Question about Refrigerators
Referagator does not go below 51degrees
Refrigerator area only cools to 51 degrees. Freezer freezes and makes ice. We pulled the plug on refrig and have cleaned the coils, plugged it back in and let it run. It is still at 51 degrees and is set on setting 9, which is the highest. It runs constantly but is still at 51 degrees.
    Sergeant:
    Champion:
  • 214 Answers
First of all switch off your refigerator for about 8 hours.. than again switch it on. now place your thermostart at 4. now let it run for about 2 hrs...... after that also if your refrigerator won't decrease its temperature than please replace the blower inside it........... or else contact your service authority.
have a nice day :-)
Posted on May 14, 2009
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrig is too cold, Freezer won't go below 2 degrees
have you readjusted the temps on each control,possibly you have the refrige side set too cold and this will reduce freezer cooling
Jul 05, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Refrigerator won't cool less than 52 degrees
I can tell you if it can be fixed by you or if you need service. Just answer a few questions as we go through this. Pull away from wall and remove the lower panel. Feel top of compressor and see if too hot to keep your hand there or cool. Let me know if freezer fan and fan below are running. Answer those and that will help me answer your questions, Thanks Sea Breeze
Feb 15, 2010 | Maytag Admiral Top-Freezer Refrigerator
Can this refrigerator be used in an unheated garage?
Yes, You can use most any refrigerator in an unheated area. Just be aware that if it is in a below freezing area for a long period of time that the cold may penetrate enough to get the refrigerator temperatures below freezing also.
Nov 18, 2009 | Refrigerators
What is the best temperature for the bottom freezer and refrig?
Set both dials in the middle.
If you have a nearly full freezer, add 1 dial unit.
If you have a nearly full refrigerator, add 1 dial unit.
If your freezer is less than half full, step down 1 dial unit
Refrigerator should not be less than mid-point on dial (it gets open more often).
This is a good starting point, adjust in a month or so.
Sep 21, 2009 | GE Monogram ZICS360NRRH C... Bottom...
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
GE refrig Model # GSS25WGMD WW freezer is cool, compressor is running, but food is thawing out, ice has melted...not sure if I left door open ovenight, should I call repair..show long does it take to...
I pulled the refrig out from the wall, turned it off, took off the back panel (that covers the compressor fan and motor) and used the attachment on my vacuum to remove the dust from the area. Then I closed the flapper that allows the ice to release from the ice maker compartment to the dispenser, so no warm air would get into the freezer area. I plugged the refrigerator back in and within an hour it was freezing again! So far this week, I have had to repair the garbage disposal and the refrigerator.....I saved some nice $$$ by figuring this out by myself!
Jun 25, 2009 | GE Refrigerators
Whirlpool Refrig. stopped cooling with no warning. Freezer is freezing with ice build up on back wall. Thanks, Mike Strickland
Mike, Please send the complete model number so I can help you better. If your refrigerator has a defrost timer this could be the problem. You also can visit my site below and enter model or part number in the search feature. We also offer free help and assistance. , Thanks, Sea Breeze seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Whirlpool Refrigerators
U-Line icemaker is undependable
to make ice the thermo in the ice maker must be below 5 F...make sure there is a clear flow between the evaporator and the ice make also make sure you have a good seal between the freezer and the refrig areas..
1) put a cup of water in the refrig.
2)start with the coolest setting and move 1 setting every 24 hrs.
until it up until it freezing the water.
3) coolest you can get but not freezing the refrig...
hope is help
Aug 30, 2008 | U-Line Refrigerator Ice Maker
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
