Electrical Supplies
Homelite Mighty Lite Lawn Trimmer  Logo
206 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
