I need instructions for the coleman king cobra lantern radio tv. Specifically, how to power it up, tune, etc. What I really need is an instruction manual I can print/download.
KB2ZGN
SOURCE: coleman lantern fan am/fm radio
This fan/lantern/radio was sold under numerous name brands, and is supposed to come with not only a wall wart, (plug in power supply) but it should have also included a 12VDC cigar lighter cord so it can be charged in your car/truck/SUV, etc. The included car adapter is not a standard variety. It has a special resistor inside the plug that limits the amount of charging current. This is very important. Too much current, and the battery could overheat and be rendered useless, or worse, it could literally explode inside the lantern housing. Your best bet is to locate a universal supply, and set it for 7.5 or 8 VDC maximum, and the plug polarity should be what is called "tip positive" Don't assume that an aftermarket wall wart is "tip positive" check it with a volt meter if you have one available to you. If not, ask your friends, neighbors, or call a local Amateur Radio club and ask if there is someone who would be willing to check for the proper voltage and polarity before you try it. It is a very simple check and I'm sure that they will be happy to assist you. As an aside, there is a little compartment in the bottom of the lantern. Mine came with a small emergency kit with a band-aid or two, monofilament line, a hook, and two matchbook type matches. Very odd, but it was a nice touch. God luck, and have fun with your fan.
Posted on Oct 06, 2008
  • 14 Answers
SOURCE: cobra mt750 two way radios instructions
This website has a PDF file of the Cobra MT750
http://www.tehnoturg.ee/kasutusjuhend/Cobra_MT750_EN.pdf
Posted on Nov 07, 2008
  • 16 Answers
SOURCE: need wiring digram for road king 56 to cobra 29 cb
He is actually looking for the Microphone wiring which is a roadKing Mic to the Radio Cobra 29.
Posted on Jul 08, 2009
tragility
SOURCE: Require instructions to fit cobra 7928 car alarm
hi tony, im tony as well, i just bought a car with a 7928 fitted and after an hour searching chat rooms and web sites found the manuel its available here http://dl.owneriq.net/2/27538fd6-de8c-4da4-9f07-b5b4fc353a82.pdf if you cant find it search google for cobra 7928 user manual
Posted on Jul 17, 2009
kelsey146588
  • 4 Answers
SOURCE: Manual for coleman lantern model 5348-700
simple unscrew the top clockwise and you will see how the tubes are removed,
Posted on Jun 07, 2012
Coleman Lantern TV #D269 appears to be DOA
If it doesn't work with batteries, and the correct power cord is being used, then it's fried. Try wiggling the lantern end of the plug slowly, to put it in a bind at each end. As long As it's turned on, you should see some sign of life if it's not fried. The plug shouldn't move much, but if it moves, the solder points inside of the lantern to the circuit board could be broken off. If none of that works, it's fried.
Oct 15, 2017 | Cars & Trucks
Tip
Parts Callout
INSTRUCTION MANUAL PARTS LOCATOR
1. ANTENNA
2. BATTERY COMPARTMENT
3. CARRYING HANDLE
4. COMPASS
5. SPEAKER
6. LCD CLOCK DISPLAY
7. BACK LIGHT (CLOCK)
8. MODE
9. SET
10. FLASHLIGHT
11. LANTERN / FLASHLIGHT / OFF
12. BLINKER I SIREN / OFF
13. WEATHER BAND/AM/FM SELECTOR
14. TUNING
15. VOLUME ON/OFF
16. LANTERN
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
Why doesn't lantern turn on when not plugged in?
I have a rechargeable spotlight and the directions specifically say not to turn it on while connected to the charger.
Mar 10, 2016 | Coleman Cpx 6 Rechargeable Power Cartridge...
User's manual for coleman rechargeable lantern model # 5348-700
There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
Nov 22, 2011 | Camping, Backpacking & Hiking
Just bought a cobra ltd crome ive mounted every thing how to i clibrate it with my attenna? when i key up both rx/tx and ant lights up red?????
This is a common misunderstanding when it comes to communications equipment. You don't tune the antenna to the radio, but rather you tune the antenna to the vehicle. the vehicle is the ground plane for your antenna system.
With that said You will need an SWR Meter between your antenna and Radio. follow the instructions for your meter for calibrating the meter and follow the instructions for your antenna for adjusting the length.
Jul 14, 2011 | Cobra 29 LTD CB Radio
How to light coleman lantern
Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
Aug 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Cobra 29 NW LTD Classic wont calibrate and red antenna light keeps coming on
The calibrate knob only calibrates the radios SWR meter, the owners manual will show you the procedure for that. If your ANT light is coming on, it is telling you that your SWR is to high, and may cause damage to the radio from reflected power. You should purchase an in line meter as the radios internal meter may be somewhat unreliable. You need to tune the antenna to the lowest SWR possible. Typically anything under 2.0:1 is acceptable. Radio Shack sells a meter for about $50, and is pretty accurate. Antenna mounting can also cause high reflection if it is to close to other objects. Google "CB antenna tuning" or read the instruction manual for you antenna, and you should be able to figure out how to properly tune the antenna.
Jul 07, 2009 | Cobra 25 NW LTD 40-Channels Base CB Radio
Coleman lantern/fan/radio won't take a charge any more.
Yes there is, you can check out http://www.batteryinternational.com/lantern-battery.html to find a replacement, or call 1-877-28-BATTERY if you're having difficulty finding the battery you need. Hope that helps.
Jun 14, 2009 | Coleman Lantern Fan Radio (841.321) AM/FM
Coleman lanterns as collectibles
Coleman Collectors Guide 1903-1954.
Tucker & Ebebdorf
ISBN 0-9651407-0-9
This is an excellent reference with lots of pictures etc., it does not give the prices, however.
You can check Ebay for completed prices if you need an idea of value.
I have not found a book yet with accurate values on Coleman lanterns.
Apr 21, 2009 | Coleman Sport & Outdoor - Others
Televison & Video Logo
278 people viewed this question
Top Televison & Video Experts
