Question about ASUS Eee Pc 1000Ha 160G Netbook
Dont let me install anyhitng
I deleted songbird from my eee pc laptop and i want to install it again but it wont let me it wont let me download anything or install the updates
This has happened three times today and I give up!! I'll be working along fine with my Asus Eee 1000HE netbook running WinXP and then .... poof! The mouse won't work, touchpad won't work,...
try going into safemode with networking, then download malwarebytes just google it, it will give you the link where to get it or click the links I provided.
Install it on the machine then if it asks to restart go ahead and restart in normal mode it should install on its own, after the installation it will ask you to update it so just go ahead and do the update after the update do a scan it will detect what AVG cannot, after the detection just go to quarantine and delete the files detected as threaths.
then restart your computer and see if the issue will happen again.
If the issue still happen I suggest that you try reformatting windows just to narrow down if the issue can be software or Hardware.
I hope this helps.
Oct 01, 2011 | ASUS Eee PC 1000HE Netbook
Every time I start up my eee pc I have an error message : "Asus eee pc acpi service encountered a problem and needs to close..." If I close the pop up comes back immediately. I have already try...
ACPI is the reporting system for the hardware. It tells the operating system about battery charges fan speeds and so on depending on the model.
I would look at the Asus support page for a bios update as well as updates for the ACPI system or software. You can download and just run the updates to install and that should fix this if they have a driver problem and a fix.
http://usa.asus.com/Eee/
Select your model to go to the model page then under downloads you should find the bios updates and the bios utility. Download and run and it will update and hopefully kill the error. I saw 4 updates and two looked like they might address this. Just get the latest one. It will tell you if it needs to be done. Don't run anything else when you do this. Start the update and don;t touch. It should take just a few minutes and may want to reboot after.
Sep 02, 2011 | ASUS Eee PC 1000HE Netbook
I can'install songbird My laptop (OS Vista), It asks for Administrator Password and I don't know what to do! Help!!!
Hi evabonito,
From the sound of it, perhaps your laptop settings are requesting the administrator's password (your laptop password) to ensure that you (the administrator) would like to install the software?
To my knowledge, Philips Songbird will not ask for an administrator password during installation.
Here is an excellent Support Site for Philips Songbird, including FAQ's, a chat link, software and drivers: http://ow.ly/5PTZu
You can also reach dedicated Consumer Care agents to troubleshoot your mp3 issue by calling 1-888-744-5477.
To install Philips Songbird:
The latest version of Philips Songbird is available for download from www.philips.com/songbird.
Tip: For optimal playback of Philips Songbird, please always have the latest version of Quick Time and Windows Media Player 11 (or later) installed before installation of Philips Songbird.
  1. Go to www.philips.com/songbird.
  2. Click "Download Philips Songbird".
  3. A window will pop up. Select "Save" to start downloading Philips Songbird.
  4. Double-click the file you just downloaded to start installation.
  5. Select the desired language and your country.
  6. Follow the onscreen instructions to finish installation.
  7. When installation is completed, click "Finish".
  8. Restart the computer.
Jul 28, 2011 | Philips GoGear ViBE Digital Media Player
Video capture hardware has been deleted in my asus eee pc 1000h laptop.what will i do?
I dont belive your hardware has been deleted, but your driver for it had probably been so. Go to asus.com and locate the drivers / support and look for your driver there and then download and install them.
Mar 05, 2011 | ASUS Eee PC 1000H Laptop
I have an asus eee 1005ha netbook. It freezes constantly while I'm on the internet. I have maybe 4-5 open tabs and signed into outlook. When I try to close out of Internet Explorer it won't do anything....
These machines are made for a min amount of work but you can fix the problem. You need to download two free programs CCleaner and Malewarebytes you can download them at filehippo.com
install ccleaner first and then clean all history then clean the registry you can delete all reg errors.
Then install maleware bytes make sure to download the update then run quick scan and delete all the problems it finds. after this you will have to run these programs once a week this will keep you running if you download anything I would put it on a flash drive to conserve space.
Chris Thrash
B52Computers
Jan 23, 2011 | ASUS Computers & Internet
I deleted the wpcap.dll file in my laptop how can i retrieve it or install it again..?or when i can get the file to reinstall it??tnx
You Download the wpcap.dll file from above link http://dll.downloadatoz.com/wpcap.dll-file-download.html
Oct 08, 2010 | ASUS Eee 4G Notebook
I cannot hear anything from my laptop
http://support.asus.com/download/download.aspx?SLanguage=en-us
select the Eee on product ..than the model ..and the operation system you use..and download and install the sound driver again ..restart after installing it and it will work ..
Jun 03, 2010 | ASUS Eee PC 900 PC Notebook
I deleted my realtek hardware by accident is it posible to retrieve the file or download it again for free?
You probably mean you deleted the driver. Yes you can reterieve it. Run system restore or simply reinstall the driver or download and install.
Feb 16, 2010 | ASUS Eee PC 900 Notebook
My device won't take my music and it's freezing
Once you delete any key system files off this player it is done - call Philips to see if you are still in-warranty.
These newer Philips players are a step backwards - it is too easy to delete system files along with songs.
Jan 31, 2009 | Philips GoGear SA5285/37 Digital Media...
ASUS Eee Pc 1000Ha 160G Netbook Logo
56 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
