Question about Sony VAIO PCV-W600G PC Desktop
VAIO PCV-W600G DESKTOP
WHEN U PUSH THE POWER BUTTON, THE FANS COME ON AT A SLOW SPEED. 3 LIGHTS ON THE KEYBOARD COME ON AND THEN GO OFF. THE POWER LIGHT STAYS REDESH. AND THATS ALL IT DOES.
    Problem Solver:
  • 12 Answers
Try unplugging components one by one (disk drive power, CD power, video cards, etc) with the system unplugged and see if the fan speeds up when you restart it. Note than when you remove certain cards, video for example, you may get beep codes.
Everything in a slot on your PC shares a common power bus so any card installed may be pulling too much load on your power supply. Pull em one by one re-starting between each one.
If this doesn't locate the fault, check the power plugs to your disk/cd drives and ensure that you are getting 12VDC between the yellow and black wires and 5VDC between the red and black wires.  If you are not, and you have already pulled all cards/drives, you have either a defective power supply or your motherboard is drawing too much current.  In the last case, pull your memory cards one by one and re-start between each pull.
YOu will get memory size errors if you let the boot procedure go too far but all you want is for the fan to go.
You  can accurately pinpoint POST errors with a POST diagnostics board available at most PC shops. It comes with a code manual.
Posted on Oct 15, 2007
I have a Sony VAIO PCV-W600G PC Desktop and when i turn my computer on the windows screen comes up then it goes anyway. But the screen doesn't come up but you can hear the computer is on. what i
Try pressing Fn-F7 to Choose monitor, it is a setting for using an external monitor or the screen or both. If it does not work try running to safe mode and change the screen resolution to its recommended setting.
Apr 30, 2012 | Sony VAIO PCV-W600G PC Desktop
My Sony Vaio PCV-RX860 won't boot and makes a clicking sound.
It's usual that new desktop PC's have fans sounds and keyboard LED's flashing during booting..There's nothing wrong on that, as long as you can get in to your PC OS.
Jun 06, 2010 | Sony VAIO Digital Studio PCV-RX860 PC...
How do I unlock vaio keyboard?
It's likely your number lock is on. Look for the "Num Lck" or similar key on the top right of your keyboard and make sure it's disabled to type correctly.
Please rate me if this solution works for you
Thanks......Have a great time
May 21, 2010 | Sony VAIO PCV-W600G PC Desktop
Keyboard problem
The keyboard is failing or has a bad connection.
If you have the technical know-how you should check the connections inside the laptop. (probably a ribbon cable) If this doesn't help replace the keyboard.
If it's still under warranty or you don't have the know-how take it to a repair shop.
Jun 02, 2009 | Sony VAIO PCV-W600G PC Desktop
I spilled water on my Sony Vaio one piece PCV-w600g keyboard
You can use the "USB" connection on your lap top to use just about any keyboard.
Replacement Parts: http://esupport.sony.com/US/perl/model-accessories.pl?mdl=PCVW600G
Feb 20, 2009 | Sony VAIO PCV-W600G PC Desktop
Vaio keyboard ?
I just finished working on a pcv-w510g and in my case it seems some liquid was dropped on it, and the chip is messed up. (i saw this when i opened it). you can try to:
Plug in another keyboard and type in the password.  Try to acess the bios and disable stop on keyboard errors. Or open the keyboard and unplug it compleatly if it helps.
Or take out the HDD and put it in an external enclosure or in another pc to get the data off.
Dec 28, 2008 | Sony VAIO PCV-W600G PC Desktop
How to Replace the builtin keyboard for the Sony PCV-W600G
go on to google and search for
Sony PCV-W600G repair manual
there you will find 2 companies that stock them you do have to pay for them and are in dollars
Jun 06, 2008 | Sony VAIO PCV-W600G PC Desktop
Freeeeeeeze problem
Sounds like you may have a bad power supply. It's a cheap fix, abd always a good upgrade. I recommend at least a 400 watt power supply.
Mar 19, 2008 | Sony VAIO PCV-W600G PC Desktop
Sony VAIO PCV-W600G PC Desktop Logo
131 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
