Question about Garden
No Spark We have no spark But, Have new Plug,Coil and sanded flywheel what next?
  • Jim Parker
    Jim Parker May 11, 2010
    Does your tiller have a kill switch?
    Jim
    President:
  • 1,776 Answers
You may have sheared the key in the flywheel. That is what it sounds like to me, anyway. Hope this helps. Good luck.
Posted on Jul 11, 2009
I am not getting a spark to the plug
What Saw? If you can disassemble enough to get to the Coil. take the Coil off and Sand the rust off both the coil and the flywheel. Then use two pieces of paper as a gap between coil and flywheel. This is the first thing I would try after knowing that the Spark plug is good.
Sep 21, 2015 | Garden
I have no spark on my 1969 Honda 90 passport moped any help??
I believe that this moped has a magnito and it is probably not functioning
Jun 09, 2014 | Cars & Trucks
Troy-bilt 27 cc tb80ec string trimmer Will not start, tested spark plug, getting no fire to spark plug
Hi Paul
To make sure you are getting spark at the spark plug,do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B. A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the distance between the flywheel and the coil and be sure to install the new one with the same clearance
Normally the clearance is around .18 thousandsands...(you can also use a business card for the measurment)
Or write the measurement down on a piece of paper for later reference, this measurement is critical to starting of the engine later.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
You can also try to lightly sand the module metal face to increase the possibility of ignition of the old module before replacement.
Please take time to rate me
Bud
Mar 22, 2013 | Garden
Bg86c stihl blower no spark new spark plug new coil gapped right take ground wire off still nothing
Sounds like a tricky one. Have you checked the magetism/functioning of the flywheel.? Tracking back the problem by having a new spark plug and coil would next point you to the flywheel. Coil to flywheel gap should be 0.25 feeler guage.
Hope this proves useful. :)
Mar 15, 2013 | Stihl Bg 86c Handheld Blower Cylinder...
Leafblower... getting fuel, but when I try to start its not getting spark... pulled plug and held it while I pulled the started... nothing... what would be the next step to get it to fire??
remove the flywheel and check the pickup coil and flywheel faces for rust on them as this can kill the pickup signal that you need to make a spark,if rusty,sand them lightly and blow out with air
Apr 18, 2010 | Poulan Weed Eater No.Ebv215 Electric...
No Spark - Cub Cadet model 71 with a Kohler 8hp
check condition of the magneto,located under the flywheel
Oct 06, 2009 | Cub Cadet Street Sign- tractor lawn riding...
I have a an echo srm 3100 weed eater that won't start. I bought a new spark plug and when I pull the starter rope it is not creating a spark. This occurred after starting it up for the first time this...
Well, if you have made sure that the kill switch wire isn't grounded somewhere, then it is probably the ignition module (coil). But before you buy a new coil, try sanding the side of the flywheel and the metal piece that faces the flywheel, (this is part of the coil).
Jim
Jun 07, 2009 | Echo Garden
I Have a Mantis tiller that I can get NO spark
set the coil to the thickness of a dollar bill from the flywheel and tell me what happens. make sure kill wire isn't grounding somewhere else
Jun 07, 2009 | Mantis 2-Cycle Tiller
Chipper won't start
what engine do you have im guessing a briggs & stratton was it running previously or sitting awhile it can be a few things the flywheel key could be sheered or the points are bad or the flywheel & coil are rusted check flywheel & coil to see if rusted if so take coil off mild sand paper like 80 grit i beleave clean both to get the right gap between flywheel & coil turn the flywheel alittle bit so the magnets won't touch coil or if coil still of set flywheel to where it will touch magnets fat peice of sand paper not folded but flat sand paper about .020 gap between magnet & coil if you place sand paper against the flywheel magnet then set coil against sand paper & magnet that should give you 0.020 gap & it should start if not e-mail me i will guide you through everything to get it started
May 11, 2009 | Heavy Machinery
5 HP Briggs and Stratton Engine
Take the coil off clean with sand paper then get a piece of cardboard from a cereal box or cigarette box, put the piece of cardboard in between the coil and the magnetic strip on the flywheel ''believe it or not it is the perfect gap'' 'let the magnet pull the two together'' then tighten the coil down. if still no spark get a new coil.
Sep 04, 2008 | Garden
Open Questions:
Garden Logo
140 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
