Question about Cuisinart DCC-1200 Coffee Maker
How to remove the carafe cover for washing
Cannot get the carafe cover off of the carafe.
Pull it off the handle.
Posted on May 15, 2009
My 12 Cup grind and brew coffee maker needs a good cleaning. How do I do it?
To clean the inside of the coffee maker, fill the reservoir with water as you would to prepare coffee, except add 2 tablespoons of vinegar to the reservoir. Place a clean filter in the basket and run the solution through. When it is complete turn off the unit and let it cool for 2 minutes and then pour the hot solution back into the reservoir for a second run, you can reuse the filter that you placed in it the first time. After it is finished this second time, turn off the unit for 2 minutes and pour the used solution down they kitchen sink. Allow the carafe to cool for a couple of minutes and fill with cold water and run it through as you did the solution, but put a clean filter in this time. Repeat this one more time to remove the vinegar solution and discard the used filters. Once the carafe is cooled fill it about 1/3 full of water, add several ice cubes and 1 tablespoon of baking soda swirl this around in the carafe for a minute or so. Rinse the carafe and run it and the basket through a cycle in the dishwasher or wash by hand with warm soapy water. Rinse thoroughly and you're done. Good luck.
Aug 28, 2013 | Cuisinart Grind and Brew 10 Cup Coffee...
DCC-1200 leaks coffee onto carafe and warmer plate
My coffee pot was leaking over the carafe and onto the warmer. I found that this issue was caused by the carafe lid. The lid was not allowing coffee to flow into the pot fast enough. I removed the inner mechanism from the carafe lid (it pops off really easily) and just sit the lid on top of the pot while brewing, and no more leaks! After brewing, I put the mechanism back onto the lid and twist lid onto the pot.
Nov 16, 2012 | Cuisinart DCC-1200 Coffee Maker
How do I run the clean cycle?
I assume you mean descaling the coffee maker when the Clean indicator flashes after a brewing cycle. You can use a packaged descaling product or white vinegar. For the packaged descaling agent, follow the package directions for the ratio of product and water. If you are using vinegar, fill the carafe with a 50:50 mixture of water and vinegar.
Remove the water filter and remove any coffee and coffee filter from the brew basket. Make sure the unit is plugged in and turned on. Pour the descaling mix from the carafe into the water tank and then place the carafe in the coffee maker. You have 10 seconds to program the cleaning mode or the unit will return to the standby mode. The next step depends on the type of carafe. For a machine with the glass carafe, press Mode 6 times. Otherwise for a unit with the thermal carafe, press Mode 5 times. The Clean indicator will blink. Press Program/Set followed by the + or - button to select Clean On. Press and hold Program/Set until you hear the beep. Press Brew and wait for the cycle to complete (the Clean indicator will go off). Then do two brewing cycles with water but no coffee or coffee filter. Discard the fluid from the coffee maker from all three cycles. Wash the brew basket and then reinstall the water filter.
If you notice an odd taste to the coffee when you next brew some, do at least one more rinse with water (remove the water filter and coffee grounds/filter).
KitchenAid manuals are available from their site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The direct link to the manual for the Kitchenaid KCM223OB is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10321647.pdf . See page 13 for the directions.
I hope this helps.
Jul 04, 2011 | KitchenAid KCM223OB
How do you clean coffee maker?
Start a cycle and run 4 ounces of white vinegar and 16 ounces of water through the coffee maker.
May 29, 2011 | Bunn NHB Coffee Maker
The clean light came on and I cannot find my manual to find out how to clen it. Plaeas help
Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Lift up the reservoir cover. Remove and discard the paper filter and ground coffee. The filter basket can be washed in warm, soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after use. Do not put any water in the unit once the filter basket has been removed. Wipe the area under the filter basket with a damp cloth. Remove the carafe from the heating plate. Discard any remaining coffee. The carafe and lid can be washed in warm, soapy water and rinsed thoroughly, or placed in a dishwasher. The carafe and carafe lid should be placed on the upper rack only. Do not use any scouring agents or harsh cleansers on any part of the coffeemaker. Never immerse base unit in water or other liquid. To clean base, simply wipe with a clean, damp cloth and dry before storing. Fingerprints and other blemishes on the stainless steel housing can be washed off with soap and water or a nonabrasive cleaning solution. Wipe warming plate with a clean, damp cloth. Never use rough, abrasive materials or cleansers to clean the warming plate. Do not dry the inside of the water reservoir with a cloth, as lint may remain.
You can print the manual on this link:
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
Feb 15, 2011 | Cuisinart DCC-1200 Coffee Maker
I am in need of replacemnt carafe for a Kenmore Wave and Brew microwave/coffee maker seriel #721.63993301
HI. I have located the parts needed. I will place two links for the cover and the actual Carafe, as well, below:
Carafe Cover - 3550W1A231B
Carafe - 383EW5A162C
Please rate and have a great day:)
Aug 19, 2010 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Coffee over flowing. It is not emptying into carafe.Just a little coffee goes into the thermal carafe through the lid. Majority goes onto the counter top.
That unit has to be replaced, or you need a new part for it. There is nothing you can do on your own to fix that problem. Call the manufacturer right away, because they may consider that a quality issue since you could be burned by the overflowing water/coffee.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 11, 2009 | Cuisinart Programmable 12-cup Thermal...
Cuisinart DGB-600BC - water inside the carafe shell
First off, do not submerge the carafe in cold water when it is hot. The water will rush past the seals. This solution involves heating the carafe. Be careful to avoid steam burns
1. Place the carafe on a stove top. 2. Slowly heat the carafe. (make sure you are wearing oven mitts -- avoid steam burns) 3. As the carafe heats the water inside steam will escape the area where the seal allowed the water to get in there in the first place. Steam should appear very quickly, If it does not stop the process right away! Pressure can build up and cause the Carafe to explode! 4. Check the carafe from time to time taking care to avoid steam burns. 5. Once the water has been steamed away, remove the carafe from the stove and allow it to cool slowly. DO NOT place the carafe in water or on a very cold surface until it has cooled. The rapid cooling of the left over steam will cause the carafe to collapse on itself if it is placed in cold water while it is still hot from this procedure.
Apr 04, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Need a replacement carafe for JCPenney Cooks 12-cup coffeemaker
You can find your replacement part on amazon... take a look: Amazon com 12 cup coffeemaker carafe. I hope this was helpful. Cheers
Mar 21, 2009 | Coffee Makers & Espresso Machines
Cuisinart DCC-1200 Coffee Maker Logo
159 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
