Question about Audiovox Audio Players & Recorders
Volume either goes too high ot too low and won't let me controll it.
Volume will either go up too high or down too low
    Brigadier General:
  • 8,546 Answers
Need specifics to answer this type of question. Did it ever work? What changed? All sources?
Posted on May 16, 2009
Subwoofer makes noise like an untuned TV regardless of volume knob
I would suggest your crossover unit has failed in the speaker cabinet. The crossover circuit board separates the low and high frequency content of your stereos audio signal. The low frequencies go to the bass unit (woofer) and the high frequencies go to the tweeter speaker. If the capacitor on the crossover goes open or near open circuit then noise is introduced into the sound system. Replace either the capacitor or crossover unit.
Jan 18, 2014 | Cambridge Audio Minx X300 - Powered...
When I turn the knob to increase the volume, it goes up to three and drops back down to zero. It does this everytime I move the knob at a normal pace or faster. However, if I push the knob slightly in and...
It could be a safety protection meaning you could have a shorted speaker check all speakers and wiring, or it could be a defective volume control, try cleaning the volume with a contact cleaner spray you can find at any good electronic store (you normally have to open the radio to reach the POTENTIOMETER/VOLUME) to be able to spray inside it, than alternate (high/low) the control repetively to move/clean the volume's circuitry
Feb 09, 2011 | Car Audio & Video
I have a passat 3.6 2006 that is driving me crazy whith the volume that i cannot control as i would like to.I already have deactived the speed control and that problem still there,if want the volume high...
The radio's in most VW's are fickle. You basically need a new unit. Whatever you do ,do not buy one from the Dealer. Any other models are cheaper and will last and work better than the factory unit.
Jun 23, 2010 | 2006 Volkswagen Passat
Radio volume goes up and down when its on a low volume not on high
Check the dealer and see if your radio automatically adjust to your speed. Some radios were built to raise the volume when driving at higher speeds and when you get in slow traffic or when you stop it would automatically adjust down the volume. You can also go to a Radio Shack and get a spray cleaner for electrical parts and pull the volume knob off of your radio and spray the volume control and turn it rapidly to remove any hidden dirt on that volume control.
Sep 13, 2009 | 2003 Chevrolet Tahoe
Amplifier goes from low volume to high volume without touching any controls. I turn it down only to have it mysteriously go up again 5 minutes later. Warranty ran out one week ago...
Let's eliminate ghosts and goblins. I can't identify your unit. Give me a make and model number.
As a test, locate the remote control window on the front of the unit, if it has one. Set it up to watch or listen to something then cover the remote window on the unit with a small piecr of cardboard. If you can't locate its infrared receiver for the remote just cover the entire front of the unit with something sufficiently opaque to block your remote. Try to operate it with th remote to be sure the unit can't see it.
If the expected problem never comes back you have a stray signal from something else in the environment getting interpreted as a 'volume up' command. Then look around for other remotes being used, wireless devices, use your imagination. I used to have a remote-controlled space heater and my TV would sometimes shut off if I used the remote. Does the unit have line-of-sight to a nearby house? Maybe something next door (garage opener?) is interfering.
If it still happens and there are no other infra-red devices nearby you have a ghost.
Apr 27, 2009 | Audio Players & Recorders
I have a samsung r60plus laptop, it has very low sound even though the volume is up as high as it goes, it was fine yesterday.
check ur volume control settings under your accessories , or another program u may be running with a volume control.undo anything you done before u notice this malfunction
Aug 05, 2008 | Computers & Internet
Tivoli Radio "Model One" Volume Problem
TRY SPRAYING A LITTLE CONTACT CLEANER ON THE VOLUME CONTROLL
I EVEN USED RUBBING ALCOHOL.
Mar 23, 2008 | Tivoli Henry Kloss Model Two FM/AM Radio
Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Aug 18, 2007 | Bose 3 2 1 GSX System
Volume
This sounds like a case of a dirty/defective rotary encoder. The volume control used here is not the conventional potentiometer type , but a rotary set of switches that tell the sytem if the knob is being turned left ot right.
Do you think you'd be able to open the unit and spray some contact cleaner into the rotary encoder? It might involve dis-assembling it down to front bezel removal.
jango.
Aug 18, 2007 | RCA RS2044 Shelf System
PANASONIC SA HE9 RECIEVER 5.1
If the sub has a volume control, turn it down then turn up the volume on the amp to the very high volume you mentioned. If it still has very low muffled sound, then we know the problem is about the amp.
Apr 24, 2007 | Panasonic SA-HE90 Receiver
76 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Chinmay Joshi
Chinmay Joshi
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
