Question about Craftsman 25cc Gas Line Trimmer
Cannot start my trimmer, even change the spark
  • 3 Answers
Take off the air cleaner and squirt gas in the carb. If it fires it is not getting gas from the tank. If it does not fire pull the spark plug and squirt a little gas in the cylinder. Replace the plug and try starting it. If it fires it is not getting gas from the carb.
Posted on May 15, 2009
Will not start with new parts?
is the spark plug wet when you pull it out ? Is your gas fresh? Did you check for spark? If all is good then I would check compression, then Carb
Oct 21, 2011 | Craftsman 25cc Gas Line Trimmer
Ryobi 700r trimmer does not start. Changed spark
hve you checked the HT lead and the on/off switch i had the same model as this and i changed everthing but in the end t chucked the thing away and got a sthil modle
Jun 21, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a Troy weekwacker, and after sitting this winter, it WILL not stay running. The only way to even get it to start is to load the thing with starting fluid, and then it only runs til it eats up all...
Have you changed the spark plug on this unit? If all else has failed, this is more then likely the problem. Please let me no if it takes care of the problem.
Sincerely, Shastalaker7
Apr 14, 2010 | Troy Bilt Tb70ss Gas Trimmer
String-trimmer (weed eater) won't start.
the only thing left is the coil that is inside the cover right next to the flywheel with a gap of 10 thousand of a inch a business card will work but a new coil is almost thr price of a new trimmer unless you have a used one
Nov 05, 2009 | Garden
I have checked spark plug,spark is strong & blue but still willn't start,what could be coursing trimmer not to start? Should I change fuel mixture,flush fuel lines?
have you checked for the PROPER spark plug gap? this is crucial, and if you have spark and fuel, with the proper GAP it WILL run
Sep 04, 2009 | Ryobi Garden
Trimmer model: Sears 358.796121: no start
Could be a faulty kill switch not allowing it to start, sounds like you covered all the things I would check.
Jul 09, 2009 | Craftsman 25cc Gas Line Trimmer
Ryobi 780 Trimmer No Spark - won't start
Hi
Check the spark at the plug,compression and carburation.Clean the air and the fuel filters.Check the muffler.
best regards savumihai71
Sep 17, 2008 | Garden
Husqvarna string trimmers 125c
Check for a spark. If none, then the coil is bad. Replace it. That should solve your problem.
Sep 10, 2008 | Husqvarna Forest & Garden 125c 17"...
Gas powered ryobi trimmer will not start
Hi
I found that the plug that came with my unit had an intermittent fault (sparked sometimes, then not all) definately the plug in my case. And yet at first, seemed to start OK, progressively got worse.
OK so youve changed the plug! Now check for spark....Can you see the spark if you pull the cord a few times
(you have to unscrew the plug from the head but leave it connected to lead & rest the plug against the metal cylinder surface using a pair of pliers to steady it and so you dont get a small shock)
If youre getting visable spark when you pull the cord, suspect fuel feed blockage from carb, Test by: Prime the bulb & turn to full choke, pul the start cord, Is there petrol vapour/odour present within the cylinder with the spark plug removed.
Check also gauze air filter behind the roto choke knob is clear, on/off switch (could be damp wd40) Test compression put your finger over the open plug port, plug starter cord, should be a little pressure build up
Hope this helps
please rate my comments - thanks
Aky1967
Jan 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Craftsman 25cc Gas Line Trimmer Logo
398 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
