Question about Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive
I have plugged up my drive and is not turning on at first it would light up with the green light and then it went orange and it has been screwed every sense now i can't get power whats wrong here?
  • Anonymous Oct 26, 2008
    I have a similar problem with the power supply. I measure the voltage and it should read at least 12v and it is .9v to 1.2v. Your suggestion to install inside the computer seems like a good idea. Could you tell me more?
  • bdstk45 Oct 26, 2008
    I have a similar problem with my Maxtor 200 GB Hard Drive. The power supply has an out put of .9v instead of the 12v that are required. I like your suggestion of installing into the computer. Could you tell me a little more about this installation process? Iss there any thing I should watch out for? I see there is a both a ribbon cable and power cables are these connections already in the computer typically?
    Problem Solver:
  • 9 Answers
You can find the Power Adapter for Maxtor Personal Storage 3100 from 12V 4A Adapter for Maxtor 3100
Posted on Dec 10, 2010
  • 39 Answers
If you are not getting any lights at all now, check the AC adapter.
If you have a voltmeter, see if anything is showing up on the DC (hard drive) side of the cord.
If you dont have a meter, use the tongue trick. Lay the connector on your tongue, perpendicularly and see if you feel any tingling. Make sure your tongue touches the outer and the inner chamber of the barrel connector. If you dont feel anything, the adapter is bad. You should be able to find one on E-Bay. Make sure it is the same type of a supply. If you cant find the exact same adapter, look for one with higher current (AMP) rating than the old one, not lower. Voltage has to be the same, a 0.x variation is not the end of the world.
Alternatively you can just rip the sucker apart and take out the internal drive. Buy a $10 enclosure and use it in there.
If the power supply is ok, and you feel tingling on your tongue, it's the controller board in the drive cage or the drive itself.
Take the drive apart, and try to plug it into your machine internally. If the drive works, then it's the controller in the cage. If the drive does not work, then you are out of options and need a new one. If that is the case, and you need your data, there are companies that can recover for a nominal fee of around $1000 on average.
Posted on Oct 15, 2007
The power went off at my house due to an overload and when the breaker was turned back on, the tv had no power, no green or orange light. I unplugged the power cord and plugged it in later and the tv...
The power supply board is dead,that the board where the power cord plug into it.Take ur tv aparts,replaced the power supply board,ur tv should work again.Tries websites like, to buy a refurbish power supply board for the replacement.
May 23, 2010 | Vizio L32 32 in. LCD HDTV
Xbox 360 elite has suddenly stopped working and doesnt light up
check you have a light on the power Brick. Usually Orange On Standby.
Push power On Button, should turn green.
No Light At All Check Plugs Fuse.
Orange light On, but not turning on, or going to Green, power Up.
Suspect Faulty Power Supply Unit, Or Motherboard Fault.
Mike @ Compurepair.
Mar 25, 2010 | Microsoft Xbox 360 Console
I have a PSP that I charged overnight and a orange light came on when i plugged it in to the wall charger. After charging all night I went to power on the PSP and it will not power on, no green or orange...
Remove the battery.
Plug the PSP charger into the PSP.
Turn it on.
The PSP works with no battery inside.
If you're not getting a green light at all, your PSP has some sort of damaged as it should work while plugged in with no battery inside.
Mar 17, 2010 | Sony PlayStation Portable (PSP) Console
Blinking orange light
green light mean on
orange light means standby
red light means power failure
no light means the fuse my have blown
good luck
Jul 31, 2009 | Microsoft Xbox 360 Console
Mac Ibook Power supply problem
On Mac iBooks the orange light comes on when it charges the battery. Once the battery is charged it turns green. Im guessing the other powersupply was aftermarket or broken. EIther way, if it starts out green - recognizes the battery isnt full - turns orange for a while - then turns green when the battery is full, then the computer and powersupply are working perfectly. Enjoy your iBook!
Feb 27, 2009 | Apple Computers & Internet
Laptop won't turn on/stay on
Is the fan blocked?
If no air goes in, CPU could overheat.
Aug 26, 2008 | Toshiba Satellite 1135-S125 Notebook
I was installing a program, and the screen went black adn the system shut down.
remove battery and try ac-power if laptop boots up then battery need replacing but if no laptop bootup then take it to be repaired and tell the tecnition what happened and he or she will try other options to get you going again. good luck on problem.
Aug 14, 2007 | Acer Aspire 3680 Laptop
Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive Logo
252 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
